Page 37 of 45 1 2 35 36 37 38 39 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2146756
09/03/16 01:11 PM
09/03/16 01:11 PM
AndyF Offline
AndyF  Offline
Looks like pushrod oiling is required with 750 lbs over the nose. These pushrods toasted themselves after just three dyno pulls. I do have pushrod oiling lifters but I didn't order pushrods with holes in them for some reason. Not sure why I didn't but that mistake cost me a set of pushrods. Doesn't seem to be any other damage.
Re: Trick Flow heads [Re: fast68plymouth] #2146798
09/03/16 02:17 PM
09/03/16 02:17 PM
Idaho
LaRoy Engines Offline
Idaho
Harland Sharp sent me some rocker arms with the adjuster screws rough machined on the balls. Small pieces were breaking/grinding off and my pushrods looked exactly like that with 780 lbs over the nose. They were kind enough to sell me some new properly machined adjusting screws and I had no more problems. You probably were smart enough to check the screws before assembly and that might not be your problem.
Re: Trick Flow heads [Re: fast68plymouth] #2146827
09/03/16 03:46 PM
09/03/16 03:46 PM
AndyF Offline
AndyF  Offline
I don't think that is the problem, I looked at the adjusters and they appear to be in good shape. One possibility is that I have the adjusters backed all the way off in order to improve geometry so perhaps the oil squirt from the hole in the rocker is missing the cup? Maybe a shorter pushrod would work okay? I'm just going to order pushrods with oiling and put it back together. I know that pushrod oiling solves the problem I'm not so sure about the oil squirt theory.
Re: Trick Flow heads [Re: AndyF] #2146887
09/03/16 05:59 PM
09/03/16 05:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
pushrods are too long....putting the cup too high not enough oil running down into the cup my twocents. Pushrod oiling will solve it though. Just not needed. When I saw the first picture I said to myself "why so much thread above the adjuster nut?" Then I saw the underside.
Re: Trick Flow heads [Re: fast68plymouth] #2146899
09/03/16 06:29 PM
09/03/16 06:29 PM
AndyF Offline
AndyF  Offline
Could be but if the adjuster hangs out very far below the rocker arm then it kicks back and forth rather than go up and down. But perhaps people live with that rather than go with pushrod oiling. Still seems like at some point you need the pressure fed oil rather than rely on splash. 750 lbs over the nose is a lot of force to just use splash oiling.
Re: Trick Flow heads [Re: fast68plymouth] #2146973
09/03/16 08:44 PM
09/03/16 08:44 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Wow! eek
72 Plymouth Roadrunner 11.08@123.25
Re: Trick Flow heads [Re: AndyF] #2147044
09/03/16 10:53 PM
09/03/16 10:53 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
This is good to find out about before I order my pushrods, sorry you had to burn up a set to find this out, did you restrict the oil to the head/rocker's and if so by how much, I just made and installed .040 restrictors in my block passage but the heads are not back from the shop getting the new PAC springs installed for the roller cam and having the guides inspected and/or corrected, so the orifice can be changed quickly before I install the head's.
Re: Trick Flow heads [Re: AndyF] #2147216
09/04/16 11:19 AM
09/04/16 11:19 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
750 over the nose really isn't that much pressure.... I am over that (well my valve spring set up anyway grin ) and I am sure there is a majority on here doing it with splash. up
Re: Trick Flow heads [Re: B1MAXX] #2147260
09/04/16 12:56 PM
09/04/16 12:56 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
First thing I thought also - that high up the squirt of oil misses the cup entirely. never had an issue with Harlan Sharpes oiling at close to 950lbs over the nose even with the old 1.65 they offered - but push rod oiling will fix it either way
Re: Trick Flow heads [Re: fast68plymouth] #2147346
09/04/16 03:16 PM
09/04/16 03:16 PM
AndyF Offline
AndyF  Offline
I'll see if I can post a video of a pull:
https://youtu.be/UDuRWlNsjok
Re: Trick Flow heads [Re: AndyF] #2147466
09/04/16 06:31 PM
09/04/16 06:31 PM
Jamie McGrath Offline
Way too go Andy, I liked the rocker arm vid!!
Re: Trick Flow heads [Re: AndyF] #2147514
09/04/16 08:06 PM
09/04/16 08:06 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Looked like a touch over 700? What was the intake carb combo on that pull?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Trick Flow heads [Re: 68 HEMI GTS] #2147537
09/04/16 08:38 PM
09/04/16 08:38 PM
AndyF Offline
AndyF  Offline
Yeah the console reads a little over 700 but the printed report says 700 exactly. That is with the Trick Flow intake and a 1050AN carb from QuckFuel. (4150 style carb)
The Dominator combo should be worth 15 to 20 more but I haven't bolted it back on yet. Still trying to figure out the best rocker system to use.
Re: Trick Flow heads [Re: fast68plymouth] #2151783
09/10/16 07:30 PM
09/10/16 07:30 PM
AndyF Offline
AndyF  Offline
Here are the results with my 950 Dominator carb. Intake #1 is the as cast Mopar 4500 M1, intake #2 is a Wilson ported M1 4500.
Re: Trick Flow heads [Re: AndyF] #2151796
09/10/16 08:07 PM
09/10/16 08:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Andy, are you still going to test the M1 tunnel ram?
Re: Trick Flow heads [Re: fast68plymouth] #2151850
09/10/16 09:27 PM
09/10/16 09:27 PM
AndyF Offline
AndyF  Offline
Yep, just need to build the various brackets for the throttle linkage and stuff like that.
Re: Trick Flow heads [Re: fast68plymouth] #2151918
09/10/16 11:16 PM
09/10/16 11:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
So the intake makes 30 more HP..wow
Re: Trick Flow heads [Re: fast68plymouth] #2151941
09/10/16 11:46 PM
09/10/16 11:46 PM
AndyF Offline
AndyF  Offline
Yep, right at 30 hp improvement from the porting that Wilson did on the intake. This was a back to back test with everything else staying the same. All the gain is from 5500 rpm up so you wouldn't notice it on a street car but a drag car that leaves at a high rpm would notice it.
Re: Trick Flow heads [Re: AndyF] #2151960
09/11/16 12:00 AM
09/11/16 12:00 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Awesome!
Don't know if you saw the results or not but my 505 picked up a tenth and 1mph using a Holly Street Dominator that was ported by Streetwize vs. A stock one. In my estimation it was 12-13HP? Sound correct? Motor is all done by ~6300 rpm.
As an interesting aside, I also tried back to back runs with K&N vs. no air cleaner at all and the car ran identical 11.41 times.
Re: Trick Flow heads [Re: fast68plymouth] #2152106
09/11/16 03:44 AM
09/11/16 03:44 AM
Earth
Rob C Offline
Rob C  Offline
Earth
IMO, more than 30hp for a tenth, a lot more.
