Re: trouble shooting stock 383 issue [Re: GOLDMYN] #2184541
10/28/16 02:40 PM
10/28/16 02:40 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Tank was in serviceable condition, but since I had it out I believe in prevention rather than trouble years from now when it'll be impossible to find someone who seals tanks, The way it was, there was no one in the town I live in, people look at you like your from Mars.
Semper Fi
Re: trouble shooting stock 383 issue [Re: GOLDMYN] #2184618
10/28/16 03:46 PM
10/28/16 03:46 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Originally Posted By GOLDMYN
UPDATE. Changed the points/condenser and problem solved.
I knew a good mechanic in 71 who could not get a car to run right no matter what he did... Common thing back then was to change the points but leave the condenser... After trying everything he knew in installed a new condenser, problem solved..
Your post ending made me think of this.....
Re: trouble shooting stock 383 issue [Re: GOLDMYN] #2184951
10/28/16 10:58 PM
10/28/16 10:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check the bulkhead wiring connectors (3)...
After 50 years they get corroded and oxidized..
Pop them apart, burnish the contacts, recrimp the female tab conectors on the firewall side, coat with dia-electric grease and reinstall...
Just my $0.02... wink
Re: trouble shooting stock 383 issue [Re: Sinitro] #2185148
10/29/16 09:07 AM
10/29/16 09:07 AM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
? problem solved
Semper Fi
