Re: Just got towed home.( UPDATE)
[Re: chicagotim2003]
#216690
02/09/09 08:01 AM
02/09/09 08:01 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Beautiful day here in chicago.I started my car, let it idle for 15 minutes then took a 1 mile drive to the gas station.I filled up, drove about a block to a stop sign and the car died.Still had a strong cranking battery but no start.I`m thinking no spark.What would u try first? UPDATE!!!!!!!!UPDATE!!!!!!!!!! This morning i go to the garage.First thing i do is put the battery charger on ,it was run down from trying to start.I check to see if i have power on the ballast and coil both are good.My next move was going to check for spark.As i was about to check for spark the battery became charged so i figured i would just try to turn it over.Boom it fires up and roars like a lion.I let it idle about 10 minutes turned it off and restarted it about 5 times.Seems to be running great.?? I don`t know what to think.
How old is the coil? It could be bad
