Re: Molnar rods
[Re: J_BODY]
#2171153
10/09/16 10:18 PM
10/09/16 10:18 PM
dartman366
Mt. Vernon, Ohio
Andy, you are going to like them, I have the 6.535 rod in my 512, and they checked out spot on. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Molnar rods
[Re: birdtracker]
#2171337
10/10/16 07:30 AM
10/10/16 07:30 AM
Posts: 9,896 MI, usa
dvw
MI, usa
What do you think the horsepower limit is on those? Birdtracker Mines never been on the dyno but runs 9.0@148 3350lbs. 7.100" Molnar with 2.200 pin". Bob weight with a little careful ring pack choice was less than with my BME aluminum rods. Doug
Re: Molnar rods
[Re: birdtracker]
#2171364
10/10/16 10:26 AM
10/10/16 10:26 AM
Posts: 3,530 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
What do you think the horsepower limit is on those? Birdtracker If you ask that question of Tom Molnar (who is a great guy), he will tell you horsepower has nothing to do with it. It is a function of piston/pin/ring weight and RPM. Give him the weights and he can tell you the RPM you should not exceed with the rod. Bill
Re: Molnar rods
[Re: 340Cuda]
#2171450
10/10/16 01:29 PM
10/10/16 01:29 PM
dvw
MI, usa
What do you think the horsepower limit is on those? Birdtracker If you ask that question of Tom Molnar (who is a great guy), he will tell you horsepower has nothing to do with it. It is a function of piston/pin/ring weight and RPM. Give him the weights and he can tell you the RPM you should not exceed with the rod. Bill Exactly. I told Tom my piston/ring/pin weight along with no power adder. Gave him a self imposed 7500 rpm limit. He said that they were more than enough. Doug
Re: Molnar rods
[Re: AndyF]
#2173930
10/13/16 07:21 PM
10/13/16 07:21 PM
Posts: 2,094 central texas
krautrock
central texas
Wait until you see the pistons for this engine. JE is designing a Mopar big block piston based off the LS design. The sides are moved in so the pin is shorter than normal. Should be really lightweight. sheeeeyit. is it 1.32CH? so it could be used in a 451?
Re: Molnar rods
[Re: dogdays]
#2173955
10/13/16 07:48 PM
10/13/16 07:48 PM
Posts: 4,715 Wichita
GY3
Wichita
That weight total is making me laugh.
The stock piston/rod/rings/pin assembly from my '86 318 weighed more than that! Something like 1540 grams.
Shoot, the late LA motor rod at 758 grams is heavier than AndyF's bigblock rod!
R. It looks like my numbers (in the other thread) translated to over 6 lbs. of savings in the rotating assembly vs. the factory LY rods and cast pistons.
Re: Molnar rods
[Re: AndyF]
#2173956
10/13/16 07:49 PM
10/13/16 07:49 PM
GY3
Wichita
Wait until you see the pistons for this engine. JE is designing a Mopar big block piston based off the LS design. The sides are moved in so the pin is shorter than normal. Should be really lightweight. I'm curious to see rod/piston total!
Re: Molnar rods
[Re: '72CudaRacer]
#2174062
10/13/16 09:53 PM
10/13/16 09:53 PM
dartman366
Mt. Vernon, Ohio
same here with Icon pistons.
Re: Molnar rods
[Re: krautrock]
#2174436
10/14/16 11:42 AM
10/14/16 11:42 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
Wait until you see the pistons for this engine. JE is designing a Mopar big block piston based off the LS design. The sides are moved in so the pin is shorter than normal. Should be really lightweight. sheeeeyit. is it 1.32CH? so it could be used in a 451? Yes it will be, that is the rod length and piston Ch I have with my 3.9 stroke crank.
Re: Molnar rods
[Re: GY3]
#2174437
10/14/16 11:43 AM
10/14/16 11:43 AM
JohnRR
R. It looks like my numbers (in the other thread) translated to over 6 lbs. of savings in the rotating assembly vs. the factory LY rods and cast pistons. Factory piston and pin in a big block mopar is a little over 1000 grams.
