Page 1 of 4 1 2 3 4
B1 MC heads for a 500" RB #2147713
09/04/16 11:54 PM
09/04/16 11:54 PM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
I need some help determining if I can run B1 MC heads on a factory 440 block with a 4.375 or less bore (currently 4.350). Other than shrouding, any issues with interference with the 2.4 Int valves?
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147717
09/04/16 11:58 PM
09/04/16 11:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Not really what your asking but those heads will flow way beyond what a stock block will handle hp wise. And at 500" you'll have to turn the piss out of it
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2147750
09/05/16 12:36 AM
09/05/16 12:36 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Stock block required for the class. I plan billet aluminum caps and a girdle to shore up the bottom end, wanting to get 900 or so out of it. Just need to know if the 2.4" intake valves will work in a 4.350 bore AND if they'll be worse than smaller valves for a 500" bullet. I am buying used heads if they'll work, thanks.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147764
09/05/16 12:59 AM
09/05/16 12:59 AM
Dude, buy yourself a good 400 block to start with, no amount of bandaids are going to fix that stock 440 block main webbing tsk scope twocents I've seen 440 blocks break and crack the main webbing between the cylinders at 700 HP with good parts shock puke
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147784
09/05/16 01:51 AM
09/05/16 01:51 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Cab,
It's a rule in his class to have an original block for the year car he is racing. Any idea if a 4.350 bore will fit a 2.400 intake valve?
Re: B1 MC heads for a 500" RB [Re: camastomcat] #2147801
09/05/16 03:05 AM
09/05/16 03:05 AM
No idea at all, sorry.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147816
09/05/16 04:47 AM
09/05/16 04:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Should clear fine...........if it won't, notch the bore. Not the first time that's had to be done. And with the right cam, you WON'T have to spin it to the moon to make it run.
As for stock block rule.........tell em its a 383 car.......LOL!!!
Re: B1 MC heads for a 500" RB [Re: Monte_Smith] #2147878
09/05/16 10:21 AM
09/05/16 10:21 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I can use any factory block size that was available in the car. It doesn't have to be the correct year, but I can't use a 400 or 360 block for instance in a 1969 car.
Thanks for the replies.
Re: B1 MC heads for a 500" RB [Re: Monte_Smith] #2147884
09/05/16 10:29 AM
09/05/16 10:29 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
A grinder and JB weld makes "383" numbers on the side of the block rather easily if anyone gets nosy..
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147894
09/05/16 10:47 AM
09/05/16 10:47 AM
Idaho
LaRoy Engines Offline
Idaho
Call Koffels. Just testing by hand I've had 2.30 valves hit a 4.375 bore at .680" lift in factory iron heads. Original B1 have the valves moved a small amount, don't know about the B1 MC heads.
Re: B1 MC heads for a 500" RB [Re: LaRoy Engines] #2147921
09/05/16 11:40 AM
09/05/16 11:40 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks Jim
Re: B1 MC heads for a 500" RB [Re: GY3] #2147924
09/05/16 11:42 AM
09/05/16 11:42 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Good point!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2147954
09/05/16 12:23 PM
09/05/16 12:23 PM
gregsdart Offline
gregsdart  Offline
Consider a center weighted crank. It greatly reduces the stress shifted to the inner bearings because the counter weights are more in line with the forces they are offsetting. I saw the cap walk go away in a Megablock I have when I went to a center weighted crank, and the bob weight is 2432, pretty heavy. The cost difference is around 2500 for a crower, been a long time since I bought mine so it may be higher, but worth every dime for a project like yours. If you can use a 400 block, and lighten the rotating assembly as much as possible, the deal might live a decent life.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: B1 MC heads for a 500" RB [Re: gregsdart] #2147989
09/05/16 01:08 PM
09/05/16 01:08 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks Greg
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2148173
09/05/16 05:47 PM
09/05/16 05:47 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
The center counter weighted crankshaft makes good sense. I wasn't thinking about that this morning, but have heard a lot people say what Greg just did.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2148236
09/05/16 07:17 PM
09/05/16 07:17 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Have you considered doing Darton sleeves? I know in a normal build it doesn't make sense but for a stock block class that you're obviously set on kill for it might make sense. Btw, there have been legit reports of 383's using 400 castings when the crossover was happening........I think for warranty blocks they used 400 castings. A 400 with Darton sleeves would get it done
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2148381
09/05/16 09:47 PM
09/05/16 09:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm unfamiliar with the term "center weighted crank".
Can someone please explain?
Re: B1 MC heads for a 500" RB [Re: GY3] #2148405
09/05/16 10:32 PM
09/05/16 10:32 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Good stuff, thanks fellas, keep it coming!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2148442
09/05/16 11:30 PM
09/05/16 11:30 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Center counter weighted. Notice all of the counterweights are the same size.
Re: B1 MC heads for a 500" RB [Re: camastomcat] #2148470
09/05/16 11:48 PM
09/05/16 11:48 PM
That sure is pretty bow Polished and lightweight, maybe not a ultra lightweight, but lighter than ones I've weighed up Tom, how long is the stroke on this one?
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2148526
09/06/16 12:57 AM
09/06/16 12:57 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
It's the one in my 604 Predator Cab. The stroke is 4.625.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2148563
09/06/16 02:34 AM
09/06/16 02:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Defintely go with a centercounter weight crank if the budget allows. They can be WAY lighter also if budget allows. If you have an interference problem then as suggest notch the bores, it is done al the time. 900 with an MC head should be pretty easy. Honestly a set of originals will get that done as well.
Re: B1 MC heads for a 500" RB [Re: Monte_Smith] #2148577
09/06/16 03:36 AM
09/06/16 03:36 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Can you expand on this with some general specs? Not doubting, just curious and am wondering.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2148960
09/06/16 04:26 PM
09/06/16 04:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We did a b1 Original motor last year that made peak power at 7000, would not call that spinning it to the moon by any means. I know Jess on here ran a 500" B1 stock block deal in his Dart for years and never spun it hard either. I also have a B1 original head deal here that I have as a spare that made peak at 7200 at 1004 HP.
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2149047
09/06/16 06:18 PM
09/06/16 06:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What? Bore notching or rpms?...........If you are referring to rpms, for some reason it has become accepted that large heads require big rpm to work and that simply isn't the case. It's all about getting the cam and events right.
The 446 I had in my GTX had B-1 MCs. That motor ran great, made good power and never saw 8000 rpm
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2149232
09/06/16 10:04 PM
09/06/16 10:04 PM
gregsdart Offline
gregsdart  Offline
What cam duration , lift and lsa worked well in the smaller motors? Care to share?
Re: B1 MC heads for a 500" RB [Re: Monte_Smith] #2149300
09/06/16 11:28 PM
09/06/16 11:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of hp were you making? I've just always thought to get the most hp potentialout of a head you can (Max hp deal, what I'm assuming the OP is after) it needs, for lack of a better term, to be "worked" to a certain point, there's a formula that incorporates cross section, cu in, and rpm (preaching to the choir here). For a given cross section and displacement, you'll need to turn x rpm to get max hp, that's all I was getting at. I'm sure the formula is a generalization as well. Not doubting you can't get big hp with mild displacement without having to spin it to the moon, but to get max hp wouldn't you have to buzz it pretty hard?
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2154154
09/14/16 12:03 AM
09/14/16 12:03 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
What ci was the spare motor
Same motor in the valiant you had ?
1.39 9.85 - 137 mph
Re: B1 MC heads for a 500" RB [Re: camastomcat] #2154163
09/14/16 12:14 AM
09/14/16 12:14 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Good Lawd that is purty!
Mopar to the bone!!!
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2207370
12/04/16 01:23 AM
12/04/16 01:23 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Man, that crankshaft is artwork! I can get a billet center weighted crankshaft from Ohio Crankshaft for $1650. I will build the engine to turn 8500 or so if it makes power there, but will be happy to turn much less. Any recommendations on cam selection will be helpful. The heads I got from Tom have individual T&D rockers, so I should be good there. TTI builds headers for B1 heads in a B-body, so I plan to run those. They are 2 1/8" to 2 1/4" step with 4" merge collectors. That oughta do it. Planning to run with a 1250 Dominator I have due to the high DA of 7700'. Thoughts?
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2207374
12/04/16 01:30 AM
12/04/16 01:30 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
By the way, that Ohio Crankshaft has no register on the back, just a flat surface. I assume this is no problem and it will register on the bolts? Thanks
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2207376
12/04/16 01:31 AM
12/04/16 01:31 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Anybody try to put over 900hp through a Viper 6-speed? Not on a dragstrip, but in a Bonneville Salt Flats type environment? Thanks
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2207397
12/04/16 02:24 AM
12/04/16 02:24 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I think the traction on the sand would be better with a converter, and you don't want to use just the bolts to locate the flexplate or flywheel. You have someone make you a plug that goes into the back of the crankshaft the same size as the collar on your forged crankshaft that locates the flexplate/flywheel. I'm sure Ohio Crankshaft can make one.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2207410
12/04/16 04:02 AM
12/04/16 04:02 AM
Keith Black Enterprises, 562-869-1518, makes and sells a billet steel adapter for use on the top fuel crank with no built in register that presses into them that has the proper I.D., O.D and depth for using and locating the later model torque converter hubs in them. I wouldn't try to use the later model stick shift flywheels on them tsk twocents Buy the early type flywheel that centers on the outer crankshaft flanges properly scope thumbs
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2208560
12/06/16 01:57 AM
12/06/16 01:57 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Fellas, just a follow up. The B1 MC heads with 2.4" intake valves clear these 4.360" bores (not final). I'm sure the proximity is less than optimum for shrouding, but they clear by a good margin. Now to spec the right cam!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2208564
12/06/16 02:02 AM
12/06/16 02:02 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Tom Hemphile may be a good guy to call about a cam
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2208675
12/06/16 12:16 PM
12/06/16 12:16 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Looking at that crank is like look'n in Play Boy used to be, you want it but you know you can't get it or maybe I'm getting old, but it's sweet!
Have a great day
Iowan
"obsolete is neat"
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2215578
12/17/16 11:50 AM
12/17/16 11:50 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Recieved one from Iowa! Thanks
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353213
08/13/17 01:25 PM
08/13/17 01:25 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Update- decided to go with THE block (which I have received),at 4.500" bore and 3.915" stroke to net 499". Machine work is being done and engine built by Best Machine, as I'm sure Chuck and Pete will make way more power than I could. Will be using a motor plate to fit a dry sump pump. Still shooting for 950hp+ NA. As of now, I'm inside of a year to have the car built...should be a piece of cake!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353246
08/13/17 02:23 PM
08/13/17 02:23 PM
That type flange is like all the early Mopars had, Top fueler cranks are still built that way. The flywheel or converter centers over the outside edge of the flange scope
Do not ever count on using the bolts to hold the flywheel without a centering register tsk
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353323
08/13/17 06:22 PM
08/13/17 06:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A 383 was around then right.................. work
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353332
08/13/17 06:50 PM
08/13/17 06:50 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What happened to the stock block rule?
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353337
08/13/17 07:12 PM
08/13/17 07:12 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would think they would make more like over a 1000 HP easy Jerry. You will be turning it up in the RPM range, like 9000+ though I would think.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353567
08/14/17 11:35 AM
08/14/17 11:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That's 25" smaller than my M/C deal was that ultimately got well over 1050hp. Don't see 950 being to difficult as mine was far from a max effort deal. Went 171 in a 2975lb car so you can do your own math.
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2353799
08/14/17 05:48 PM
08/14/17 05:48 PM
dogdays Offline
dogdays  Offline
The Bonneville Salt Flats is, IIRC, 4200 feet elevation. That's an automatic 15% derate in horsepower.
Oh, rats, I see you've already covered the Density Altitude of 7700 feet.
5280 is -20% at standard temp and pressure, so the 7700 would be something like 33%?
R.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353830
08/14/17 06:31 PM
08/14/17 06:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Well, I live and race here. It's not 33%, more like 15% in 8500 ft corrected.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2353876
08/14/17 08:01 PM
08/14/17 08:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think more people need to come and experience what we get to experience out the west. A lot of things go into factoring a DA. I don't think they understand the barometer is 25 there...It has a way of kinda killing an NA car. I don't know the correction factor for RMR but it has to be .95XX given the altitude. Even NHRA slows indexes down .45 seconds there..
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2353979
08/14/17 11:09 PM
08/14/17 11:09 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Rulebook says same material as original block, all OE parts must bolt up, etc. I'm going with close enough. Didn't want to build a time bomb 400 block. This block is approved for NHRA SS as I understand it, so I'm rollin' with that.
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2354146
08/15/17 10:48 AM
08/15/17 10:48 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
seconds there..
Last correction factor was 1.27 at 8150 ft corrected. The car is typically .3 slower from Las Vegas, and there is a whole bunch of variation there.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2354164
08/15/17 11:22 AM
08/15/17 11:22 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well and we both know Vegas is at least .2 slower than most tracks. Poorly tuned combos will be even slower. But its a fun experience in all the thin air around here. I know we are celebrating if the barometer reached 28, its party time and we are gonna FLY!!!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2354429
08/15/17 06:54 PM
08/15/17 06:54 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Right on, that makes it easier! (originally it looked like you needed to use a stock block)
Re: B1 MC heads for a 500" RB [Re: WO23Coronet] #2577786
11/13/18 12:48 AM
11/13/18 12:48 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
So, the 499" Bonneville bullet based on a B "THE BLOCK" is almost finished at Best Machine Racing Engines. Unfortunately, I need to bring it home to FL, install and plumb the dry sump and have headers built prior to taking it back for the dyno session, so the numbers will still be a while. Hoping for 1000hp NA. It has been and continues to be a long road, but still planning to make Speed Week 2019!
46099014_1982787495110257_6465589156889231360_n.jpg46099014_1982787495110257_6465589156889231360_n.jpg45322733_1973239259398414_2462041233078353920_n.jpg
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577792
11/13/18 01:03 AM
11/13/18 01:03 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I've been watching the build at Best and it sure is a nice piece. You picked a great shop to do the build and I'm sure you will be more then pleased.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577816
11/13/18 03:47 AM
11/13/18 03:47 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Hey Jerry,
New Bullet looks fantastic....i'm sure it'll run just as good as it looks !
Sent you a PM wave
Ron
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577988
11/13/18 04:06 PM
11/13/18 04:06 PM
K
KOS Offline
KOS  Offline
K
whats the deal with the water pump and belt driven distributor?do you have spacers to push it forward?its hard to tell in the pic.nice build btw
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2577998
11/13/18 04:42 PM
11/13/18 04:42 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
that's a nice piece. Chuck knows how to make HP for sure! I bet it makes more than 1000. Best of luck
....BAD A$$ STREET CAR.....
Re: B1 MC heads for a 500" RB [Re: n20mstr] #2755022
03/23/20 12:25 PM
03/23/20 12:25 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
These heads proved to work well for this 498" B-block endurance build. Made 947hp @7400rpm and 690tq@6800rpm on Best Machine's dyno.
KOS, not sure about spacers, I think the motor plate takes care of it. Best Machine could answer that.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755027
03/23/20 12:34 PM
03/23/20 12:34 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
KOS, I went with the Jesel timing belt drive and distributor based on Best Machine's recommendation. Timing belt due to cam and valvetrain harmonics, and the distributor to have a bigger cap to lessen likelihood of crossfiring. This engine will be WOT for up to two plus minutes at a time.
The Meziere water pump I chose because of flow rating and to free up some power. After going down this path, I spoke with Meziere and they said a mechanical pump would have been better...so time will tell. I did get a custom Saldana radiator for this project, so hopefully it will work.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755052
03/23/20 01:44 PM
03/23/20 01:44 PM
Do you think you will make it out here this year? If so the early SCTA race or the later BNI race?
How hard is it to get a room when the races are on?
I'm still watching you on this up
I decided to not try and make the car I wanted to build after they both drop the all wheel drive classes whiney
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2755149
03/23/20 05:02 PM
03/23/20 05:02 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Yes, if Speed Week occurs I plan to be there. Still need a few bits and pieces (driveshaft, a pair of 28" Moroso DS-2s, and a fee other odds and ends), and have a ton of work to do, but I have most all the systems to get it together, just have to get it all installed. I am focussing on it to try and get it done this year, at least for the maiden run!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755799
03/25/20 12:10 PM
03/25/20 12:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lets see some pictures of the car!!!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2755806
03/25/20 12:26 PM
03/25/20 12:26 PM
What is the cut off speed now on requiring approve Bonneville high speed tires?
How hard and expensive are those tires to get now?
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2756030
03/25/20 07:42 PM
03/25/20 07:42 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I've been 193mph on old Moroso DS-2s, so I'm going with those (new ones). I need to get a pair of 28" tires, as my math gets me to 240+ with those and a 2.47 geared 9" rear axle. The lowest I can find for an 8 3/4" is 2.76s, and even Moroso doesn't recommend their 29" skinnies for Land Speed use. I have an old pair 29" tires with very good tread, but not sure it is a good idea to use them. I plan to use an 18 spline 833 but am not sure if it will shift quickly around 7500rpm.
Actual land speed tires are very expensive and only produced occasionally. I am confident the DS-2s will be fine at 240mph or so.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2756036
03/25/20 08:24 PM
03/25/20 08:24 PM
You might want to check with both BNI and SCTA tech about those tires being okay for speeds above 175 MPH twocents
Last time I called them they wanted the Bonneville approved above 175 MPH specific tires only to get through tech, the expensive ones whiney
Re: B1 MC heads for a 500" RB [Re: Cab_Burge] #2756066
03/25/20 10:48 PM
03/25/20 10:48 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I ran 193mph at Bonneville in a friend's car that cruises through tech with DS-2s, car runs straight although with a power steering box with no power, meanders around a bit. The rulebook goes with speed ratings of the tires for classes up to Z ratings. If the existing record you are contesting is over 200mph, racing specific tires are required and speeds are based on mfgr recommendations. Moroso does not recommend the 29" skinnies for LSR, but up to 28" is okay and have been tested to 300mph with an 800lb load.
I think the LSR specific tires are like $1000 each and are only produced occasionally.
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2756067
03/25/20 10:53 PM
03/25/20 10:53 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Cab, don't be a quitter! up Four wheel drive is ok with SCTA in the 2019 rulebook in Special Construction class or Production Class if the vehicle originally had four wheel drive from the factory!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2756086
03/26/20 12:44 AM
03/26/20 12:44 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
This is the center weighted Crower custom crank, and finally posting dyno numbers!
Dyno Chart 498 Sept 2019.jpgDyno sheet Sept 2019 498.jpg45585069_1973239092731764_5200802287005466624_n.jpg
Re: B1 MC heads for a 500" RB [Re: Al_Alguire] #2756087
03/26/20 12:47 AM
03/26/20 12:47 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I started a new thread with pics just for you Al! Looks like a semi-junky 1970 Charger with her clothes back on!
Re: B1 MC heads for a 500" RB [Re: Lifsgrt] #2756089
03/26/20 01:00 AM
03/26/20 01:00 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Cab, these DS-2s were several years old and they worked fine for me to 193mph. The next time I got in the car it would "only" go 180mph...someone had broken the ceramic on the #1 plug, which fell away resulting in running on a dead cylinder. At 15:1, I couldn't feel it missing, but it killed that piston. The engine was already broke when they put me back in the car to go over 200mph, but that run did it in for sure. The 193mph run was uneventful until the chute didn't open. A lot of cars there do not run front brakes, only rears, including this car, but it slow and stopped before I ran out of track on the long course (7 miles) in 2016.
Page 1 of 4 1 2 3 4
