Page 38 of 45 1 2 36 37 38 39 40 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2152133
09/11/16 06:17 AM
09/11/16 06:17 AM
Earth
Rob C Offline
Rob C  Offline
Earth
OP's, double post. up
Re: Trick Flow heads [Re: Rob C] #2152534
09/11/16 07:58 PM
09/11/16 07:58 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Originally Posted By Rob C
IMO, more than 30hp for a tenth, a lot more.
At 3800lbs, going from 11.50 to 11.40, the moroso chart shows it would take 13hp, about the same for going from 115mph to 116mph.
Re: Trick Flow heads [Re: fast68plymouth] #2152591
09/11/16 09:14 PM
09/11/16 09:14 PM
AndyF Offline
AndyF  Offline
Here is a link to a video of the console during the 720 hp pull: https://www.youtube.com/watch?v=qGGD_oIgbas
Re: Trick Flow heads [Re: fast68plymouth] #2152624
09/11/16 09:44 PM
09/11/16 09:44 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
andy on your see through valve cover on you tube videos i would expect to see rocker oil sooner and more of it?
Re: Trick Flow heads [Re: fast68plymouth] #2152631
09/11/16 09:49 PM
09/11/16 09:49 PM
AndyF Offline
AndyF  Offline
Yeah that is what everyone says but the rockers just don't spray that much oil around. I've posted 3 different rocker arm videos now and they all look roughly the same. I think the MRE rockers have the most oil spraying around but even they don't have a ton of it.
I'm using pushrod oiling as well as normal internal oiling thru the head so if anything my rocker arms should have more oil than normal. Guess that goes to show how little oil is actually up there in the valve covers.
Re: Trick Flow heads [Re: fast68plymouth] #2152654
09/11/16 10:06 PM
09/11/16 10:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep, about right. Heck at 30 horse for a tenth, that would be only a little better than 3 tenths with a hundred horsepower gain... Lol
100 horse change is WAY more than 3+ tenths.
I saw exactly a tenth( as did my brother with his car at the same time) when we both went to electric water pumps and electric fans years ago. We figured a 12-15 horse change, and it indeed showed up as a tenth on our time slips.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Trick Flow heads [Re: AndyF] #2152698
09/11/16 10:33 PM
09/11/16 10:33 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
do you think its enough oil for valve spring cooling
Re: Trick Flow heads [Re: fast68plymouth] #2152712
09/11/16 10:46 PM
09/11/16 10:46 PM
AndyF Offline
AndyF  Offline
Did you try the 1050/4500 on an adapter, on the TF manifold?
The TF intake 1050/4150 combo was 5hp better than the unported M1/4500 combo?
I did try the Dominator on the TF intake using a Wilson adapter and it sucked. Lost 20 hp when compared to the 1050-AN QF carb.
Re: Trick Flow heads [Re: fast68plymouth] #2152767
09/11/16 11:21 PM
09/11/16 11:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
I guess I didn't expect there to be that much difference, one way or the other.
Just shows how easy it is to bolt combinations of stuff on that doesn't work.
Re: Trick Flow heads [Re: fast68plymouth] #2152823
09/12/16 12:29 AM
09/12/16 12:29 AM
AndyF Offline
AndyF  Offline
Yeah I've had guys tell me that the Dominator works better on a 4150 intake due to the "venturi effect". Not exactly sure what that means but it didn't work on this combo.
For comparison the TF intake with a 4150 carb was 10 hp better than the unported M1 4500 intake with the Dominator carb. The Wilson intake added a bunch of power over the unported M1 but most guys aren't going to spend the bucks to have Wilson re-work an intake that much. So for the average bracket guy the best combo appears to be the TF intake with a good 4150 carb.
Re: Trick Flow heads [Re: AndyF] #2152845
09/12/16 12:54 AM
09/12/16 12:54 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Was that the tall adapter/spacer and was it blended into the plenum? work Easy to say the dommy sucked w/out a TALL adapter blended into the plenum..........maybe I should ship you my intake and carb for a test............. drive
Re: Trick Flow heads [Re: fast68plymouth] #2156261
09/17/16 02:32 PM
09/17/16 02:32 PM
AndyF Offline
AndyF  Offline
Here are a couple of pulls from inside the dyno cell: https://youtu.be/8oLyIhDdKww
Engine is making around 720 hp @ 6600 rpm on these pulls. Using a very tall open spacer with a merge insert on top of the Wilson intake. The rocker arms start to throw off of a lot of oil at the top of the run but the oil clears off as soon as the RPM drops.
Re: Trick Flow heads [Re: AndyF] #2156293
09/17/16 03:48 PM
09/17/16 03:48 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
So, how would this be for a "Drag Week" type build?
Re: Trick Flow heads [Re: AndyF] #2156410
09/17/16 08:24 PM
09/17/16 08:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
It's easy to sit here on the computer and "spend your money", but I'd love to see that test done with a 1050/4500 on top of an HVH 4500/4150 super sucker adapter.
Re: Trick Flow heads [Re: Skeptic] #2156423
09/17/16 08:37 PM
09/17/16 08:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
The heads on Andy's dyno mule have had a few parts changes since the first pull..... But IMO, the ootb roller springs/retainers, along with 1.5 rockers(zero power loss in that combo) and some decent lifters(as in someone's premium lifter)....... Keep it under 7k..... Should work fine.
Re: Trick Flow heads [Re: fast68plymouth] #2156467
09/17/16 09:55 PM
09/17/16 09:55 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
So what is the combo of said motor as of right now..I see you have changed a few parts here and there just wondering if you didn't mind giving a short run down...that's some pretty good numbers there..
Re: Trick Flow heads [Re: fast68plymouth] #2156519
09/17/16 11:32 PM
09/17/16 11:32 PM
AndyF Offline
AndyF  Offline
I haven't changed the shortblock since the beginning so it is still 10.5 compression with the SCAT crank and Diamond pistons. It currently has the Comp cam in it which is 264/268 duration. What I've been testing lately is the rocker arms and then I've tried some different carb spacers and stuff like that. High level summary is that it makes 700 hp with a Trick Flow intake and a QF carb. With the Wilson intake and a Dominator it makes about 720 hp.
Re: Trick Flow heads [Re: Skeptic] #2162380
09/26/16 10:17 PM
09/26/16 10:17 PM
AndyF Offline
AndyF  Offline
Andy, are you still going to test the M1 tunnel ram?
Getting ready to do just that.
Re: Trick Flow heads [Re: AndyF] #2162419
09/26/16 10:56 PM
09/26/16 10:56 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
Andy, are you offering a valley plate for the trick flows at this time? I am starting a build and cannot stand the tin tray. Would like to order if you are, thanks.
Re: Trick Flow heads [Re: AndyF] #2162444
09/26/16 11:39 PM
09/26/16 11:39 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Are those the "Magical" 500 cfm Eddie carbs?
