Re: Trick Flow heads
[Re: Youngblood]
#2162721
09/27/16 12:22 PM
09/27/16 12:22 PM
Posts: 31,076 Oregon
AndyF
Andy, are you offering a valley plate for the trick flows at this time? I am starting a build and cannot stand the tin tray. Would like to order if you are, thanks. I have a couple of the solid plates on hand for low deck engines. I'll have RB plates in stock in a few weeks.
[Re: AndyF]
#2163282
09/28/16 12:08 AM
09/28/16 12:08 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
They are 500 cfm Edelbrock carbs. Part number 1804. They've worked pretty well in the past on cross rams or tunnel rams so I think they'll work well here too. Have you done any mods to them, beyond jets/metering rods?
[Re: fast68plymouth]
#2164101
09/29/16 01:23 AM
09/29/16 01:23 AM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Well,I've read this entire thread in bits over the last few days.Great to see this cylinder head available and nice to hear about the good quality as delivered.Thanks for all the input from everyone,builders,tuners,racers and others using the heads.And AndyF,nice to see you continuing to design parts to fit new products,nice stuff! Good read,RT
[Re: RTSrunner]
#2164733
09/29/16 10:28 PM
09/29/16 10:28 PM
dartman366
Mt. Vernon, Ohio
I am just now starting the assembly of my new Trick Flow headed 512 lo deck motor for my 76 dart drag car, I am taking picturs and documenting information as I go along and will one day post it all here and then give track results in the spring,,,,at least that's the plan. going to be a busy winter.
[Re: Cab_Burge]
#2164785
09/29/16 11:26 PM
09/29/16 11:26 PM
AndyF
Andy, any thoughts on using the Holley 1000 CFM annular carbs. yet to test with? Not even going to try to use those carbs. I looked them over and the jetting is so far off from stock I didn't want to touch them. Looks to me like maybe they were set up for Q16 or E80 or something like that. Did not appear to be a race gas tune. I just unbolted them and put them in a box for safekeeping. The engine ran great with these 500 cfm Edelbrock carbs. Every time I swap over from Holley carbs to Edelbrock carbs I'm amazed at how much smoother the engine runs. For an engine like this the dual Edelbrocks are probably tough to beat. If I had a pair of 600 Edelbrocks I'd try them but I doubt this engine would make any more power.
#2164793
09/29/16 11:35 PM
09/29/16 11:35 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Just a quick one Andy. Where would be the best place to buy a set of these heads ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2164805
09/29/16 11:53 PM
09/29/16 11:53 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just a quick one Andy. Where would be the best place to buy a set of these heads ? Probably with a 10% off coupon from Summit.
[Re: AndyF]
#2164939
09/30/16 04:33 AM
09/30/16 04:33 AM
Posts: 43,301 Bend,OR USA
Cab_Burge
Those carbs came off of Mike Swanns old PSCA heads up car, they where modded by some shop down south in SO CA, probally C&J engr. I had loaned one them out to a local bracket racer and I didn't think to check to see if they jet extensions on them, they didn't, and that made it bog off the line a tiny bit but it ran more MPH and quicker ET than his 950 HP did at Woodburn on back to back runs Mike didn't seem to like them back then due to the annular boosters according to him
[Re: ozymaxwedge]
#2164941
09/30/16 05:04 AM
09/30/16 05:04 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Just a quick one Andy. Where would be the best place to buy a set of these heads ? Al , you get a Summit pro shop discount with your ANDRA licence now . used to have to ring for a coupon number . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Harley]
#2170369
10/08/16 04:21 PM
10/08/16 04:21 PM
Skeptic
The Pale Blue Dot
Looks like they just opened up the intake ports, the exhaust #s are the same. Andy, do you have any head to head numbers on the combo? How much would this run in approx $. Thanks, Steve BTW the spring and retainers look great!
