Re: BB hydraulic valve lifter preload with stock valve train [Re: JimG] #2170292
10/08/16 02:09 PM
10/08/16 02:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you would have ordered the adjustable ones, they would probably be in your hands on Monday, and since they are adjustable you could have exactly the same preload on all lifters regardless of tip height variations.
Fwiw, what you're seeing for tip height variation is no more(and probably less) than what you would find on a set of original new heads. They really werent all that close from the factory.
Re: BB hydraulic valve lifter preload with stock valve train [Re: JimG] #2170307
10/08/16 02:27 PM
10/08/16 02:27 PM
I would order pushrods that set your tightest one at .020-.030 preload (do some checking on the perfect dimention you should have) then some will be more than that (not the end of the world) but none will be less. you can check your ruler on a pane of glass & with a small square pane of glass you might even be able to use it as a flat check on 4 stems at a time. when checking preload I put a pair of lobes on base circle then ink the side of my small steel scale ruler & set it flat on the head valve cover mounting rails & ink a spot of it with a sharpie then slide it over fast till it contacts the side of the pushrod & transfers an ink mark then I repeat on the other side for the other pushrod then I undo the rocker arm assys till the pushrods JUST stop moveing up vertical & repeat the inking then remove the rocker arm assys & remove the pushrod inked pair & measure the distance between the two ink marks for my exact preload.
