Page 4 of 85 1 2 3 4 5 6 84 85
Re: paint job on a budget!? *DELETED* #21550
01/26/06 05:20 PM
01/26/06 05:20 PM
near Alexandria, VA
Gas_Bandit Offline
Gas_Bandit  Offline
near Alexandria, VA
Post deleted by Ira
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned
1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2
1983 Firebird TA
1993 Saturn SL2 83k
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21551
01/26/06 05:37 PM
01/26/06 05:37 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
if you have the skill and time to do it my way and have a weekend warrior that you don't want to be embarhassed to drive but don't crap $ every night after dinner then give it a shot!!!
First of all, I crap my $ out after breakfast!!!
Seriousely, though, your idea is very sound and I take it way more seriousely than someone who comes on here and says "trust me, the electric supercharger on ebay really does add a lot of horsepower" Anyone can tell that you have been experimenting around with this, no matter how much the idea breaks with traditional thinking.
Please keep posting more details about this because it's a very interesting topic to a lot of us. I would love to see that charger if you decide to do even more polishing/buffing. Thanks for the info.
Re: paint job on a budget!? *DELETED* [Re: Pool Fixer] #21552
01/26/06 05:48 PM
01/26/06 05:48 PM
toronto canada
69chargeryeehaa Offline
toronto canada
Post deleted by Ira
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21553
01/26/06 06:13 PM
01/26/06 06:13 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
my concern is how to really thin the paint. i've got an autocross car i'd be willing to try this on. in any case... i am hoping for a little more scientific approach than it looks a little thicker than water. can we get 1:1 or 1:10 or 1:whatever?
Re: paint job on a budget!? [Re: Jerry] #21554
01/26/06 06:26 PM
01/26/06 06:26 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
does anyone think you can roll on bc/cc? who says it has to be spray only?
I'm more interested in the method. anyone can brush/roll on paint and sand it smooth.
**Photobucket sucks**
Re: paint job on a budget!? [Re: Jerry] #21555
01/26/06 06:31 PM
01/26/06 06:31 PM
toronto canada
toronto canada
well it just goes by "feel", theres no ratio that i could come up with because once you open the can and pour some out the next day the paint will be a bit thicker. if i had to guess i would say about 20% thinner or so? just thin enough that it does'nt run, but not too thick. keep in mind that you can allways add more paint to the mix if you go too thin. and the coats go on really really thin, that is the key, like i said before you don't really have a true non transparent base until the 3rd or 4th coat.
There is no way i would try to roll on BC/CC it would definetly not work. that paint is ment to be atomized when sprayed, and you could never thin it down to the point where it does not run and is thin enough to apply. plus it would dry too fast with the correct reducers and flash over too quick. i think it would be impossible. when u just paint and sand, you're going to be sanding too much, and the paint is hard resulting in waves in the paint unless u sand really consistently, so the key is to lay it on thin and sand as little as possible, also when the paint layer is thin and the paint is thinned properly it "self levels" it's like bondo, u mix it up and it's just in a blob, let it sit for a few minutes and it flattens out, thats just what the paint does.
hope that helps
Re: paint job on a budget!? [Re: Jerry] #21556
01/26/06 06:43 PM
01/26/06 06:43 PM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
Keep it coming 69 Chargeryeehaw.
GREAT IDEAS
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21557
01/26/06 06:44 PM
01/26/06 06:44 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
also i assume this only works for solid colors. have you tried doing stripes or anything?
Re: paint job on a budget!? [Re: Jerry] #21558
01/26/06 06:55 PM
01/26/06 06:55 PM
toronto canada
toronto canada
yes, metalics are out of the picture here, no i haven't tried doing stripes but i imagine it would be easy.
Re: paint job on a budget!? [Re: Jerry] #21559
01/26/06 06:59 PM
01/26/06 06:59 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I was desribing what I have read here to one of my mechanics at work today. His dad also runs a small body shop and paints boats. He said oh yeah we do that method a lot with boats and basically described a similar method of application. Said that it sticks to boat hulls great and lasts longer than some marine epoxies. If it stands up to the crap we call water here it may hold up on a car. I am going to play with an old Duster fender this weekend if I have time and see how it works out.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: paint job on a budget!? *DELETED* [Re: 69chargeryeehaa] #21560
01/26/06 07:01 PM
01/26/06 07:01 PM
toronto canada
toronto canada
Post deleted by Ira
Re: paint job on a budget!? [Re: Jerry] #21561
01/26/06 07:04 PM
01/26/06 07:04 PM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
This is definitely one of the more interesting threads I've read in a while here. You have to hand it to him, he thought outside the box, and it seems to have paid off. The photo's don't lie, but only time will tell how the paint holds up. It's true there are no guarantee's, but for the amount of time and money spent it seemed worth the effort.
High density foam rollers are pretty amazing, I use them all the time around the house on wood and metal. I refinished my fridge pictured below with a roller and POR-15 engine enamal. I think it turned out pretty great and I didn't put half the effort he put into his car. Of course it doesn't sit out in the sun or rain, but it worked.
One red car, one yellow car.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21562
01/26/06 07:05 PM
01/26/06 07:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What about when you have to paint the bulk of the car? Like the roof, pillars and rear 1/4's all at once cause they're all one piece? Doesn't the paint on the roof dry by the time you get done one side and then start on the other, or are you starting on the bottom of one side and working up across and down the other side of the car? Or does the light coats and sanding make it okay? I'm pretty much just wondering if you have any kind of a seam line on the top of the car. Lol, and I emailed a link to this thread to my brother, and he wants to do it to his rampage. It'd be a perfect candidate to try this out on, seeing as the roller job done by the previous owner is looking real bad these days.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21563
01/26/06 07:08 PM
01/26/06 07:08 PM
toronto canada
toronto canada
oh and yes, i've heard of alot of people using this paint to paint fiberglass boats too, infact i painted my little sail boat with it and it's holding up great. my wife actually gave me the idea first about 12 yrs ago one day at the cottage to paint my 85 honda crx (which was white) and we painted it black, i just scuffed up the paint, and painted it with some old rust paint and those rollers my dad had in the garage. would you believe i drove that car for like 3 more years? it really looked good.
Re: paint job on a budget!? [Re: DaytonaTurbo] #21564
01/26/06 07:15 PM
01/26/06 07:15 PM
toronto canada
toronto canada
i was wondering when someone would ask that question. well basically i do the hood, doors, front fenders, and the trunk, that's easy. then i do the whole roof and sail pannels in one shot working fast, there's enough time to do it before the paint tacks up if u rush it, not the time to have a coffee or smoke. i stopped at the rear quarter just below the sail pannels and top quarter pannel where there is a edge to stop at. then continue from there on each side meeting in the back rear valance. the trick there is to not leave and raised paint lines, and smooth it out gradually as u approach the point where u stop, then run to the other side and do the other half of the roof and overlap the strokes. wetsanding does the rest, but u try to make it as smooth as possible, the paint is very thin on each coat. it's really hard to describe, that's where all the expirementing comes in to play.
Re: paint job on a budget!? [Re: plymouthfan] #21565
01/26/06 07:19 PM
01/26/06 07:19 PM
toronto canada
toronto canada
i can say i'm on 6 yrs and 35,000mi and counting on the orange 74 beetle, so time has told me that it holds up. Still looks like the day i did it.
for those who haven't seen the pics, here they are, the beetle pics were this past summer (there's 2 pages of pics BTW)
http://photobucket.com/albums/d13/69martin/paint/
Re: paint job on a budget!? [Re: 69superbee383] #21566
01/26/06 07:24 PM
01/26/06 07:24 PM
Anonymous OP
Anonymous OP
I painted my chev S-10 with John Deere yellow construction paint. Mind you i sprayed it on but it looked really good.
Re: paint job on a budget!? #21567
01/26/06 08:17 PM
01/26/06 08:17 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Just curious, what happens when you try rubbing compound? You mention its too rough. To me, it seems like an important step to eliminate from the finishing process. I know in my limited painting experience, if going from wet sanding directly to a machine glaze, the gloss would be knowhere near as deep as if I had used a rubbing compound first.
2 kids and a dog
Re: paint job on a budget!? #21568
01/26/06 08:21 PM
01/26/06 08:21 PM
Johnston County, N.C.
Shawns_Cuda Offline
Shawns_Cuda  Offline
I'm going to give this a shot this weekend on my project car. In case anyone was wondering here's a pricelist from Lowes Home Improvement. This is an awesome thread.
Rustoleum $24.57 for all colors (1 gal)
Mineral Spirits $8.42
Foam brush w/ roller (4") $3.47
Foam brush refills (4") (2 pack) @ $3.47 (6 pack) @ $9.32
Flat foam brush (2").57 ea (3").74 (4").82
Roller tray (3 pack) $1.28
"Water" proof sandpaper (5 sheet pack) $2.97 all grits
I'll post before and after pics here or maybe I can get John to post some on the website. I'll also try to get dilution ratios if I remember at the time.
Shawn
Re: paint job on a budget!? [Re: TonyS451] #21569
01/26/06 08:23 PM
01/26/06 08:23 PM
toronto canada
toronto canada
the rubbing compound could be used if you really want to, i just found it much better to wetsand with 1000 grit and then go straight to polishing, that's what worked for me. the rubbing compound seemed to ball up under the polisher and make a mess and make some scratches when it balled up, i used the polishing compound on a regular bonnet on a 10" elecrtic random orbit polisher, it's only after polishing that it looks like glass, and i kept it wet with water from a spray bottle on the bonnet, forgot to mention that, but keeping it quite wet worked great.
