Re: Qa1 k member
[Re: 1fastaspen]
#2165551
10/01/16 12:43 AM
10/01/16 12:43 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
The three friend that have caps all had problems. Only one got it fixed and still uses front end, the other two gave up on it and replaced them with another brand. That is my experience with them.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Qa1 k member
[Re: turbo toad]
#2165554
10/01/16 12:46 AM
10/01/16 12:46 AM
1967dartgt
Hilltown Pa
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Maybe he will see this post and chip in on his thoughts and results on his ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Cab I had a chance to look Mopar Billys car over this year at drag week and He did mention that the K member he was running came from you. If you every get aline on another please keep me in mind Id like to put one on in my Valiant. STR makes a nice one for early a bodies. There is one in Brett's 66 Dart that goes 8.90s. Very reasonably priced.
Re: Qa1 k member
[Re: 1967dartgt]
#2165833
10/01/16 01:22 PM
10/01/16 01:22 PM
Posts: 368 michigan
turbo toad
michigan
STR makes a nice one for early a bodies. There is one in Brett's 66 Dart that goes 8.90s. Very reasonably priced.[/quote]
Thanks Ill have to look into it.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Qa1 k member
[Re: 1fastaspen]
#2165877
10/01/16 02:07 PM
10/01/16 02:07 PM
Posts: 1,560 Michigan
Kiddart
anyone have a link to str??
Thank you Kiddart
Re: Qa1 k member
[Re: 1fastaspen]
#2165884
10/01/16 02:12 PM
10/01/16 02:12 PM
KOS
good luck getting one (STR) .....i spoke with Tory last year he was in the middle of a move i said np i can wait a couple months....well i waited forever tried contacting him several times never returned calls or emails even tried calling him a month ago and nothing.to bad i was in the market to buy two of them.
Re: Qa1 k member
[Re: B3422W5]
#2166333
10/02/16 10:10 AM
10/02/16 10:10 AM
1967dartgt
Hilltown Pa
Stay away, they bought that design from caps. No one has had any good luck with caps. I know several guys running them for years with zero issues. Shouldn't bad mouth them, saying nobody likes them. It's flat not true I guess I should have said no one I know. If you want to get more in to it, my one friend bought it about 6 months before Ray sold out. He would return his phone calls till he had problems with the system, then no returned calls.
Re: Qa1 k member
[Re: 1fastaspen]
#2166452
10/02/16 02:27 PM
10/02/16 02:27 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I love Tory's front end. Love it!
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Qa1 k member
[Re: sixpackgut]
#2166514
10/02/16 04:09 PM
10/02/16 04:09 PM
1967dartgt
Hilltown Pa
I love Tory's front end. Love it! Love mine too, and customer service is top notch...
Re: Qa1 k member
[Re: 1967dartgt]
#2166672
10/02/16 08:57 PM
10/02/16 08:57 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
We made our own K member.. virtually no camber or toe change through the range of motion..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Qa1 k member
[Re: WHITEDART]
#2166744
10/02/16 11:21 PM
10/02/16 11:21 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
We made our own K member.. virtually no camber or toe change through the range of motion.. I would say acceptable(way less than stock) camber and toe change. It looks a lot like the one on the Dart behind you.
"Just a Bracket car dressed up like a streetcar"
Re: Qa1 k member
[Re: 1fastaspen]
#2166774
10/02/16 11:55 PM
10/02/16 11:55 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
The OP asked about QA1. Some of you are talking about QA1 and CAP as if they are one and the same. I don't think that's fair to QA1. I was over there at a plant tour when they were developing the QA1 K frame. I don't know whether they bought CAPs design or not, but whatever they did, they put their own design engineers on it. Judge it based on QA1 reveiws, not CAP reveiws.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Qa1 k member
[Re: 1fastaspen]
#2166820
10/03/16 01:17 AM
10/03/16 01:17 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
I have both of them...take the decal off the qa1 and you wont know the difference...but I think the qa1 has mounts for the sway bar...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Qa1 k member
[Re: 1fastaspen]
#2166862
10/03/16 02:28 AM
10/03/16 02:28 AM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
A local racer put one on his Duster. He still uses the torsion bars but added QA1 uppers, lowers, k frame and strut bars. I talked w/him about the set up, how it handles any problems w/installation or alignment. He said it installed w/o any issues and the alignment was perfect and drives down the track great. His actual words were " the car handles better than it ever has "
Ok
Re: Qa1 k member
[Re: Just-a-dart]
#2166894
10/03/16 08:37 AM
10/03/16 08:37 AM
Posts: 22,782 Bitopia
jcc
Bitopia
We made our own K member.. virtually no camber or toe change through the range of motion.. I would say acceptable(way less than stock) camber and toe change. It looks a lot like the one on the Dart behind you. However lack of camber gain is often thought to be a downside. Unequal length arms is the intentional method used to achieve that gain, taking it away is seldom a goal.
Re: Qa1 k member
[Re: Hemi_Joel]
#2167339
10/03/16 10:08 PM
10/03/16 10:08 PM
dartman366
Mt. Vernon, Ohio
The OP asked about QA1. Some of you are talking about QA1 and CAP as if they are one and the same. I don't think that's fair to QA1. I was over there at a plant tour when they were developing the QA1 K frame. I don't know whether they bought CAPs design or not, but whatever they did, they put their own design engineers on it. Judge it based on QA1 reveiws, not CAP reveiws. QA-1 did buy Cap Automotive several years ago, did they change the general design no did they do some refinements I would say yes because of the previous comment about sway bar mounts,,I have everything that Cap built on my car with the exception of the K member,I just wish QA-1 would make one with a rack and pinion mount so I can trash can the stock steering box and still be able to use everything that I have now and not have to re-buy every thing.
