1987 D100 #2159702
09/22/16 09:56 PM
09/22/16 09:56 PM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
I just purchased a 1987 D100. I'm thinking about swapping in an Edelbrock performer intake and 1406 carb. IfI do this can I still leave the ESC computer and distributor hooked up? The carb is not a feedback one and I have no o2 sensor.
Re: 1987 D100 [Re: Eggman] #2159787
09/22/16 11:50 PM
09/22/16 11:50 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
I put a big block in one & had no problems with computer. Even hooked up vacuum advance
Re: 1987 D100 [Re: Eggman] #2159942
09/23/16 09:52 AM
09/23/16 09:52 AM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
I kinda thought it could work. It doesn't have a feedback carb, so it should run o.k.
Re: 1987 D100 [Re: Eggman] #2160007
09/23/16 12:21 PM
09/23/16 12:21 PM
scratchnfotraction Offline
done a few of them. feed back carbs or tbi I swap to a early model wire harness then by-pass the ecu.
myself on earlier models, I always by-pass the ecu with a stock points dist and pertronix points conversion.
well I do use the FBO mech advance limiter plate and spring kit in there also.
Re: 1987 D100 [Re: Eggman] #2160061
09/23/16 01:22 PM
09/23/16 01:22 PM
usa
Mopar1970440 Offline
usa
Recently bought an 86 D150. It already has the performer intake and 1406, and they still had the factory esc computer and distributor it was running fine...so shouldn't be a problem!
