Re: Another burnt pushrod! [Re: gregsdart] #2153088
09/12/16 03:07 PM
09/12/16 03:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you can live with "standard duty" Comp lifters and want pushrod oiling for a bb, and don't need offset pushrod seats, just use the AMC lifter(861) along with the bb mopar link bars(829L).
These will have the same pushrod seat height as the 892(not 829) and 87016, but with the oil hole parallel to the axle.
Re: Another burnt pushrod! [Re: gregsdart] #2153194
09/12/16 06:09 PM
09/12/16 06:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
First 250 passes Comp 829. Then switched to Isky Bushed. My Iskys have the oil hole for the axles in approximately the same spot. The first .050" or so of lifter travel the axle holes are exposed. The pushrod feed holes are located above the band. I restrict the pushrods with a 3/32" roll pin (inner hole dia aprox .058") The feed hole in the bushing is aproximately .100". The oil pressure runs around 60@1500, 80@7000 with 5/W30. Comp 996 springs, Now Pac 1224 both set at 300-310 seat.
Doug
Re: Another burnt pushrod! [Re: gregsdart] #2153208
09/12/16 06:28 PM
09/12/16 06:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
Doug, your lifters have a "band"? Not slots like the ones in the pic?
Feed holes parallel or perpendicular to the axles?
Re: Another burnt pushrod! [Re: fast68plymouth] #2153272
09/12/16 08:28 PM
09/12/16 08:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes, a band push rod holes 90 degrees to the axle. I found a pic
Doug
Re: Another burnt pushrod! [Re: gregsdart] #2153281
09/12/16 08:41 PM
09/12/16 08:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
On one of the motors I put together using Jesel rockers, I thought I'd be a smart guy and go with pushrod oiling.
It was built from an aluminum World block with bushed lifter bores, so I got some Comp 892's for it.
Had it all together, primed the motor....... And as soon as the drill bogged a bit from building oil pressure in the system, oil shot out of the top of one of the rockers 15-20 feet across the shop.
Apparently, the hole in the bushing and the hole in the lifter were lined right up with each other when the cam was on the based circle.
With the drill even barely turning oil just gushed out of whichever rockers were mostly closed.
When I saw it my thought was, "well....... I guess that's not going to work".
That was completely unrestricted oil flow to the top end.
Ordered some 87019's(no oil holes) and spray bar valve covers..... And that was that.
Re: Another burnt pushrod! [Re: fast68plymouth] #2153330
09/12/16 10:12 PM
09/12/16 10:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My comps had the oil hole inline. The motor would only build 45psi@7000. epoxied the hole in the adjacent side of the lifter and restricted the opposite side to .040". Then had to back the adjustment screw for the relief valve out .250" to get the pressure back down to 65@7000.
Doug
Re: Another burnt pushrod! [Re: gregsdart] #2153358
09/12/16 10:43 PM
09/12/16 10:43 PM
gregsdart Online content OP
gregsdart  Online Content OP
The lifters are on their way to Isky, so in about a week or so I should have some parts to test.
Now to figure out why I have three relatively new intake rockers with busted needle bearing cages mad I've seen them break on the outer edge of the cage next to the snap rings, but these are all broken inside, where there shouldn't be any side load. I am glad I took the time to check them. They felt fine till I tried to rotate them a full 360 around the shafts, then I could feel some bind, and found the broken ones.
