Re: D100 Charging Woes
[Re: elmor353]
#2171204
10/09/16 11:26 PM
10/09/16 11:26 PM
Andrewh
both of the field wires should not have read 12.6 volts with the car on. one of them should have read lower. was that not the case?
[Re: Dave Hall]
#2171575
10/10/16 05:24 PM
10/10/16 05:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I say keep it simple. 9 times out of 10 if my car is not charging I simply replace the POS alternator and done. Did you miss this statement in the first post? A replacement alternator was only $25 so I replaced it. Same problem.
[Re: elmor353]
#2171691
10/10/16 09:23 PM
10/10/16 09:23 PM
Posts: 5,996 ohio
ruderunner
ohio
Speaking of grounds, is this the finned case alternator or the heavy duty one with rubber bushings?
If its the bushing style, THERRE MMUST BE a GROUND WIRE FROM THE CASE TO BLOCK.
Angry white pureblood male
[Re: elmor353]
#2171966
10/11/16 07:45 AM
10/11/16 07:45 AM
Posts: 5,996 ohio
ruderunner
ohio
OK wanted to be clear on which alternator you had.
Sounds like a dead alternator at this point.
[Re: elmor353]
#2172615
10/12/16 12:48 AM
10/12/16 12:48 AM
RapidRobert
(1) key off, no voltage at either alt field terminal & none also at reg blue/green terminals. (2) key on, voltage at alt blue wire field terminal and reg blue wire terminal and some at green wire terminal at other alt field and reg green wire terminal. (3) reg triangle connector is tight (4) reg is grounded (5) continuity between alt large "batt" terminal and battery positive post (6) continuity between alt case and battery neg post. (7) good alt and reg. redundant on some & I'm thinking we're covered most or all of these but if all are good then it MUST charge so we've missed something. Short version: we'll assume alt/reg are good & reg is grounded & alt case has continuity to batt neg post. all that is left is (A) does alt batt terminal have continuity to battery positive post & (B) are the blue wire terminals at alt/reg hot with key on and (C) does the green wire have continuity between the other alt field terminal and the "side" reg terminal.
