Re: best carb for a 440 [Re: moparmatt0] #2163048
09/27/16 07:06 PM
09/27/16 07:06 PM
AndyF Offline
AndyF  Offline
Not sure what the lightest carb is that would still have decent performance. Thermoquad maybe? QJet is probably fairly light. Maybe need to do a weight vs. power shootout to pick the best carb for you.
Re: best carb for a 440 [Re: Thumperdart] #2163052
09/27/16 07:14 PM
09/27/16 07:14 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted By Thumperdart
I surely wouldn't recommend a carb based on weight and NOTHING including efi out performs a Holley carb in single and dual applications.........
I agree. 5 pounds is extremely unlikely to be seen on a time slip, and unimportant on a street strip or bracket car in the whole scheme of things. And that's if there is even a 5 pound difference.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: best carb for a 440 [Re: moparmatt0] #2168229
10/05/16 09:13 AM
10/05/16 09:13 AM
NY
moparmatt0 Offline OP
NY
Thanks for the help I found a 850 xp on ebay and I am going to try it Thanks again Matt.
Re: best carb for a 440 [Re: moparmatt0] #2168244
10/05/16 10:17 AM
10/05/16 10:17 AM
gregsdart Offline
gregsdart  Offline
One thing I have read is how well the fuel is atomized for various intake temperatures is very important? An X plain intake without heat may want very good atomization, a heated dual plain might suffer from it. The same might apply for the same intake, heat versus no heat in the intake regardless of manifold.
