Re: Brewer heads
[Re: 1baddart]
#2161451
09/25/16 04:23 PM
09/25/16 04:23 PM
fast68plymouth
So. Burlington, Vt.
Are they still readily available? Along with the other required parts..... Intakes, rocker gear, valve covers?
In the end, what kind of cost differences between those and some high effort b1's or predators?
There's also supposedly some new raised port 600-13 that's in the works.
Re: Brewer heads
[Re: Viper469]
#2161523
09/25/16 06:49 PM
09/25/16 06:49 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
There has been a set (supposedly the last set made) on CL for a long time in the Tacoma, WA area. They show up and drop off after a while then they come back...not surprised that no one bites...
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Brewer heads
[Re: 1baddart]
#2162133
09/26/16 04:50 PM
09/26/16 04:50 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I would second talking to Michael Sanders or Best Machine about the "600-13" he is using. They are done by Goodwin Competition FWIW
Re: Brewer heads
[Re: 1baddart]
#2163077
09/27/16 08:12 PM
09/27/16 08:12 PM
Posts: 409 Texas
mprhound
Texas
There is a set for sale in Albuquerque nm with a raised block tunnel ram. Have to be an early set because they have rocker shaft stands cast in. My set use t&d paired rockers
If you want the single four cast intake that is very hard to find!!
