Page 2 of 4 1 2 3 4
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149027
09/06/16 06:58 PM
09/06/16 06:58 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If max hp is at 9000rpm why are you shifting at 8700?
I don't know a thing about W7 engines but 900hp sounds a little optomistic.
Re: How much are my small headers killing my performance [Re: GomangoCuda] #2149148
09/06/16 09:19 PM
09/06/16 09:19 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
[quote=GomangoCuda]If max hp is at 9000rpm why are you shifting at 8700?
ounds a little optomistic. [/qu
I got the dyno sheet. I bought it from a well-known super stock racer. Just trying to get it to run like it should
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149223
09/06/16 10:49 PM
09/06/16 10:49 PM
AndyF Offline
AndyF  Offline
In that case you should be able to ask the guy you bought the engine from what headers you should use. Anyone who runs superstock probably has a garage full of headers that they have tried. Might even be able to buy his set from last year and save yourself some money.
Re: How much are my small headers killing my performance [Re: AndyF] #2149228
09/06/16 10:58 PM
09/06/16 10:58 PM
CEDAR RAPIDS
CEDAR RAPIDS
I have the headers that came off of it. They just won't fit my chassis without major modifications. Just wondering if all the work will be worth it they are much larger headers.. I'm running. 1 7/8 now and the other headers are step headers 2 inch 2 1/8. 2 1/4.. with this much horsepower and RPM is it really choking it down that much that's what I'm wondering
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149270
09/06/16 11:55 PM
09/06/16 11:55 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guess is the super stock guy probably wasn't using those headers unless they made more power than anything else he has tried.
I would try and make them work and report back.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149271
09/06/16 11:56 PM
09/06/16 11:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Those headers may be and probably are hurting you some. Whats the rest of the specs on the headers, pipe length and collector diameter and length.
As Poly suggested , you don't need much of a collector length with a stall of 7000 and a peak hp of 9000 rpm. I too want to know why you shift much lower then hp peak. I'm guessing you tried shifting at and above with no difference in ET???
Pipe size has a rule of thumb with exhaust port flow for port velocity for exhaust scavenging. I don't know what a w7 exhaust port flows. But in general, you size it from that. So whats your exhaust W7 ports flow?
Re: How much are my small headers killing my performance [Re: B3422W5] #2149287
09/07/16 12:05 AM
09/07/16 12:05 AM
CEDAR RAPIDS
CEDAR RAPIDS
I think that's going to be the plan for now
Re: How much are my small headers killing my performance [Re: AndyF] #2149291
09/07/16 12:13 AM
09/07/16 12:13 AM
CEDAR RAPIDS
CEDAR RAPIDS
[quote=AndyF]In that case you should be able to ask the guy you bought the engine from what headers you should use. Anyone who runs superstock probably has a garage full of headers that they have tried. Might even be able to buy his set from it
The headers he gave me we're on this motor on his other car. Nothing will bolt directly onto my car it has a tube chassis
Re: How much are my small headers killing my performance [Re: hustlin hoosier] #2149296
09/07/16 12:21 AM
09/07/16 12:21 AM
CEDAR RAPIDS
CEDAR RAPIDS
[quote=hustlin hoosier]We have tried about everything possible with headers and never found over a few hundredths going from what we thought was a great set of headers to what we thought was the worst set of headers. I hope you have better luck chasing et with we exhaust than we did. [/q
How much in diameter did you change the header size
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149301
09/07/16 12:32 AM
09/07/16 12:32 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Several years back Brian( IMM engines) who posts on here ran two different sets of headers on I believe a stroker W2 motor.
Headmans and TTI headers as memory serves me.
There was a 30 or 40 horse difference between them
1.41 best 60 foot
6.60 at 103.90 1/8
Re: How much are my small headers killing my performance [Re: B3422W5] #2149315
09/07/16 12:58 AM
09/07/16 12:58 AM
CEDAR RAPIDS
CEDAR RAPIDS
I wonder if there was a difference in diameter or length or what?
Re: How much are my small headers killing my performance [Re: B3422W5] #2149317
09/07/16 01:00 AM
09/07/16 01:00 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How much are my small headers killing my performance [Re: Plymouth340] #2149585
09/07/16 01:46 PM
09/07/16 01:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
To be running w7 heads in a super stock car, it would have to be one of the modified classes.
The whole car was likely set up around that engine package, and I'm sure part of what the op is seeing is that a class car is often a better, more sophisticated overall "package" than a typical bracket car.
Take a stock eliminator motor out of a good running stocker package and stick it in a similar bracket car and I doubt the ET's would even be close.
Another question I would have is, how close to 900hp was the performance of the car the motor came out of? Did the ET/mph/weight show it to be 900hp?
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150217
09/08/16 09:36 AM
09/08/16 09:36 AM
gregsdart Offline
gregsdart  Offline
Another thought; an SS racer will kill for .02 ET. If he was running the headers that came were in the car he raced, They are probably as good as it gets, but might not show a lot of improvement. The best answer is try it and see. Be ready to tune for them, and find out EXACTLY what stall you have. I was fooled for years because I went by a tach. I am no small block guy, but hear they are sensitive to converters.
Re: How much are my small headers killing my performance [Re: gregsdart] #2150392
09/08/16 03:01 PM
09/08/16 03:01 PM
CEDAR RAPIDS
CEDAR RAPIDS
Yes one thing at a time I will put these headers on and see what happens. I had my converter stall raised from 6500 to 7000 that was all they could get out of my 8 inch converter. 60 footed a couple hundreds better but the ET remain the same
Re: How much are my small headers killing my performance [Re: fast68plymouth] #2150394
09/08/16 03:07 PM
09/08/16 03:07 PM
CEDAR RAPIDS
CEDAR RAPIDS
Yes his car was probably a whole lot better than mine being a super stock car. But what I really want to know is are my headers killing my motor a tremendous amount I'm going to find out over the winter
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150437
09/08/16 04:42 PM
09/08/16 04:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
What did the car the motor came out of weigh, and what was the speed?
IMO not a converter builder, but it seems to me that in order for an 8" converter to be loosened up enough to stall 7000rpm behind a motor with less than 600ft/lbs, it would lose some effeciency in the process.
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150576
09/08/16 07:50 PM
09/08/16 07:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO
Re: How much are my small headers killing my performance [Re: cudaman1969] #2150645
09/08/16 09:30 PM
09/08/16 09:30 PM
CEDAR RAPIDS
CEDAR RAPIDS
That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference.
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150663
09/08/16 10:05 PM
09/08/16 10:05 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it.
Page 2 of 4 1 2 3 4
