Re: Qa1 k member [Re: 1fastaspen] #2165551
10/01/16 12:43 AM
10/01/16 12:43 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The three friend that have caps all had problems. Only one got it fixed and still uses front end, the other two gave up on it and replaced them with another brand. That is my experience with them.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Qa1 k member [Re: turbo toad] #2165554
10/01/16 12:46 AM
10/01/16 12:46 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By turbo toad
Originally Posted By Cab_Burge
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient shruggy
Maybe he will see this post and chip in on his thoughts and results on his luck
I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it shruggy
Cab I had a chance to look Mopar Billys car over this year at drag week and He did mention that the K member he was running came from you. If you every get aline on another please keep me in mind Id like to put one on in my Valiant. up
STR makes a nice one for early a bodies. There is one in Brett's 66 Dart that goes 8.90s. Very reasonably priced.
Re: Qa1 k member [Re: B3422W5] #2165565
10/01/16 12:57 AM
10/01/16 12:57 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
They do suck ask One Bad Fish and the twenty hours of working on it to find out IT WOULD'VE NEVER WORK without the new parts Ray had to send him.
I have one in my dart and that sucked also.
Re: Qa1 k member [Re: 1fastaspen] #2165698
10/01/16 10:23 AM
10/01/16 10:23 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Buy Bobs Profab and be done with it or talk to 67dart gt about his friends kit i here is also very nice
Re: Qa1 k member [Re: 1967dartgt] #2165833
10/01/16 01:22 PM
10/01/16 01:22 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
STR makes a nice one for early a bodies. There is one in Brett's 66 Dart that goes 8.90s. Very reasonably priced.[/quote]
Thanks Ill have to look into it.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Qa1 k member [Re: 1fastaspen] #2165877
10/01/16 02:07 PM
10/01/16 02:07 PM
K
Kiddart Offline
Kiddart  Offline
K
anyone have a link to str??
Thank you
Kiddart
Re: Qa1 k member [Re: 1fastaspen] #2165884
10/01/16 02:12 PM
10/01/16 02:12 PM
K
KOS Offline
KOS  Offline
K
good luck getting one (STR) .....i spoke with Tory last year he was in the middle of a move i said np i can wait a couple months....well i waited forever tried contacting him several times never returned calls or emails even tried calling him a month ago and nothing.to bad i was in the market to buy two of them.
Re: Qa1 k member [Re: 1fastaspen] #2165894
10/01/16 02:23 PM
10/01/16 02:23 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Did you try Bobs Pro Fab
Re: Qa1 k member [Re: B3422W5] #2166333
10/02/16 10:10 AM
10/02/16 10:10 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By B3422W5
Originally Posted By 1967dartgt
Stay away, they bought that design from caps. No one has had any good luck with caps.
I know several guys running them for years with zero issues. Shouldn't bad mouth them, saying nobody likes them. It's flat not true
I guess I should have said no one I know. If you want to get more in to it, my one friend bought it about 6 months before Ray sold out. He would return his phone calls till he had problems with the system, then no returned calls.
Re: Qa1 k member [Re: 1fastaspen] #2166391
10/02/16 12:39 PM
10/02/16 12:39 PM
Ohio
lockjaw-express Offline
Ohio
I got the Alterkation front end because it would get rid of the torsion bars, and the rack would clear my TTI 2 1/4" headers, and the steering link under the oil pan. Along with clearing almost any deep pan. The pan just has to have a small front notch, and that's it.
My cousin has one on his e-body challenger, and it drives like it is on rails.
The QA1 front kit is a lot less money, though...
Regards, Mark
Re: Qa1 k member [Re: 1fastaspen] #2166452
10/02/16 02:27 PM
10/02/16 02:27 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I love Tory's front end. Love it!
Re: Qa1 k member [Re: sixpackgut] #2166514
10/02/16 04:09 PM
10/02/16 04:09 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Love mine too, and customer service is top notch...
Re: Qa1 k member [Re: 1967dartgt] #2166672
10/02/16 08:57 PM
10/02/16 08:57 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
We made our own K member.. virtually no camber or toe change through the range of motion..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Qa1 k member [Re: WHITEDART] #2166744
10/02/16 11:21 PM
10/02/16 11:21 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I would say acceptable(way less than stock) camber and toe change. It looks a lot like the one on the Dart behind you.
"Just a Bracket car dressed up like a streetcar"
Re: Qa1 k member [Re: 1fastaspen] #2166774
10/02/16 11:55 PM
10/02/16 11:55 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The OP asked about QA1. Some of you are talking about QA1 and CAP as if they are one and the same. I don't think that's fair to QA1. I was over there at a plant tour when they were developing the QA1 K frame. I don't know whether they bought CAPs design or not, but whatever they did, they put their own design engineers on it. Judge it based on QA1 reveiws, not CAP reveiws.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Qa1 k member [Re: 1fastaspen] #2166820
10/03/16 01:17 AM
10/03/16 01:17 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I have both of them...take the decal off the qa1 and you wont know the difference...but I think the qa1 has mounts for the sway bar...
Tony
70 AARCuda Vitamin C
Re: Qa1 k member [Re: 1fastaspen] #2166862
10/03/16 02:28 AM
10/03/16 02:28 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
A local racer put one on his Duster. He still uses the torsion bars but added QA1 uppers, lowers, k frame and strut bars. I talked w/him about the set up, how it handles any problems w/installation or alignment. He said it installed w/o any issues and the alignment was perfect and drives down the track great. His actual words were " the car handles better than it ever has "
Ok
Re: Qa1 k member [Re: cudatom] #2166883
10/03/16 04:48 AM
10/03/16 04:48 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
i love my qa1 k and lowers..i have full hotchkis tvs with qa1 k and lowers...
https://www.youtube.com/watch?v=Y1zmXWlS3Bk
https://www.youtube.com/watch?v=bdVNdGmKZG8
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Qa1 k member [Re: Just-a-dart] #2166894
10/03/16 08:37 AM
10/03/16 08:37 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
However lack of camber gain is often thought to be a downside. Unequal length arms is the intentional method used to achieve that gain, taking it away is seldom a goal.
Re: Qa1 k member [Re: Hemi_Joel] #2167339
10/03/16 10:08 PM
10/03/16 10:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
QA-1 did buy Cap Automotive several years ago, did they change the general design no did they do some refinements I would say yes because of the previous comment about sway bar mounts,,I have everything that Cap built on my car with the exception of the K member,I just wish QA-1 would make one with a rack and pinion mount so I can trash can the stock steering box and still be able to use everything that I have now and not have to re-buy every thing.
