Question to anybody using the Moroso Blue V/C gaskets #215314
02/05/09 08:24 PM
02/05/09 08:24 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
I heard somewhere that the valve cover has to be flat with no lip to hold the gasket..... is this the case? I have the Mopar ribbed V/Cs and they have a lip for the gasket.
Trying to cure a V/C leak so want to be sure I use the new $50 gaskets correctly.
Tom
Re: Question to anybody using the Moroso Blue V/C gaskets [Re: Dart Racer] #215315
02/05/09 09:29 PM
02/05/09 09:29 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
They should be fine,mine fit inside the lip of my old M/T valve covers just like a regular cork gasket.I am very happy with mine.
Re: Question to anybody using the Moroso Blue V/C gaskets [Re: Dunnuck Racing] #215316
02/05/09 09:39 PM
02/05/09 09:39 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have them under my old stamped aluminum direct connection covers. They fit within the lip. Best valve cover gaskets i've ever bought. No leaks , no glueing, no replacing squished out rubber or cork.
Re: Question to anybody using the Moroso Blue V/C gaskets [Re: Dart Racer] #215317
02/05/09 10:35 PM
02/05/09 10:35 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
They have worked on every cover I have tried so far. I still have about 7 sets left from a prior sale, so I can accomodate if any one needs them. Still reduced shipping rate.
RIP Monte Smith
