Re: Ring and Pinion pattern (round two)
[Re: gdonovan]
#2178426
10/19/16 09:09 AM
10/19/16 09:09 AM
Posts: 1,138 Home of the Bluegrass
MoparJunkie
If your pattern is spot on and the backlash is right in the middle of specs then sum it up to gearset quality. I worked for DCA as technical training instructor and worked on enough DANA's and corporate axles to make me sick. That being said, there are a lot of factors, but at the end of the day if it's setup within specs and still noisy it'll be a gearset issue... Very hard to find stellar gearsets, we even used what they call matched gearsets when we had extreme situations.
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: crash520]
#2178638
10/19/16 03:28 PM
10/19/16 03:28 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I've been told, true or not flip or flop don't care, that ratio's above 3.55 can be on the noisy side as they are more a truck ratio, either way it's piss poor with today's manufacturing machinery that we are buying hit and miss sets, it's an install and prey situation today.
I have run 4.11, 4.56, 4.88 on the street and all are silent compared to this hunk of junk living in my 8.25 rear. My GTX just ran 11.0 at 121 with a silent 4.11 gear set 3 weeks ago. As a dealer tech I have driven many vehicles with ratios over 3.55 and they make no noise. This gear set sounds like a dentist drill in the trunk and will be the last Motive set I ever purchase.
"I think its got a hemi"
[Re: gdonovan]
#2178812
10/19/16 10:25 PM
10/19/16 10:25 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I actually liked the look of the .020 the most. I probably would have tried .022. .026 or more loks like you're on the edge of the pinion's teeth. The less shim seems to have more the look of "flat on flat", if that makes sense.
[Re: TJP]
#2178997
10/20/16 06:56 AM
10/20/16 06:56 AM
gdonovan
Oakdale CT
I understand the basic principle but the pattern reading seems almost like black magic Which is why I had the vendor who supplied the gear set approve the pattern before running the car. "You didn't have it setup correct" excuse has just been eliminated. Edit: I am considering dropping the shim from where it is currently at to .022-.024. Whats the worst that will happen? Already junk as far as I'm concerned.
[Re: NANKET]
#2179605
10/21/16 08:11 AM
10/21/16 08:11 AM
gdonovan
Oakdale CT
Send the gears out to get REM finished. They will be smooth after that. Might work.
They will go in the trash before I put any more money into them, thanks for the suggestion though. Just having a run of bad luck this month.
[Re: gdonovan]
#2179607
10/21/16 08:17 AM
10/21/16 08:17 AM
gdonovan
Oakdale CT
Anyone have any feedback on these four companies? Yukon and Richmond I'm familiar with, the other two not so much.
[Re: gdonovan]
#2180177
10/22/16 08:27 AM
10/22/16 08:27 AM
gdonovan
Oakdale CT
Richmond I'm inclined to go with since they have been around forever but that doesn't seem to mean much these days.
[Re: gdonovan]
#2180247
10/22/16 11:50 AM
10/22/16 11:50 AM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
US STANDARD GEAR - from what I have heard are over stock or non spec. Yukon GEAR
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: gdonovan]
#2180394
10/22/16 05:10 PM
10/22/16 05:10 PM
gdonovan
Oakdale CT
Interesting.
Pulled everything apart again this morning after an hours run time and dropped the shim from .026 to .023 and set the backlash at .009
The noise moved up about 10 mph from where it was and seems to be in a more narrow window, it also sounds a touch more quiet.
Dare I move another .003 or just leave it the hell alone? I am getting tired of disassembling my 8.25" over and over. Good practice. I'll post the new pattern in a few hours.
The marks on the teeth look very, very coarse. I have my doubts about how well they were "lapped in" from the factory.
Gary
