Website with ethanol-free gasoline in the U.S. and Canada
#2163258
09/27/16 11:44 PM
09/27/16 11:44 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I know a lot of boaters love this stuff but I know some car guys that love it too. http://pure-gas.org/
Re: Website with ethanol-free gasoline in the U.S. and Canada
[Re: pittsburghracer]
#2163335
09/28/16 01:03 AM
09/28/16 01:03 AM
Posts: 11,649 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I wish there was a station close. E10 is a costly scam, and it's awful in anything with a carb. Death to motorcycles, power equipment, etc. I've had to work on the carb on everything I own to make it run right.
[Re: CMcAllister]
#2163362
09/28/16 01:30 AM
09/28/16 01:30 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wish there was a station close. E10 is a costly scam, and it's awful in anything with a carb. Death to motorcycles, power equipment, etc. I've had to work on the carb on everything I own to make it run right. I have had real good luck adding SeaFoam to my lawn equipment and even in my gas tank in my motorhome when I plan on running the Onan generator and during Winter storage. I'm lucky when I do want the ethonol free as I have a station about 7 miles from my house in a direction I go often.
#2163383
09/28/16 01:58 AM
09/28/16 01:58 AM
Posts: 4,694 Wichita
GY3
Wichita
The '63 Dodge, minibike and all lawn equipment get 91 octane no Ethanol from a local Casey's. I have to drive a few miles but it's worth it!
[Re: DaytonaTurbo]
#2163577
09/28/16 12:07 PM
09/28/16 12:07 PM
GY3
Wichita
I run the E10 garbage in all my junk, small engines included. No problems. I have never found seafoam to do anything. My push mower was having all sorts of issues. Switched to no Ethanol and problems went away. It seemed to have more power too. I noticed the accelerator pump diaphragm's having issues on both vehicles with 3310 750 Holly's. No issues after switching.
#2163711
09/28/16 03:36 PM
09/28/16 03:36 PM
Posts: 1,237 North Central, Indiana
Roughbird72
In my area, CountryMark carries ethanol free gasoline and marinas are always a good source.
72 Plymouth Roadrunner 11.08@123.25
[Re: AndyF]
#2163758
09/28/16 04:52 PM
09/28/16 04:52 PM
GY3
Wichita
Wow, I feel fortunate in that 91 No Ethanol here was only $2.49 a gallon this morning!
It sounds like some of you are paying a LOT more.
[Re: GY3]
#2163832
09/28/16 06:58 PM
09/28/16 06:58 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Just learned of the availability of it this summer. Now its in all of my recreational stuff and more. Mowers, golf carts, golf carts at camp, chain saws etc.
I'm fortunate to live within a few miles of the Marathon refinery here in canton that distributes it here and more. Have three stations nearby, and from the looks of the Station map on pittsburgs link, its all over the place. That will continue to grow, as the ethanol is a carb clogger for sure after a given amount of time.
Was getting it for 2.99 a gallon, with Pittsburgs link I see another station closer to marathon witch may be even cheaper.
[Re: CMcAllister]
#2163849
09/28/16 07:22 PM
09/28/16 07:22 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
E10 made my radiator plug up, makes my radio sound funny and caused my headlights to burn out! I hate that stuff! A little more seriously, small engine fuel systems are vented to the atmosphere and modern fuels have a short shelf life. For any small engines I drain the fuel if it isn't going to be used for a an extended period (and burn it in the truck). They always start and run fine on FRESH pump gas of any type. If there's ANY water in the bottom of your tank the Ethanol will blend with it and make it more available to the pickup. Without the ethanol water can sit at the bottom of your gas tank for years and years. The E** can make the engine run a little leaner but small engines often have little fuel trim screws to adjust that anyway. I've never had a problem.
#2164830
09/30/16 12:30 AM
09/30/16 12:30 AM
Posts: 641 Monroe NC
Luvcars69
Monroe NC
Wow have non ethonal 93 at a station 10 miles from the house in South Carolina $2.44/gal yesterday.
Making cars faster one at a time!
19 Challenger Scat Pack white 16 Ram Sport SB Regular cab black 14 Charger Pursuit silver 78 Magnum 400 gray 69 SuperBee 512 Passion 4-speed 4:10
#2164851
09/30/16 01:04 AM
09/30/16 01:04 AM
Superfreak
Superfreak
Two of the stations listed for BC, Canada are just down the road from me, one of which I go to all the time.
