Re: Launch critique
[Re: MoParFish]
#2165045
09/30/16 12:19 PM
09/30/16 12:19 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
[quote=MoParFish] Launch critique??...I'd say you tree'd me with a red light... Sorry Mike, couldn't resist Funny, thats the next thread, how to slow down my reaction
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Launch critique
[Re: mikeysmopars]
#2165111
09/30/16 02:09 PM
09/30/16 02:09 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Towards the end it was getting better but even having the chip at 3000 would blow the tires on the hit. NO, it didn't. I don't even have to see it to know that is not even remotely possible. Your car will NOT blow the tire off at the hit. Now it might shortly after because it is crushing the tire, or topping the front and THEN spinning. But it is NOT doing it at the hit of the throttle. The reason I asked about the "chatter" was to see if you described it as a shake. Tire shake is caused by too much bite and or not enough wheel speed
Re: Launch critique
[Re: Monte_Smith]
#2165150
09/30/16 03:08 PM
09/30/16 03:08 PM
mikeysmopars
fresno ca
Towards the end it was getting better but even having the chip at 3000 would blow the tires on the hit. NO, it didn't. I don't even have to see it to know that is not even remotely possible. Your car will NOT blow the tire off at the hit. Now it might shortly after because it is crushing the tire, or topping the front and THEN spinning. But it is NOT doing it at the hit of the throttle. The reason I asked about the "chatter" was to see if you described it as a shake. Tire shake is caused by too much bite and or not enough wheel speed The video was with it footbraking, I didn't have a vid, with the transbrake launch. Transbrake 60 foot was 1.51 and spun instantly, I only have one hit with the brake so far. As Al Mentioned I need to sort the issues using the brake I just havn't because its not hooking just footbraking.
Re: Launch critique
[Re: mikeysmopars]
#2165159
09/30/16 03:27 PM
09/30/16 03:27 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
You need to quick footbracking the car and start working on how to get it happy on the brake. C/Gas being a .400 Pro Tree deal will require you to run it on the brake. So quit trying to get it to work footbraking. Just putting laps on the motor and making no progress.
As Monte pointed out I highly doubt it is blowing them off at the hit. Likely just after that when the suspension is being upset. Those front shocks have VERY little front travel,nature of the beast. Having said that you should be able to get them to work but they do likely only have 3" or so of travel is my guess. Applying power to get the wheelspeed up will help with the shake and pitch rotation most likely. Also don't be afraid to go DOWN with the tire pressure.
Re: Launch critique
[Re: Al_Alguire]
#2167808
10/04/16 04:37 PM
10/04/16 04:37 PM
mikeysmopars
fresno ca
We car is SCSN, or Street Car, or Streetcar Supernationals Man I wish I could do that race, Don't have the vacation time and cant afford the trip right now Mike Cunningham will be there to win the non E "again" and wish I could at least go to support him and watch. have try to do something local. Good luck AL!!, I will be at least watching you guys on Bangshift!
Re: Launch critique
[Re: mikeysmopars]
#2167825
10/04/16 04:56 PM
10/04/16 04:56 PM
Al_Alguire
Las Vegas
We actually will not be running there this year at all. Well maybe the dragster but not sure honestly.
Re: Launch critique
[Re: racerx]
#2168319
10/05/16 01:01 PM
10/05/16 01:01 PM
mikeysmopars
fresno ca
for this, didn't want it to fall off, any up to date news on this. waiting for springs, I'm looking for a TNT close to me before November, There's a Chevy race on the schedule that has an open lane, Might put a Nova badge on it & jump in their party. I get this thing to hook in good air it should get me in the low 50's or better So what spring did you decide on? I believe you had the 250 on the front correct? Or were you changing the rear? Ordered 200 lb fronts and 110 rears, going to change the fronts at home and set ride height and that's the only change I want to do for the first hits. If it hooks i'll leave it. if not i'll change the rears at the track.
Re: Launch critique
[Re: mikeysmopars]
#2168385
10/05/16 02:33 PM
10/05/16 02:33 PM
Al_Alguire
Las Vegas
There is a race in Fontana next weekend. Free test and tune on Friday. A few Moparts members are usually there. NMCA West race, track prep is usually good as long as it is not 100+ degrees should be good. Plenty of classes and lots of opportunities to put laps on a car. Many of the bracket guys double dip at least.
Re: Launch critique
[Re: mikeysmopars]
#2168389
10/05/16 02:35 PM
10/05/16 02:35 PM
Al_Alguire
Las Vegas
Don't assume that changing front spring rate is gonna be the magic ticket. IMO some good video would help a lot. No reason you cannot get it to work but might need some more changes. Don't forget the converter as part of this package, you might need more stall speed to take some of the aggressiveness away at the hit....
Re: Launch critique
[Re: Al_Alguire]
#2168450
10/05/16 04:26 PM
10/05/16 04:26 PM
mikeysmopars
fresno ca
Don't assume that changing front spring rate is gonna be the magic ticket. IMO some good video would help a lot. No reason you cannot get it to work but might need some more changes. Don't forget the converter as part of this package, you might need more stall speed to take some of the aggressiveness away at the hit.... Noted Al, I had the converter adjusted with the Dyno sheet by A-1 which Is what my converter is, Jason recommended them and they adjusted it from 5600 to 6300 per dyno sheet. do you think its still too tight? I need to give the springs a try, cheep enough test.
Re: Launch critique
[Re: mikeysmopars]
#2168716
10/05/16 11:27 PM
10/05/16 11:27 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
AHHHHH... so not only did we "increase" HP, change the front suspension, we did a huge converter change. .... the rest, of the story. personally I'd love to see what would have happened leaving the converter "as is".
Re: Launch critique
[Re: J_BODY]
#2168771
10/06/16 01:15 AM
10/06/16 01:15 AM
mikeysmopars
fresno ca
AHHHHH... so not only did we "increase" HP, change the front suspension, we did a huge converter change. .... the rest, of the story. personally I'd love to see what would have happened leaving the converter "as is". I mentioned that somewhere deep in page one J. Thats next on my agenda, to call A-1
