Re: Trick Flow heads
[Re: 65Fury440]
#2170453
10/08/16 06:36 PM
10/08/16 06:36 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I had a set of TF heads matched up to a 337 intake. Larry Smith from Flow2Tech Cylinder heads in NC did the work. Here are the numbers. In. Ex. 1.99 63 2. 170 126 3. 243 165 4. 306 192 5. 340 210 6. 352 222 7. 370 231 This is cfm the intake ports are 246 cc Did you get "before" #s?
[Re: fast68plymouth]
#2170522
10/08/16 08:04 PM
10/08/16 08:04 PM
fast68plymouth
So. Burlington, Vt.
The Indy MW gasket is listed as having a 2.650x1.340 port opening, which is the size I make SR or EZ heads when I take them from std port to MW size.
Sounds like the TF270 is MW size to me.
#2170543
10/08/16 08:55 PM
10/08/16 08:55 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
That looks like a good intermediate head, especially for strokers . Wonder what price range and shipping date .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Skeptic]
#2170737
10/09/16 02:19 AM
10/09/16 02:19 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
I had a set of TF heads matched up to a 337 intake. Larry Smith from Flow2Tech Cylinder heads in NC did the work. Here are the numbers. In. Ex. 1.99 63 2. 170 126 3. 243 165 4. 306 192 5. 340 210 6. 352 222 7. 370 231 This is cfm the intake ports are 246 cc Did you get "before" #s? Larry said the before numbers were close to written specs. I need to ask him why the exhausts numbers were so far off.
[Re: 65Fury440]
#2170803
10/09/16 11:19 AM
10/09/16 11:19 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
We are finally getting the '65 Plymouth to test n' tune next weekend with the 470 low deck/ TF 240 headed beast.
We dynoed the engine back in July with an Indy intake- corrected #'s were 653 HP; 630 Ft.Lb. We just switched to the TF intake upon engine install. What a nice piece! It's about 6# lighter, 1" lower and the ports are spot on with the gasket and heads (gasket matched intake).
We did add a 1" carb spacer, so we'll see what the results are at the track and will post them here in a week.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: chrisnben]
#2170812
10/09/16 11:50 AM
10/09/16 11:50 AM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
We did add a 1" carb spacer, so we'll see what the results are at the track and will post them here in a week. Nice can't wait to here some ET results. Any idea what the car weight is?
#2172352
10/11/16 07:06 PM
10/11/16 07:06 PM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
IMO, more than 30hp for a tenth, a lot more. At 3800lbs, going from 11.50 to 11.40, the moroso chart shows it would take 13hp, about the same for going from 115mph to 116mph. So @ 3950pounds I need to find over 50 horse to go from 11.40 to 11.00 ? Thinking of swapping from Eddy RPM STD window to the TF 240. Michael
#2172771
10/12/16 11:03 AM
10/12/16 11:03 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Eagerly waiting for the 270 Port version...
In general, is there a way to figure out how much higher peak torque would be shifted going from STD to MW port? All else being equal
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2172780
10/12/16 11:19 AM
10/12/16 11:19 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
you could start with the Jim McFarland formula: Jim McFarland's formula for calculating the torque peak in and engine. The formula is: the smallest CSA of the intake track x 88200 divided by the cubic inches of one cylinder. From MaxRace Software: a more accurate Formula is RPM = ( 614 * CA ) / ( Bore * Bore * Stroke * .00353 ) where RPM = point of Peak HP 614 feet per second (.55 Mach) There is a whole thread on this here: http://speedtalk.com/forum/viewtopic.php?t=771
[Re: SILVER67]
#2172820
10/12/16 12:13 PM
10/12/16 12:13 PM
fast68plymouth
So. Burlington, Vt.
IMO, more than 30hp for a tenth, a lot more. At 3800lbs, going from 11.50 to 11.40, the moroso chart shows it would take 13hp, about the same for going from 115mph to 116mph. So @ 3950pounds I need to find over 50 horse to go from 11.40 to 11.00 ? Thinking of swapping from Eddy RPM STD window to the TF 240. Michael If everything is working as it should..... 11.40 is 115.2mph, and is 8.49lbs/hp 11.00 is 120.0mph, and is 7.52/lbs/hp If your car stayed at 3950lbs and you did nothing to make it more efficient, then it should take an extra 60hp to make that jump in performance.
[Re: OUTLAWD]
#2172827
10/12/16 12:19 PM
10/12/16 12:19 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
In general, is there a way to figure out how much higher peak torque would be shifted going from STD to MW port? All else being equal Trick Flow will probably have the 270 head on display at the Halloween Classic at Norwalk next week at Norwalk, Ohio. They always have a VERY nice tent display there. Betting they will then start working on a small block mopar head if the Edelbrock Victor doesn't scare them away from doing so.
[Re: OUTLAWD]
#2172842
10/12/16 12:44 PM
10/12/16 12:44 PM
Posts: 31,076 Oregon
AndyF
In general, is there a way to figure out how much higher peak torque would be shifted going from STD to MW port? All else being equal The torque peak will move up about 25% if everything else can handle that big of a change. So if your engine has a torque peak at 5000 rpm with the 240 heads then it will move to 6250 with the 270 heads. But, you would need the correct cam, carb, intake, etc. to actually move the torque peak up that much.
#2172854
10/12/16 01:02 PM
10/12/16 01:02 PM
fast68plymouth
So. Burlington, Vt.
Here's my grey matter 3.2 prediction.....
On a "typical" 493/505/520 bracket or hot street type build, with normal compression ratios(10.0-13.5) and cam lift/duration(.550-.700 lift, 250-280 @.050) running a single plane manifold with a properly sized carb, and the proper sized headers for the application, the TQ peaks would be within 500rpm of each other if you changed ONLY the heads and intake manifold.
#2172865
10/12/16 01:20 PM
10/12/16 01:20 PM
OUTLAWD
Metro Detroit
Thanks for the info guys. Right now my 493 is a stump puller, single plane, and a 260/266 cam, I'll have to dig up the dyno sheets to see peak torque RPM. Just on the fence if the trade-off is worth it, port velocity of the small ports to the flow of the large ports. Street/Strip type deal.
#2172871
10/12/16 01:29 PM
10/12/16 01:29 PM
fast68plymouth
So. Burlington, Vt.
I doubt you'd be able to swap from a "decent" std port head to the TF 270's(and accompanying intake manifold.......well, unless you used something like the Indy 440-2D ) and see much improvement to the ET in a mid-low 11 sec street/strip combo without changing something else in the car to take advantage of the bigger heads upper rpm capability. This is assuming that the current combo is at least somewhat correct to begin with.
#2172874
10/12/16 01:31 PM
10/12/16 01:31 PM
fast68plymouth
So. Burlington, Vt.
Since Andy will have both the TF 240 and 270 on hand, maybe if he's looking for something to test, he could do that very test. Swap only the heads and manifold and see just how it shakes out.
