Motor alignment 72 duster
#2162143
09/26/16 05:04 PM
09/26/16 05:04 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I have a race car that uses motor and mid plates car did not come with them . I have new ones and a block and trans with cross member I want to mock up but where would you do your measurements/ take off from ??? I do have a 69 dart running v8 car would you say bottom of cross member to pan rail ? Thanks a lot guys mopar or no car. Ps this will be a small block was a big block car
Re: Motor alignment 72 duster
[Re: RAY1969CARS]
#2162147
09/26/16 05:19 PM
09/26/16 05:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Basically you will have to mock it up to see where the headers fit best.. both the side to side and the up and down locations.. along with fore and aft.. of course if you are using those headers EDIT looking at the mid plate location it was in there in a stock location fore and aft I just seen that was a BB and your going SM.. still mock it up... I think they were 1 3/8" to the pass side for center line
[Re: MR_P_BODY]
#2162153
09/26/16 05:23 PM
09/26/16 05:23 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Mike I would be using these hooker super comps and that big pan I Would think the pan would've been set up for stock location
[Re: RAY1969CARS]
#2162155
09/26/16 05:27 PM
09/26/16 05:27 PM
MR_P_BODY
I edited my post above EDIT I would move it rearward just so the dist clears and move it up some so it will transfer the weight easy
[Re: MR_P_BODY]
#2162162
09/26/16 05:33 PM
09/26/16 05:33 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I edited my post above True I would put trans cross member in and with trans and motor together get. Some measurements because both mid plate and motor plate need trimmed
[Re: AndyF]
#2162305
09/26/16 08:33 PM
09/26/16 08:33 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: squirrel]
#2162372
09/26/16 10:09 PM
09/26/16 10:09 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Use the trans mount as a reference.then go forward if you can
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2162393
09/26/16 10:34 PM
09/26/16 10:34 PM
dartman366
Mt. Vernon, Ohio
Use the trans mount as a reference.then go forward if you can thats what I did when I fitted my motor plate.
[Re: RAY1969CARS]
#2162429
09/26/16 11:06 PM
09/26/16 11:06 PM
MR_P_BODY
Yes I got that half its the up and down I think I'll put the pan on plus install center link And center it and go from there I think it's the most crucial ??? The way to do it is get the engine/trans pointed right at the pinion then roll the pinion down for for the pinion angle
[Re: MR_P_BODY]
#2162447
09/26/16 11:44 PM
09/26/16 11:44 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Yes I got that half its the up and down I think I'll put the pan on plus install center link And center it and go from there I think it's the most crucial ??? The way to do it is get the engine/trans pointed right at the pinion then roll the pinion down for for the pinion angle Thanks Mike she's going up on jackstands this weekend
[Re: WHITEDART]
#2162528
09/27/16 02:13 AM
09/27/16 02:13 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
[quote=WHITEDART]One key component is the engine limiter
limiter... ???? White dart
[Re: RAY1969CARS]
#2162531
09/27/16 02:18 AM
09/27/16 02:18 AM
WHITEDART
bean town ....Ca
limiter... ???? White dart very important on a motor plate mid plate setup how to use a engine limiter.. mine is off the trans.. if I remember I will snap a few pictures tomorrow.. or maybe someone can post a picture of theirs.. you may already have a provision welded to the frame somewhere
