Re: paint job on a budget!?
[Re: FuryUs]
#21571
01/26/06 09:55 PM
01/26/06 09:55 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
Ok I was bored tonight so I ran down to Home Depot and picked up a quart of Rustoleum 7747 Sunburst yellow paint. Also got a quart of mineral spirits and the high density foam rollers. or giggles I also got a spray can of the same paint. I swear that color looks a lot like a cross between Viper Yellow and FY 1. Enter one torn up Duster fender...I painted the bottom with the spray bomb then mixed some paint with the mineral spirits and like he said I just did it till it felt right...took the roller and applied it to the top of the fender..it is cold tonight and actually that isnt bad since it made it easier to work with. You can do the fender lips and edges using the rounded edge. It seems to give it a different texture but I am thinking it will lay down and not be visible. Well first coat on and I can tell it is laying down. To be honest the sprayed part looks really good already. I will let it dry tonight and reapply another coat tomorrow then wet sand on Saturday...I will play with this over the weekend and I am really interested to see how this comes out...next up my girlfriends beater Neon...
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: 69superbee383]
#21572
01/26/06 10:02 PM
01/26/06 10:02 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
do another coat, try to put it on really light, i hope u prepped the fender a little before you started painting. when u wet sand try using a 600-800 grit, and lightly wet sand the fender with light pressure and ALOT of water. Spraying it on should maybe work better but its messy, stinky, and a pain. when u first start to wet sand you'll notice the paper just kinda glides over the paint and it does'nt really feel like your sanding anything, keep going, soon the water will stop beeding off the paint and it will start to turn yellow. after wetsanding it looks like crap, this is where the polishing come in, brings it to glass.
#21577
01/26/06 11:15 PM
01/26/06 11:15 PM
Posts: 3,062 Western New York
sixpackbee
Western New York
This is driving me crazy.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: 69chargeryeehaa]
#21578
01/26/06 11:25 PM
01/26/06 11:25 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
guys all i have to tell you is that i first painted a 85 honda crx at my cottage in 1 day, i had no money, i did like 3 coats with no sanding and it looked great, i should scan that old pic and show you!!!. The job only looks as good as the time and effort that you put into it. the paint is extreemly durable, think about it, it's used to paint over rusted metal on things like tractors, metal railings, ect... and stand the elements. it is formulated to do just that. the tequnique is critical, u have to have a "feel" for how much to thin the paint and u have to use mineral spirits, not paint thinner like varsol. I could not even imagine how well it would turn out if you sprayed it with a HVLP gun and wet sanded and polished. It does "self Level" on the sides just as it does on the flat level surfaces. Like i said before it is critical on how you thin the paint and how you apply it. i did the charger in about 3 days. i got sick of going to body shops and them telling me either they don't do classic cars and if they did want to do the car i need at least $5000 even though the car was stripped and prepped!!!! the auto painting industry is in my opinion a total rip off so if you want it done right and cheep, do it yourself!!! when the paint is thinned your barley putting on any paint with each coat, so you really need to do about 6 coats to get enough of a base so you can wet sand and polish. it took me a long time to figure out what steps to take to get awesome results. my 74 bug looks awesome even after 6 years the paint is still mint. looks like the day i did it. that paint dries FAST, so literally you can wetsand overnight. Keep in mind i know a little about painting, i've shoot a few cars with single stage enamel with professional results, but it's expensive and tedious. I used duplicolor paint, primer, reducer and primer sealer on this car: http://i32.photobucket.com/albums/d13/69martin/DSC00194.jpg it looked like this before paint: http://i32.photobucket.com/albums/d13/69martin/Picture1.jpg that car was painted midnight metalic blue, and flips awesome in the sun. a very hard color to do cause it's almost black and shows every imperfection. but as you can see in the pic it came out awesome. but the materials alone (paint, reducer, primer, primer sealer) cost about $250 CDN, which was alot, never mind the work. the "tremclad" paint is really a awesome alternetive, since your rollering it on there's no dust and you get a really clean paint job if you do it in your garage, where if you spray theres a battle with dust. when i painted with the Tremclad i just use the paint, no primer, nothing, just the paint, right over bondo. like i mentioned before after wetsanding use a random orbit polisher and the cheapest POLISHING COMPOUND made by turtle wax, it comes in a paste in a small round flat container and it's white, allmost looks like hand cream and smells good too!!! I find that after thinning the paint with mineral spirits the paint "flashes" or dries really quickly, and after a overnight period it is completely dry, unlike automotive paint which takes up to 6 months to fully "cure" so litterally the next day you can sand, buff, polish, and wax the paint. on the charger the paint looks really good, i did not take a huge amount of time to perfect it because i really really wanted to drive it!!!. in the spring i plan on wetsanding and polishing it more, but yes it looks like the pics, really good. considering that it cost me about $50 i love it and i'm not paranoid about juicing it on a dirt road and going sideways worring about my precious paint job, i drive the car, hard and alot, after all is'nt that what they're made for? for $50 and a few days of work i can paint it again in a few years!!!! If your not good with your hands, and not a real detail person let someone else paint your car cause it can get ugly really fast!!!! if i had a shop, made a little paint booth and sprayed this stuff on and wetsanded and polished it, i'm sure i could paint show quality cars with $30 worth of paint. keep in mind this paint is really good, like i said bofore i bought a can 3 yrs later to repaint a fender on my 74 beatle and it was dead on for color match, that must tell you about the quality of the paint, i'd give you $100 if you could tell me which fender i painted on this car in person, and its' right out of the can: http://i32.photobucket.com/albums/d13/69martin/DSC00164.jpg keep in mind that you must still prep the car as you would with any other paint job, prepping is all the work and reflects the overall result. i did not block sand the car just wetsand progressivly finer paper by HAND, no machine, no block nothing. using any "block" to sand i found the paper got dirty fast and got all plugged up, so do it by hand and keep it really wet, using a spray bottle in one hand and a clean bucket of water and a shammy (dollar store!!!)to clean it off to see how it looks. i prepped the car with 80, then 100, then 200, finished with a 400, did all my body work, and painted. after 2 coats (about 4hrs work for the whole car) i wetsanded with a 600, then did 2 more coats, wetsand with 800, 2 more coats and sand with a 1000-1500 and polish, followed by wax, done......
If you wanted metalic why couldn't upi mix in metalic flakes?? Just a thought. I know you would have to keep them stirred up to get them somwhat even. That would be the main problem with the roller technique but if it were sprayed???
[Re: Exit1965]
#21582
01/27/06 11:22 AM
01/27/06 11:22 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Looking at the 2 different rustoleum sites I am not sure if Tremclad is just Rustoleum with different name. It seems to be marketed differently in Canada and no real equivalent on the USA site.
It might not meet EPA standards in the USA.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: max]
#21586
01/27/06 12:28 PM
01/27/06 12:28 PM
69chargeryeehaa
toronto canada
i've painted engine accessories like air cleaners, pulleys, fans, with the rattle can version, but on the block it self i would only use a engine enamel, i would'nt want to expirement with the rust paint and have it not hold up to the heat. i have had really good luck with duplicolor engine enamel in a rattle can, in my pics, both the beetle engine tins were painted with it and it looks just like when i did it, also keep in mind that those VW air-cooled beetles run HOT, over 400* deg F, and the paint is perfect after 6 years.
#21587
01/27/06 12:46 PM
01/27/06 12:46 PM
This is really a great thread,thanks a lot 69chargeryeehaa! The A-100 might get that treatment when it's time to paint.
One note about the Duplicolor spary can engine enamel - my buddy and I had nothing but trouble with them as compared to the Plastikote. On more than one occasion they would fish-eye like crazy, and not cover very well. Using the Plastikote solved the problem. It happened more than once, so we swore never to use Duplicolor. But the Duplicolor in Canada can be diffeenet than the Duplicolor in So-Cal.
Ran
P.S. - I see the "it doesn't look nearly as good as my custom $10,000 paint job" criticizm has died down, thank god.
