Page 3 of 4 1 2 3 4
Re: Got my roof ..... [Re: 74fish] #215845
02/25/09 11:18 PM
02/25/09 11:18 PM
NM
74fish Offline OP
74fish  Offline OP
NM
welded and shaped
Re: Got my roof ..... [Re: 74fish] #215846
02/25/09 11:20 PM
02/25/09 11:20 PM
NM
74fish Offline OP
74fish  Offline OP
NM
end part of drip rail
Re: Got my roof ..... [Re: 74fish] #215847
02/25/09 11:24 PM
02/25/09 11:24 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Back brace welded .... checked the measurements and this part just fell in ....
Next up the roof skin .... first I've got to check it for surface rust on the back , pound out any little dings it might have and finally straighten the edging for a clean weld . I'll post more as I go along.....
Re: Got my roof ..... [Re: 74fish] #215848
02/26/09 10:12 PM
02/26/09 10:12 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Test fitting the roof
Re: Got my roof ..... [Re: 74fish] #215849
02/26/09 10:15 PM
02/26/09 10:15 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Checking what needs doing for the edging to line up.. 1/4 panel
Re: Got my roof ..... [Re: 74fish] #215850
02/26/09 10:15 PM
02/26/09 10:15 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Front pillars....
Re: Got my roof ..... [Re: 74fish] #215851
02/26/09 10:20 PM
02/26/09 10:20 PM
NM
74fish Offline OP
74fish  Offline OP
NM
window lip....
Re: Got my roof ..... [Re: 74fish] #215852
02/26/09 10:22 PM
02/26/09 10:22 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Identifying the dings .....
Re: Got my roof ..... [Re: 74fish] #215853
02/26/09 10:49 PM
02/26/09 10:49 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Btw ... I would like to thank everyone for all the comments and compilments.
This is my first roof and so far it seems to be going well. I'm not the greatest welder or best bodyman around that's for sure.
Over the years I've learned alot and done alot. Putting on a roof or a trunk pan was not somthing I thought I was capable of doing several years back. Moparts has really helped me and has kept me motivated. I just want to say thanks Moparts
Re: Got my roof ..... [Re: 74fish] #215854
02/26/09 10:59 PM
02/26/09 10:59 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
Moparts is a great motivator, years ago, I never thought myself to be the type to pull out motors and transmissions..I've got a few under my belt now..
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Got my roof ..... [Re: 74fish] #215855
02/26/09 11:45 PM
02/26/09 11:45 PM
Jacksonville Florida
elitecustombody Offline
I'd work out the dings while the skin is off, if you're patient enough you can massage them out instead of grinding and slapping bondo
Re: Got my roof ..... [Re: elitecustombody] #215856
02/27/09 01:49 AM
02/27/09 01:49 AM
NM
74fish Offline OP
74fish  Offline OP
NM
Planning on doing just that .. I have to be careful I don't add any more handling it...
Re: Got my roof ..... [Re: 74fish] #215857
03/14/09 07:16 PM
03/14/09 07:16 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Worked on the dings.. sprayed some guide coat
Re: Got my roof ..... [Re: 74fish] #215858
03/14/09 07:17 PM
03/14/09 07:17 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Now to address the back side of the roof
Re: Got my roof ..... [Re: 74fish] #215859
03/14/09 07:19 PM
03/14/09 07:19 PM
NM
74fish Offline OP
74fish  Offline OP
NM
You can see rust on the edges where the quarter panel goes and at the front pillar
Re: Got my roof ..... [Re: 74fish] #215860
03/14/09 07:21 PM
03/14/09 07:21 PM
NM
74fish Offline OP
74fish  Offline OP
NM
First I wire wheel it with my drill
Re: Got my roof ..... [Re: 74fish] #215861
03/14/09 07:25 PM
03/14/09 07:25 PM
NM
74fish Offline OP
74fish  Offline OP
NM
And then with my grinder on the bad parts. you can't grind too much or you'll cause heat and warp the panel.. Then I used my drill to with the wire wheel to remove as much surface rust as I can
Re: Got my roof ..... [Re: 74fish] #215862
03/14/09 07:27 PM
03/14/09 07:27 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Finally I brushed on a rust converter....
Re: Got my roof ..... [Re: 74fish] #215863
03/14/09 07:31 PM
03/14/09 07:31 PM
NM
74fish Offline OP
74fish  Offline OP
NM
I straightened all the edges and put the roof on. There was 2 beads of seam sealer on the middle support. and proceeded to measure and clamp
Re: Got my roof ..... [Re: 74fish] #215864
03/14/09 07:32 PM
03/14/09 07:32 PM
NM
74fish Offline OP
74fish  Offline OP
NM
clamp some more
Page 3 of 4 1 2 3 4
