limits of stock driveshaft?
#2155053
09/15/16 01:19 PM
09/15/16 01:19 PM
Posts: 370 Suffolk County, New York
1mean340
For a small block E body. Anybody know how far most people push these things before they twist up? I'm going to run a driveshaft loop on my car, but I figured at least for a little while I'd keep the stock driveshaft/stock pinion yoke on the car until I can recoup some funds. The car is an auto and on drag radials but I doubt it'll be hooking up too hard and will see mostly street driving (I'll probably be able to pick up a good one before getting to the track as I doubt I'll make it to the track before next season).
HP wise I am hoping will be around 650 at the crank via procharger so no instant nitrous hit off the line or anything like that.
Re: limits of stock driveshaft?
[Re: 1mean340]
#2155076
09/15/16 01:45 PM
09/15/16 01:45 PM
Posts: 570 UK
rb446
UK
I can't tell you what the limits are but I can tell you that on my old Street/strip '71 340 Cuda with stock 8.3/4" posi, stock leafs with clamps on the fr segment, snubber, stock prop, u-bolts etc., a 4200 verter/4.30's and 10x28's it took a 250 shot hit off the line with ease with daylight under the frontrunners, so wouldn't think you'd have issues with your set up.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: 1mean340]
#2155111
09/15/16 02:33 PM
09/15/16 02:33 PM
Posts: 11,747 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
7260 joints? Stock slip yoke? A driveshaft coming out under power usually tears up your car a lot more than the price of a good shaft, and maybe even the car of the guy next to you. You can afford the power adders but try to get away with a stock driveline? Cruising around it may be OK. I would not want it in there at the track. Neither would I want to be close to it or be in the other lane.
[Re: CMcAllister]
#2155130
09/15/16 03:05 PM
09/15/16 03:05 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
7260 joints? Stock slip yoke? A driveshaft coming out under power usually tears up your car a lot more than the price of a good shaft, and maybe even the car of the guy next to you. You can afford the power adders but try to get away with a stock driveline? Cruising around it may be OK. I would not want it in there at the track. Neither would I want to be close to it or be in the other lane. Well then there is this ^^^^ On a related note: I once a tossed a stock driveshaft out of a mid 11-second car once due to rear u-joint failure. Cut a slick then took out the little piece of rubber brake hose on the rear end AND bent a shock on it's way out. First thing to go was the tail shaft of the 727. AND the guy in the other lane almost wadded his ride up trying to dodge it. 11 second car isn't fast. That is, until you are at 1000' and you have no brakes, one flat slick and the good slick has a light misting of the recently exiting trans fluid on it.
[Re: 1mean340]
#2155137
09/15/16 03:18 PM
09/15/16 03:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have had to dodge driveshafts coming across my lane back in the "good ol' days" when all we had were stock shafts. Not a fan of that kind of action.
[Re: 1mean340]
#2155147
09/15/16 03:40 PM
09/15/16 03:40 PM
Posts: 7,506 Az
Crizila
Az
At 650 HP, a stock driveshaft is a time bomb waiting to happen.
Fastest 300
[Re: Crizila]
#2155148
09/15/16 03:42 PM
09/15/16 03:42 PM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
At 650 HP, a stock driveshaft is a time bomb waiting to happen. Yep. Why people would want to debate that fact is beyond me. It's an accident waiting to happen.
[Re: 1mean340]
#2155348
09/15/16 10:21 PM
09/15/16 10:21 PM
Posts: 608 TN
1DGEMAN
TN
The drive shaft doesn't break it is the U joints. Like Cab said put solid joints in it. I had hundreds of runs on 7260 joints in a stick shift Duster and Demon NHRA Stocker never broke an U joint broke plenty of 8 3/4's. Of course when the rules changed and I could put a Dana in the car I went 1350 and aluminum shaft. I can't believe a slushomatic hits the shaft like we did back in the day with our high pressure clutches and 3 pad discs. Oh and the 71 Demon Cab is talking about was my old car that got switched to slushbox because the owner couldn't drive a stick.
Real Men shift for themselves
[Re: 1DGEMAN]
#2155492
09/16/16 01:24 AM
09/16/16 01:24 AM
Posts: 4,706 Wichita
GY3
Wichita
The drive shaft doesn't break it is the U joints. Like Cab said put solid joints in it. I had hundreds of runs on 7260 joints in a stick shift Duster and Demon NHRA Stocker never broke an U joint broke plenty of 8 3/4's. Of course when the rules changed and I could put a Dana in the car I went 1350 and aluminum shaft. I can't believe a slushomatic hits the shaft like we did back in the day with our high pressure clutches and 3 pad discs. Oh and the 71 Demon Cab is talking about was my old car that got switched to slushbox because the owner couldn't drive a stick. This! I killed a 7260 Spicer joint at the track a few weeks ago. Sheared one cross right off! I started using solid joints!
[Re: 1mean340]
#2155507
09/16/16 02:00 AM
09/16/16 02:00 AM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
The stock drivetrain can take quite a bit of power. More than many think.
For 14 yrs(1988-2002) ran a stock drive shaft in my 73 cuda that used a combo u-joint to mate to the dana I added. Was running 10 teens at 3500lbs, 1.41 60'but no trans brake.
Close friend ran the same stock shaft and combo u-joint in his GTX from 1988 till 2 yrs ago. He was running 9.7-9.8 at 3550lbs and a trans brake. Never lost one.
Both of us do understand we were playing w/fire and have since switched. We were lucky. Even though you probably will be ok why take the chance when you can get a new driveshaft that's built to handle the power for about $400. Lots cheaper than replacing a car.
Ok
[Re: 1mean340]
#2155685
09/16/16 01:27 PM
09/16/16 01:27 PM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
I ran a stock driveshaft until my car went into the 10s at 3700 lbs. Then I twisted two shafts on back to back weekends. Took out the tailshaft housing both times too.
[Re: 10secchallenger]
#2155774
09/16/16 03:07 PM
09/16/16 03:07 PM
Posts: 3,288 West Coast, USA
jbc426
West Coast, USA
Strange Engineering can ship you out a 3" chromemoly shaft with 1350 u-joint and forged yoke & flange for pretty cheap. If you don't want to spend the money, follow Cab's advice about the u-joints on yours.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
