The shaft needs to be good for added torque, traction
and rpm... those are the 3 major factors... the factory
shaft isnt held to all the greatests tolerances but not
bad.. if you have .010 run out you might feel it.. if its
more you will.. diameter is strength along with the material..
I have had stock shafts be bad from the factory(just a small
vibration).. I took it into work and took it to the lab that
balances them.. it was bad and he balanced it and added weight
to get it right... that big weight that hangs off the trans is
there to change the frequency that the vibration was at to a
point that is out of the normal shaft speed... I buy a new shaft
for all my builds.. Dynotech is who I use for all of them.. never
had any issues with there parts
