Re: Why is a cams intake center line usually around 102 to 112?
[Re: 451Mopar]
#2171296
10/10/16 02:07 AM
10/10/16 02:07 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I think some can't see the forest for the trees. To say "they figured all that out in the 70s" is a ludacris statement. You think nobody has learned anything in 40 years?
Modern stockers are over 1 second faster now that back then. Same parts such as heads intakes and carbs, yet the cars are way faster. The camshaft if the heart of any engine and what will make it run or be a turd. There is no current stocker record holder out there with a 70s grind camshaft in it. Will about bet the farm on that one.
The rod connects the piston to the crank, that's it. Doesn't matter in any other facet. People get WAY caught up in rod ratios and what's good and what's bad. Guys way smarter than me say it doesn't matter and I have found the same results.
People also do NOT understand the difference in intake centerline and lobe separation angle apparently. A 118 LSA cam installed at 116 does NOT always mean it is advanced. LSA is the intake centerline and exhaust centerline added and divided by two and is usually NOT the same as the intake centerline. Lots of big cams may have the intake ground on a 116 centerline and the exhaust ground on a 120 or wider centerline. That cam would have a 118 LSA but installed on 116 would make it straight up
As far as Don's deal, seems he told Scott before he ever tried it, that it wouldn't work. So he went into the experiment thinking it wouldn't work, so how much effort did he put into making the cam work. Did he do any carb changes, timing changes, maybe a converter? Just because you swap to this cam from another and the car slows early, doesn't mean the cam is wrong, just that it didn't like the current parts arrangement.
As AL has tried to point out, there is no magic PART........its the combination of ALL the parts and making them work right
[Re: Monte_Smith]
#2171410
10/10/16 12:25 PM
10/10/16 12:25 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
As AL has tried to point out, there is no magic PART........its the combination of ALL the parts and making them work right He knew I wasn't going to change anything in the combo. It was already sorted out Monte. Your right, I didn't think it would help. That doesn't mean I wasn't willing( in spite of that thought) to tear off the front of the motor and install it and give it a shot. It was at that time a heavy 3350 pound car with like 11.8 compression. It just wouldn't run as good. And yes, I did tinker with timing and such, trying to get the ET slip better. It isn't the first time I have tried something that didn't work. I suspect with a good bit more compression and convertor it might have worked better. But it didn't have that. I had what I had. And frankly saying it ran only a tenth off was being nice about it. You missed a key point I made. He said it would run better with what I had, not if I changed everything around. It didn't.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: 451Mopar]
#2172047
10/11/16 11:48 AM
10/11/16 11:48 AM
Posts: 4,219 New York
polyspheric
New York
Must be why they use those short rods in Formula 1...
Boffin Emeritus
[Re: polyspheric]
#2172273
10/11/16 04:53 PM
10/11/16 04:53 PM
Posts: 4,457 Washington
madscientist
Washington
Must be why they use those short rods in Formula 1... The length of the rod is only part of the equation. If you have a 4 inch long rod and a 2 inch stroke, you still have a 2:1 rod/stroke ratio.
[Re: madscientist]
#2172407
10/11/16 08:24 PM
10/11/16 08:24 PM
polyspheric
New York
Glad you pointed that out, I've forgotten it so frequently since first encountered... in 1964. Let me guess: wheels are round, and water is wet? Or must I use the <sarc> tag?
Boffin Emeritus
[Re: polyspheric]
#2172428
10/11/16 08:48 PM
10/11/16 08:48 PM
madscientist
Washington
Glad you pointed that out, I've forgotten it so frequently since first encountered... in 1964. Let me guess: wheels are round, and water is wet? Or must I use the <sarc> tag? Then say it correctly. There is no such thing as a long rod, long tube headers and the like.
[Re: 451Mopar]
#2172764
10/12/16 10:55 AM
10/12/16 10:55 AM
polyspheric
New York
You keep tripping over your ego. By "correctly", you mean "agree with you"?
Boffin Emeritus
[Re: Monte_Smith]
#2173247
10/12/16 11:21 PM
10/12/16 11:21 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Sorry to say, but you must include yourself, in not understanding LSA vs ICL. A cams Exhaust and Intake centerline will Always Match the LSA angle in number When Centered equally or "Straight up" at piston TDC between the exhaust and intake cycle. It will only alter, when moved from that position, centered straight up position. 0 Degrees advanced or retarded. Straight up. Centered. Equal split left or right, dead center between the two lobes exhaust and intake when the piston is at TDC. Its from this centered Reference point 0, that the cam can be measured advanced or retarded in relation to the crank, regardless of the LSA number. Lots of people still feel straight up is when the dots are lined up, as did I at one time. But the true meaning is as I have described. Its a simple mechanical event, then measured from there. But not simply understood. Also the term "Straight up" doesn't accurately describe the cams lobes actual position on measured cylinder. Lobes are actually pointing down away from said cylinder but equally in both cam degrees and crank degrees. But its a Visual left and right of a centered cams lobes in a graph showing a equal split in degrees for a better understanding. Also a term just to describe 0 Advance and 0 Retard, of the exhaust and intake lobes Equally split in both Cam degrees and Crankshaft degrees at piston TDC as described above.
