Page 40 of 45 1 2 38 39 40 41 42 44 45
Re: Trick Flow heads [Re: 65Fury440] #2170453
10/08/16 06:36 PM
10/08/16 06:36 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By 65Fury440
I had a set of TF heads matched up to a 337 intake.
Larry Smith from Flow2Tech Cylinder heads in NC did the work. Here are the numbers.
In. Ex.
1.99 63
2. 170 126
3. 243 165
4. 306 192
5. 340 210
6. 352 222
7. 370 231
This is cfm the intake ports are 246 cc
Did you get "before" #s?
Re: Trick Flow heads [Re: Harley] #2170481
10/08/16 07:03 PM
10/08/16 07:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Harley
Curious if the 30 cc increase in port volume means the 270 is a Max Wedge. That's a lot of volume without the entry size being opened up.
Re: Trick Flow heads [Re: fast68plymouth] #2170520
10/08/16 07:57 PM
10/08/16 07:57 PM
AndyF Online content
AndyF  Online Content
There is a spec sheet posted over on A body forum that says the 270 heads are MW with a port opening of 2.630 x 1.340. So that might not be as big as some people make a MW opening, but I think it is close to what some of the smaller MW gaskets are.
Interesting thing is that the 270 head uses standard rocker arms. So no need to buy the 0.800 offset Indy rockers or the Victor offset rockers.
I'm planning to have the 270 heads on the dyno as soon as they ship. I don't know if Trick Flow is going to release an intake or not. If they don't then I guess I'll have to find a 400-2 Indy intake.
Re: Trick Flow heads [Re: fast68plymouth] #2170522
10/08/16 08:04 PM
10/08/16 08:04 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
The Indy MW gasket is listed as having a 2.650x1.340 port opening, which is the size I make SR or EZ heads when I take them from std port to MW size.
Sounds like the TF270 is MW size to me.
Re: Trick Flow heads [Re: fast68plymouth] #2170543
10/08/16 08:55 PM
10/08/16 08:55 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
That looks like a good intermediate head, especially for strokers . Wonder what price range and shipping date .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: fast68plymouth] #2170617
10/08/16 11:04 PM
10/08/16 11:04 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I will be buying a set of them.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: Skeptic] #2170737
10/09/16 02:19 AM
10/09/16 02:19 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
In. Ex.
1.99 63
2. 170 126
3. 243 165
4. 306 192
5. 340 210
6. 352 222
7. 370 231
Larry said the before numbers were close to written specs. I need to ask him why the exhausts numbers were so far off.
Re: Trick Flow heads [Re: 65Fury440] #2170803
10/09/16 11:19 AM
10/09/16 11:19 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
We are finally getting the '65 Plymouth to test n' tune next weekend with the 470 low deck/ TF 240 headed beast.
We dynoed the engine back in July with an Indy intake- corrected #'s were 653 HP; 630 Ft.Lb. We just switched to the TF intake upon engine install. What a nice piece! It's about 6# lighter, 1" lower and the ports are spot on with the gasket and heads (gasket matched intake).
We did add a 1" carb spacer, so we'll see what the results are at the track and will post them here in a week.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Trick Flow heads [Re: chrisnben] #2170812
10/09/16 11:50 AM
10/09/16 11:50 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Nice can't wait to here some ET results. Any idea what the car weight is?
Re: Trick Flow heads [Re: fast68plymouth] #2172352
10/11/16 07:06 PM
10/11/16 07:06 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Originally Posted By fast68plymouth
Originally Posted By Rob C
IMO, more than 30hp for a tenth, a lot more.
At 3800lbs, going from 11.50 to 11.40, the moroso chart shows it would take 13hp, about the same for going from 115mph to 116mph.
So @ 3950pounds I need to find over 50 horse to go from 11.40 to 11.00 ?
Thinking of swapping from Eddy RPM STD window to the TF 240.
Michael
Re: Trick Flow heads [Re: fast68plymouth] #2172771
10/12/16 11:03 AM
10/12/16 11:03 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Eagerly waiting for the 270 Port version...
In general, is there a way to figure out how much higher peak torque would be shifted going from STD to MW port? All else being equal
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Trick Flow heads [Re: OUTLAWD] #2172780
10/12/16 11:19 AM
10/12/16 11:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
you could start with the Jim McFarland formula:
Jim McFarland's formula for calculating the torque peak in and engine. The formula is: the smallest CSA of the intake track x 88200 divided by the cubic inches of one cylinder.
From MaxRace Software:
a more accurate Formula is
RPM = ( 614 * CA ) / ( Bore * Bore * Stroke * .00353 )
where RPM = point of Peak HP
614 feet per second (.55 Mach)
There is a whole thread on this here:
http://speedtalk.com/forum/viewtopic.php?t=771
Re: Trick Flow heads [Re: SILVER67] #2172820
10/12/16 12:13 PM
10/12/16 12:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Michael
If everything is working as it should.....
11.40 is 115.2mph, and is 8.49lbs/hp
11.00 is 120.0mph, and is 7.52/lbs/hp
If your car stayed at 3950lbs and you did nothing to make it more efficient, then it should take an extra 60hp to make that jump in performance.
Re: Trick Flow heads [Re: OUTLAWD] #2172827
10/12/16 12:19 PM
10/12/16 12:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Trick Flow will probably have the 270 head on display at the Halloween Classic at Norwalk next week at Norwalk, Ohio. They always have a VERY nice tent display there. Betting they will then start working on a small block mopar head if the Edelbrock Victor doesn't scare them away from doing so.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow heads [Re: OUTLAWD] #2172842
10/12/16 12:44 PM
10/12/16 12:44 PM
The torque peak will move up about 25% if everything else can handle that big of a change. So if your engine has a torque peak at 5000 rpm with the 240 heads then it will move to 6250 with the 270 heads. But, you would need the correct cam, carb, intake, etc. to actually move the torque peak up that much.
Re: Trick Flow heads [Re: fast68plymouth] #2172854
10/12/16 01:02 PM
10/12/16 01:02 PM
So. Burlington, Vt.
So. Burlington, Vt.
Here's my grey matter 3.2 prediction.....
On a "typical" 493/505/520 bracket or hot street type build, with normal compression ratios(10.0-13.5) and cam lift/duration(.550-.700 lift, 250-280 @.050) running a single plane manifold with a properly sized carb, and the proper sized headers for the application, the TQ peaks would be within 500rpm of each other if you changed ONLY the heads and intake manifold.
Re: Trick Flow heads [Re: fast68plymouth] #2172865
10/12/16 01:20 PM
10/12/16 01:20 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Thanks for the info guys. Right now my 493 is a stump puller, single plane, and a 260/266 cam, I'll have to dig up the dyno sheets to see peak torque RPM. Just on the fence if the trade-off is worth it, port velocity of the small ports to the flow of the large ports. Street/Strip type deal.
Re: Trick Flow heads [Re: fast68plymouth] #2172871
10/12/16 01:29 PM
10/12/16 01:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
I doubt you'd be able to swap from a "decent" std port head to the TF 270's(and accompanying intake manifold.......well, unless you used something like the Indy 440-2D ) and see much improvement to the ET in a mid-low 11 sec street/strip combo without changing something else in the car to take advantage of the bigger heads upper rpm capability. This is assuming that the current combo is at least somewhat correct to begin with.
Re: Trick Flow heads [Re: fast68plymouth] #2172874
10/12/16 01:31 PM
10/12/16 01:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Since Andy will have both the TF 240 and 270 on hand, maybe if he's looking for something to test, he could do that very test.
Swap only the heads and manifold and see just how it shakes out.
Re: Trick Flow heads [Re: fast68plymouth] #2172923
10/12/16 02:38 PM
10/12/16 02:38 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Right now i'm going
11.37@117.7 on an 84* day
Two Sundays ago i had 11.32/11.33 as my dial for 8 rounds in two classes.
On that Sunday it did a string of 11.32/11.33 @ 117.8-118.1
And two runs that clicked off an 11.28@118.44 and 118.12
Temp ranged from 55* to 65* throughout the day.
Does bottom 11.40's @ 117 when the temp is 86* to 88*
I do have all the stuff to convert it to manual steering.
Not sure if the WO23 scoop would do much.
Think the 240 heads are enough alone ?
