Page 4 of 6 1 2 3 4 5 6
Re: How to block off heat riser ports [Re: Bill MeLater] #214766
02/16/09 11:44 PM
02/16/09 11:44 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
If you are dealing with unknowns, such as intake port/head angles try making a template of the intake side of the heads on the motor w/the intake removed. Then make a template of the intake, compare them and adjust angles/mounting holes/ports as needed. Certainley not high tech but will get the results you're looking for..
thats what i was doing. I took the old gasket (.040 thick) and saw the intake was riding .100" above the port opening in the gasket. the gasket fits on the head port perfectly. SO i was trying to use that .100" measurement to calculate how much to cut it but that requires the intake angle.
I found something here http://victorylibrary.com/mopar/intake-mill-c.htm but Im not sure what to make of it yet. it says -3 degrees but -3 to what???
Re: How to block off heat riser ports [Re: aarcuda] #214767
02/17/09 12:03 AM
02/17/09 12:03 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
What I meant was to make an actual template. Take a piece of sheetmetal/plastic/stiff cardboard and cut it to fit the intake side of your heads w/them on the block. Then do the same with the bottom/intake side of your intake manifold. This will give you actual "parts" you can lay flat on a table (overlay) and will allow you to determine where your problem lies. I suck at explaining things so if this dosen't make sense pm me..
Re: How to block off heat riser ports [Re: Bill MeLater] #214768
02/17/09 03:54 PM
02/17/09 03:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Isn't a 340 6bbl manifold aluminum? Just weld it up before you surface the heads and it will look like there was never a passage there.
On iron intakes I use epoxy and never had one burn through. It is the flow of gas through there that will make it get super hot, if %100 of the flow is blocked it will not get that hot.
As for the burning through stainless gaskets, it won't if you block the tiny hole they made in it, a screw and nut with permanant lock tite works for me.
Re: How to block off heat riser ports [Re: HotRodDave] #214769
02/17/09 04:45 PM
02/17/09 04:45 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Well, after reading this thread several times, I am getting gaskets with the blocked off passages, and stuffing the INTAKE with foil. That way, they foil can't go anywhere, and I can goop the ends near the heads with Copper RTV. This should keep the majority of the heat out I would say, a lot better than doing nothing! Worth a try!
Re: How to block off heat riser ports [Re: aarcuda] #214770
02/18/09 10:27 AM
02/18/09 10:27 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i may be welding the ports in the intaake closed. i need to cut it anyways... stay tuned for updates
Re: How to block off heat riser ports [Re: aarcuda] #214771
02/18/09 09:13 PM
02/18/09 09:13 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That will keep that heat out of there.
Re: How to block off heat riser ports [Re: JohnRR] #214772
02/18/09 11:00 PM
02/18/09 11:00 PM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
i have checked mine with a temp gun at the base of the intake crossover passage. 150 degrees @ idle and a funcuntional crossover fulley warmed up.
Re: How to block off heat riser ports [Re: Nick Mineau] #214773
02/21/09 11:35 PM
02/21/09 11:35 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
so this is what i did today. I cut out some patches out of .100" aluminum and had them welded in to the crossover slots. looks good so far. I'm going to have the intake surfaces milled down next week and i'll post more pics after its done.
Re: How to block off heat riser ports [Re: aarcuda] #214774
02/21/09 11:37 PM
02/21/09 11:37 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
and the other side
Re: How to block off heat riser ports [Re: aarcuda] #214775
02/21/09 11:42 PM
02/21/09 11:42 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i also added this to keep the hot oil off the bottom of the intake.
Re: How to block off heat riser ports [Re: aarcuda] #214776
02/21/09 11:43 PM
02/21/09 11:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Looks like a good solution.
I would just file those down by hand rather than pay to have it done, but either way is fine.
Re: How to block off heat riser ports [Re: aarcuda] #214777
02/21/09 11:44 PM
02/21/09 11:44 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i checked on my solid can for wear (i have about 1000 miles on the 416 so far).
Re: How to block off heat riser ports [Re: aarcuda] #214778
02/21/09 11:45 PM
02/21/09 11:45 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i guess this is normal..
Re: How to block off heat riser ports [Re: Neil] #214779
02/21/09 11:46 PM
02/21/09 11:46 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i need to have both side cut .035" anyways so i'm good with letting the shop handle it
Re: How to block off heat riser ports [Re: aarcuda] #214780
02/21/09 11:47 PM
02/21/09 11:47 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
its going to run hard with the ports lined up right. i matched the intake to the gasket and got a nice smooth transition going.
Re: How to block off heat riser ports [Re: aarcuda] #214781
02/21/09 11:56 PM
02/21/09 11:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Cam is fine.
Re: How to block off heat riser ports [Re: Neil] #214782
02/22/09 12:49 PM
02/22/09 12:49 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
so if after 1000 miles, my cam is fine, I assume I won't have to worry too much about it (as long as I keep running the zinc encrusted oil). Ive been running Valvoline VR1 with either the zddplus or the hughes extreme pressure additive (I bought a case of the stuff)
Re: How to block off heat riser ports [Re: aarcuda] #214783
02/22/09 08:38 PM
02/22/09 08:38 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Nice work on blocking off those heat passages.
Re: How to block off heat riser ports [Re: 69Cuda340S] #214784
02/22/09 08:53 PM
02/22/09 08:53 PM
swamps of florida
beepsalot Offline
beepsalot  Offline
swamps of florida
i've also found that after heads are milled, the end seals are useless. use a good bead of rtv for that. it will make thing line up easier. my LRT(lil rat truck)is donr like that beeps
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
Re: How to block off heat riser ports [Re: beepsalot] #214785
02/22/09 09:02 PM
02/22/09 09:02 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i havent been able to use those end seals EVER. Ive always used the permatex rtv. theres just not enough room for those seals
