Re: 505 Overheating!!
[Re: GY3]
#2173932
10/13/16 07:24 PM
10/13/16 07:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have a 505 and drive it everywhere with a very simple setup:
440Source pump and housing Original '65 manual transmission radiator Mopar clutch fan with Hayden Jaguar clutch (shorter for clearance) 36° total timing that, for the most part, is locked out.. No thermostat No fan shroud
Car never overheats, even when hotlapping at the track. It will creep over 200°F on the highway at 70mph but never gets higher.
The 440Source pump is a scapegoat as is the b.s. about water not staying in the radiator long enough to get cooled off!
I agree about the thermostat. I have never had a car run hotter when the thermostat was removed as they always ran cooler or the same if it has another problem. Ron
[Re: Shatar4]
#2173972
10/13/16 08:20 PM
10/13/16 08:20 PM
RapidRobert
Wow! This is a lot of ideas I have to try. Hey we're the best
[Re: ahy]
#2174181
10/13/16 11:46 PM
10/13/16 11:46 PM
Posts: 4,699 Wichita
GY3
Wichita
I need to clarify one point. My comment about the temp creeping to 200° on the highway is on a very warm 90° plus day. Most of the time it stays happy around 180° in reasonable temps.
