Re: South Feorgia Motorsport Park
[Re: caper]
#2170065
10/08/16 01:48 AM
10/08/16 01:48 AM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
He ( Marty Robertson) was 4 cars from the starting line when the Mustang crashed. It started to rain a bit so they canceled qualifying. They made many changes in the last while. They are now running a screw blower. They had problems with dropped valves and other minor problems. The guys working on the car seemed to be very knowledgeable people.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: caper]
#2170115
10/08/16 05:30 AM
10/08/16 05:30 AM
Posts: 10,050 MN
JERICOGTX
MN
20 cars running in the 3's at 190+ on a drag radial... Simply amazing.
69 GTX
68 Road Runner
[Re: Roughbird72]
#2170256
10/08/16 01:25 PM
10/08/16 01:25 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Marty's out. Car banged up, but he's ok. That looks very expensive. Glad he is ok
[Re: Roughbird72]
#2170259
10/08/16 01:26 PM
10/08/16 01:26 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Marty's out. Car banged up, but he's ok. Man that stinks, very expensive weekend for them hurting a motor and then hurting the car. Hopefully they get it fixed quickly.
[Re: caper]
#2170535
10/08/16 08:42 PM
10/08/16 08:42 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That thing had either an ignition or injector problem every pass it made that I saw. Sucks bad because that car made some clean passes with the other combo.
Mopar to the bone!!!
[Re: caper]
#2170574
10/08/16 09:46 PM
10/08/16 09:46 PM
caper
He blew the blower off again, cutting a fuel line spilling fuel all over the track. Marty is alright, he burnt his forehead a little bit. He says it is not as bad as it looks and he will ready to go in February.
[Re: caper]
#2170602
10/08/16 10:24 PM
10/08/16 10:24 PM
caper
Goss puked oil on the track just off the line. I went by his pit afterwards and it seemed they were working around the transmission.
Josh (Dart) he ran a 5.00, sounds good just not performing well yet.
