Re: best carb for a 440
[Re: Thumperdart]
#2163052
09/27/16 07:14 PM
09/27/16 07:14 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I surely wouldn't recommend a carb based on weight and NOTHING including efi out performs a Holley carb in single and dual applications......... I agree. 5 pounds is extremely unlikely to be seen on a time slip, and unimportant on a street strip or bracket car in the whole scheme of things. And that's if there is even a 5 pound difference.
[Re: moparmatt0]
#2168244
10/05/16 10:17 AM
10/05/16 10:17 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
One thing I have read is how well the fuel is atomized for various intake temperatures is very important? An X plain intake without heat may want very good atomization, a heated dual plain might suffer from it. The same might apply for the same intake, heat versus no heat in the intake regardless of manifold.
