Re: B1 MC heads for a 500" RB
[Re: Lifsgrt]
#2148563
09/06/16 03:34 AM
09/06/16 03:34 AM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Defintely go with a centercounter weight crank if the budget allows. They can be WAY lighter also if budget allows. If you have an interference problem then as suggest notch the bores, it is done al the time. 900 with an MC head should be pretty easy. Honestly a set of originals will get that done as well.
[Re: Monte_Smith]
#2148577
09/06/16 04:36 AM
09/06/16 04:36 AM
Posts: 4,258 Canada
WO23Coronet
Canada
Should clear fine...........if it won't, notch the bore. Not the first time that's had to be done. And with the right cam, you WON'T have to spin it to the moon to make it run.
As for stock block rule.........tell em its a 383 car.......LOL!!! Can you expand on this with some general specs? Not doubting, just curious and am wondering.
[Re: Lifsgrt]
#2148960
09/06/16 05:26 PM
09/06/16 05:26 PM
Al_Alguire
Las Vegas
We did a b1 Original motor last year that made peak power at 7000, would not call that spinning it to the moon by any means. I know Jess on here ran a 500" B1 stock block deal in his Dart for years and never spun it hard either. I also have a B1 original head deal here that I have as a spare that made peak at 7200 at 1004 HP.
[Re: WO23Coronet]
#2149047
09/06/16 07:18 PM
09/06/16 07:18 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
As for stock block rule.........tell em its a 383 car.......LOL!!! Can you expand on this with some general specs? Not doubting, just curious and am wondering. What? Bore notching or rpms?...........If you are referring to rpms, for some reason it has become accepted that large heads require big rpm to work and that simply isn't the case. It's all about getting the cam and events right. The 446 I had in my GTX had B-1 MCs. That motor ran great, made good power and never saw 8000 rpm
[Re: Monte_Smith]
#2149300
09/07/16 12:28 AM
09/07/16 12:28 AM
Posts: 4,258 Canada
WO23Coronet
Canada
As for stock block rule.........tell em its a 383 car.......LOL!!! Can you expand on this with some general specs? Not doubting, just curious and am wondering. What? Bore notching or rpms?...........If you are referring to rpms, for some reason it has become accepted that large heads require big rpm to work and that simply isn't the case. It's all about getting the cam and events right. The 446 I had in my GTX had B-1 MCs. That motor ran great, made good power and never saw 8000 rpm What kind of hp were you making? I've just always thought to get the most hp potentialout of a head you can (Max hp deal, what I'm assuming the OP is after) it needs, for lack of a better term, to be "worked" to a certain point, there's a formula that incorporates cross section, cu in, and rpm (preaching to the choir here). For a given cross section and displacement, you'll need to turn x rpm to get max hp, that's all I was getting at. I'm sure the formula is a generalization as well. Not doubting you can't get big hp with mild displacement without having to spin it to the moon, but to get max hp wouldn't you have to buzz it pretty hard?
[Re: Al_Alguire]
#2154154
09/14/16 01:03 AM
09/14/16 01:03 AM
Posts: 5,620 long island NY
Ari440
long island NY
We did a b1 Original motor last year that made peak power at 7000, would not call that spinning it to the moon by any means. I know Jess on here ran a 500" B1 stock block deal in his Dart for years and never spun it hard either. I also have a B1 original head deal here that I have as a spare that made peak at 7200 at 1004 HP. What ci was the spare motor Same motor in the valiant you had ?
1.39 9.85 - 137 mph
[Re: camastomcat]
#2154163
09/14/16 01:14 AM
09/14/16 01:14 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Center counter weighted. Notice all of the counterweights are the same size. Good Lawd that is purty!
Mopar to the bone!!!
[Re: Al_Alguire]
#2207370
12/04/16 02:23 AM
12/04/16 02:23 AM
Posts: 248 near St Petersburg, FL
Lifsgrt
Man, that crankshaft is artwork! I can get a billet center weighted crankshaft from Ohio Crankshaft for $1650. I will build the engine to turn 8500 or so if it makes power there, but will be happy to turn much less. Any recommendations on cam selection will be helpful. The heads I got from Tom have individual T&D rockers, so I should be good there. TTI builds headers for B1 heads in a B-body, so I plan to run those. They are 2 1/8" to 2 1/4" step with 4" merge collectors. That oughta do it. Planning to run with a 1250 Dominator I have due to the high DA of 7700'. Thoughts?
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
[Re: Lifsgrt]
#2207374
12/04/16 02:30 AM
12/04/16 02:30 AM
Lifsgrt
By the way, that Ohio Crankshaft has no register on the back, just a flat surface. I assume this is no problem and it will register on the bolts? Thanks
[Re: Lifsgrt]
#2207376
12/04/16 02:31 AM
12/04/16 02:31 AM
Lifsgrt
Anybody try to put over 900hp through a Viper 6-speed? Not on a dragstrip, but in a Bonneville Salt Flats type environment? Thanks
[Re: Lifsgrt]
#2207410
12/04/16 05:02 AM
12/04/16 05:02 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
[Re: Lifsgrt]
#2208560
12/06/16 02:57 AM
12/06/16 02:57 AM
Lifsgrt
Fellas, just a follow up. The B1 MC heads with 2.4" intake valves clear these 4.360" bores (not final). I'm sure the proximity is less than optimum for shrouding, but they clear by a good margin. Now to spec the right cam!
[Re: Lifsgrt]
#2208564
12/06/16 03:02 AM
12/06/16 03:02 AM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Fellas, just a follow up. The B1 MC heads with 2.4" intake valves clear these 4.360" bores (not final). I'm sure the proximity is less than optimum for shrouding, but they clear by a good margin. Now to spec the right cam! Tom Hemphile may be a good guy to call about a cam
[Re: Lifsgrt]
#2208675
12/06/16 01:16 PM
12/06/16 01:16 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Looking at that crank is like look'n in Play Boy used to be, you want it but you know you can't get it or maybe I'm getting old, but it's sweet!
Have a great day Iowan
"obsolete is neat"
[Re: Lifsgrt]
#2353213
08/13/17 02:25 PM
08/13/17 02:25 PM
Lifsgrt
Update- decided to go with THE block (which I have received),at 4.500" bore and 3.915" stroke to net 499". Machine work is being done and engine built by Best Machine, as I'm sure Chuck and Pete will make way more power than I could. Will be using a motor plate to fit a dry sump pump. Still shooting for 950hp+ NA. As of now, I'm inside of a year to have the car built...should be a piece of cake!
[Re: Lifsgrt]
#2353246
08/13/17 03:23 PM
08/13/17 03:23 PM
Cab_Burge
By the way, that Ohio Crankshaft has no register on the back, just a flat surface. I assume this is no problem and it will register on the bolts? Thanks That type flange is like all the early Mopars had, Top fueler cranks are still built that way. The flywheel or converter centers over the outside edge of the flange ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Do not ever count on using the bolts to hold the flywheel without a centering register ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
