Re: paint job on a budget!? *DELETED*
#21550
01/26/06 06:20 PM
01/26/06 06:20 PM
Posts: 4,820 near Alexandria, VA
Gas_Bandit
near Alexandria, VA
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned 1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2 1983 Firebird TA 1993 Saturn SL2 83k
[Re: 69chargeryeehaa]
#21551
01/26/06 06:37 PM
01/26/06 06:37 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
if you have the skill and time to do it my way and have a weekend warrior that you don't want to be embarhassed to drive but don't crap $ every night after dinner then give it a shot!!!
First of all, I crap my $ out after breakfast!!!
Seriousely, though, your idea is very sound and I take it way more seriousely than someone who comes on here and says "trust me, the electric supercharger on ebay really does add a lot of horsepower" Anyone can tell that you have been experimenting around with this, no matter how much the idea breaks with traditional thinking.
Please keep posting more details about this because it's a very interesting topic to a lot of us. I would love to see that charger if you decide to do even more polishing/buffing. Thanks for the info.
[Re: Jerry]
#21554
01/26/06 07:26 PM
01/26/06 07:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
does anyone think you can roll on bc/cc? who says it has to be spray only?
I'm more interested in the method. anyone can brush/roll on paint and sand it smooth.
**Photobucket sucks**
[Re: Jerry]
#21555
01/26/06 07:31 PM
01/26/06 07:31 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
well it just goes by "feel", theres no ratio that i could come up with because once you open the can and pour some out the next day the paint will be a bit thicker. if i had to guess i would say about 20% thinner or so? just thin enough that it does'nt run, but not too thick. keep in mind that you can allways add more paint to the mix if you go too thin. and the coats go on really really thin, that is the key, like i said before you don't really have a true non transparent base until the 3rd or 4th coat. There is no way i would try to roll on BC/CC it would definetly not work. that paint is ment to be atomized when sprayed, and you could never thin it down to the point where it does not run and is thin enough to apply. plus it would dry too fast with the correct reducers and flash over too quick. i think it would be impossible. when u just paint and sand, you're going to be sanding too much, and the paint is hard resulting in waves in the paint unless u sand really consistently, so the key is to lay it on thin and sand as little as possible, also when the paint layer is thin and the paint is thinned properly it "self levels" it's like bondo, u mix it up and it's just in a blob, let it sit for a few minutes and it flattens out, thats just what the paint does. hope that helps
[Re: Jerry]
#21559
01/26/06 07:59 PM
01/26/06 07:59 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
I was desribing what I have read here to one of my mechanics at work today. His dad also runs a small body shop and paints boats. He said oh yeah we do that method a lot with boats and basically described a similar method of application. Said that it sticks to boat hulls great and lasts longer than some marine epoxies. If it stands up to the crap we call water here it may hold up on a car. I am going to play with an old Duster fender this weekend if I have time and see how it works out.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
#21562
01/26/06 08:05 PM
01/26/06 08:05 PM
DaytonaTurbo
Manitoba, Canada
What about when you have to paint the bulk of the car? Like the roof, pillars and rear 1/4's all at once cause they're all one piece? Doesn't the paint on the roof dry by the time you get done one side and then start on the other, or are you starting on the bottom of one side and working up across and down the other side of the car? Or does the light coats and sanding make it okay? I'm pretty much just wondering if you have any kind of a seam line on the top of the car. Lol, and I emailed a link to this thread to my brother, and he wants to do it to his rampage. It'd be a perfect candidate to try this out on, seeing as the roller job done by the previous owner is looking real bad these days.
[Re: DaytonaTurbo]
#21564
01/26/06 08:15 PM
01/26/06 08:15 PM
69chargeryeehaa
toronto canada
i was wondering when someone would ask that question. well basically i do the hood, doors, front fenders, and the trunk, that's easy. then i do the whole roof and sail pannels in one shot working fast, there's enough time to do it before the paint tacks up if u rush it, not the time to have a coffee or smoke. i stopped at the rear quarter just below the sail pannels and top quarter pannel where there is a edge to stop at. then continue from there on each side meeting in the back rear valance. the trick there is to not leave and raised paint lines, and smooth it out gradually as u approach the point where u stop, then run to the other side and do the other half of the roof and overlap the strokes. wetsanding does the rest, but u try to make it as smooth as possible, the paint is very thin on each coat. it's really hard to describe, that's where all the expirementing comes in to play.
[Re: plymouthfan]
#21565
01/26/06 08:19 PM
01/26/06 08:19 PM
69chargeryeehaa
toronto canada
The photo's don't lie, but only time will tell how the paint holds up. It's true there are no guarantee's, but for the amount of time and money spent it seemed worth the effort.
i can say i'm on 6 yrs and 35,000mi and counting on the orange 74 beetle, so time has told me that it holds up. Still looks like the day i did it. for those who haven't seen the pics, here they are, the beetle pics were this past summer (there's 2 pages of pics BTW) http://photobucket.com/albums/d13/69martin/paint/
[Re: 69superbee383]
#21566
01/26/06 08:24 PM
01/26/06 08:24 PM
I painted my chev S-10 with John Deere yellow construction paint. Mind you i sprayed it on but it looked really good.
#21567
01/26/06 09:17 PM
01/26/06 09:17 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Just curious, what happens when you try rubbing compound? You mention its too rough. To me, it seems like an important step to eliminate from the finishing process. I know in my limited painting experience, if going from wet sanding directly to a machine glaze, the gloss would be knowhere near as deep as if I had used a rubbing compound first.
2 kids and a dog
