Re: Molnar rods
[Re: AndyF]
#2174903
10/14/16 10:57 PM
10/14/16 10:57 PM
Posts: 4,209 New York
polyspheric
New York
horsepower has nothing to do with it. It is a function of piston/pin/ring weight and RPM
X2, reciprocating weight X RPM^2 (with a tiny adjustment for rod thrust angle) determines rod breakage.
Boffin Emeritus
Re: Molnar rods
[Re: polyspheric]
#2175199
10/15/16 12:41 PM
10/15/16 12:41 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
X2, reciprocating weight X RPM^2 (with a tiny adjustment for rod thrust angle) determines rod breakage. Could you go through a calculation of this for us?
Re: Molnar rods
[Re: 340Cuda]
#2175303
10/15/16 03:33 PM
10/15/16 03:33 PM
Posts: 4,691 Wichita
GY3
Wichita
X2, reciprocating weight X RPM^2 (with a tiny adjustment for rod thrust angle) determines rod breakage. Could you go through a calculation of this for us? Don't encourage him...
Re: Molnar rods
[Re: GY3]
#2175436
10/15/16 08:19 PM
10/15/16 08:19 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Re: Molnar rods
[Re: max_maniac]
#2177074
10/17/16 05:49 PM
10/17/16 05:49 PM
dogdays
Actually there is a spreadsheet that has the program built into it to calculate acceleration and velocity of the piston for any stroke, rod length and rpm. I have it on my computer, don't know how to attach it, maybe I'll figure it out.
R.
Note in the spreadsheet the max acceleration numbers are always at the top, where velocity = zero. These numbers have units of ft/sec^2. To convert to Gs we divide by 32.2.
60,085 / 32.2 = 1,866 Gs. At that point a 500 gram piston is exerting an outward pull of 933kg or 2,055 lb.
