Re: Can some one do some math for me??????
[Re: madscientist]
#2165056
09/30/16 12:39 PM
09/30/16 12:39 PM
Posts: 5,168 CT
GTX MATT
CT
I get 10.65. 3.43 is what I came up with for your valve reliefs. I think you're getting different results based off what people are calculating for that. 110 CC is 6.71261 CI. The volume of your bore with the piston 1/2 inch down should be 6.50332 CI. The difference of 0.20929 converts back to 3.43 CC for the valve reliefs. This is a flat top piston I assume? Aren't you the madscientist? I thought you would have been good at math too
[Re: madscientist]
#2165072
09/30/16 01:08 PM
09/30/16 01:08 PM
fast68plymouth
So. Burlington, Vt.
I think along with the rounding errors, depending on how far out you take it after the decimal, is how far out you take pi.
I used: 708.2 swept 12.2 gasket 67.0 head 3.35 piston -9.4 deck height ----------- 781.35 total 73.15 total minus swept ----------- 10.68 (781.35/73.15)
Depending on the ring down placement and the actual piston diameter above the ring, there's going to be another 1-1.5cc there, so in reality it's more like 10.5-10.55:1.
[Re: GTX MATT]
#2165088
09/30/16 01:22 PM
09/30/16 01:22 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
I get 10.65. 3.43 is what I came up with for your valve reliefs. I think you're getting different results based off what people are calculating for that. 110 CC is 6.71261 CI. The volume of your bore with the piston 1/2 inch down should be 6.50332 CI. The difference of 0.20929 converts back to 3.43 CC for the valve reliefs. This is a flat top piston I assume? Aren't you the madscientist? I thought you would have been good at math too I ASSumed the 3.32cc valve relief to be correct, however I even got a different result from yours when I calculate the volumes. Pi*R squared*.500= 106.62cc 110cc-106.62cc=3.38cc making the Comp ratio 10.658:1 But yes, I would expect a scientist to be stellar at math as well
[Re: madscientist]
#2165202
09/30/16 05:21 PM
09/30/16 05:21 PM
Posts: 4,213 New York
polyspheric
New York
WRT "the actual piston diameter above the ring"
That's included in the fill volume, but not in the deck height, because it assumes the dome is actual bore size - which is never true.
Boffin Emeritus
[Re: fast68plymouth]
#2165379
09/30/16 08:43 PM
09/30/16 08:43 PM
Posts: 4,457 Washington
madscientist
Washington
Depending on the ring down placement and the actual piston diameter above the ring, there's going to be another 1-1.5cc there, so in reality it's more like 10.5-10.55:1. How are you getting 73.15 for a chamber volume? I get 67 for the chamber, 12.2 for the gasket and approximately 3.5 for the DISH that I am measuring. That would be: 67 12.2 3.5 for a total of 82.7 With a swept volume of 706.3 plus the chamber volume of 82.7 is 789 divided by 82.7 is 9.54 I can do math. Its just this one is pissing me way off. Its simple math but we are all getting different numbers. Im losing the last bit of my mind thats left.
[Re: madscientist]
#2165442
09/30/16 10:25 PM
09/30/16 10:25 PM
Posts: 561 USA
B3RE
USA
Depending on the ring down placement and the actual piston diameter above the ring, there's going to be another 1-1.5cc there, so in reality it's more like 10.5-10.55:1. How are you getting 73.15 for a chamber volume? I get 67 for the chamber, 12.2 for the gasket and approximately 3.5 for the DISH that I am measuring. That would be: 67 12.2 3.5 for a total of 82.7 With a swept volume of 706.3 plus the chamber volume of 82.7 is 789 divided by 82.7 is 9.54 I can do math. Its just this one is pissing me way off. Its simple math but we are all getting different numbers. Im losing the last bit of my mind thats left. Tim, the 10.65 is a good number. You are forgetting that the positive deck is reducing your chamber volume.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: madscientist]
#2165443
09/30/16 10:25 PM
09/30/16 10:25 PM
fast68plymouth
So. Burlington, Vt.
How are you getting 73.15 for a chamber volume? It doesn't say that's the chamber volume....... It's the total volume minus the swept volume.
[Re: madscientist]
#2167353
10/03/16 10:18 PM
10/03/16 10:18 PM
madscientist
Washington
SPECIAL THANKS to Mike at B3 racing engines. I called him on the phone and he held my hand and walked me through my math mistake.
Porter has his numbers correct. Later tonight I will re-calculate the CR on this project out to the 3rd digit and then I'll be good to go.
It will be close to 10.5:1 or so.
Gotta remember to calculate the flat that comes out of the bore. That's where DP got the extra 9 cc's that I was missing.
Thanks to all that posted and especially Mike.
[Re: madscientist]
#2167473
10/04/16 01:17 AM
10/04/16 01:17 AM
BradH
SPECIAL THANKS to Mike at B3 racing engines. I called him on the phone and he held my hand and walked me through my math mistake. What do you do for a living?
[Re: BradH]
#2167792
10/04/16 04:10 PM
10/04/16 04:10 PM
madscientist
Washington
SPECIAL THANKS to Mike at B3 racing engines. I called him on the phone and he held my hand and walked me through my math mistake. What do you do for a living? Retired machinist, weldor and gunsmith. I still do some of all of it when I want to or need to.
[Re: Thumperdart]
#2167975
10/04/16 08:10 PM
10/04/16 08:10 PM
madscientist
Washington
Fix that carb yet............ Sheeeeeeeeiiiiiiiiitt!!! I'm slow as hell. It runs but don't drive yet. Front shocks will be here late this week. I'll get it lined up next week. What a PITA.
