Page 2 of 6 1 2 3 4 5 6
Re: How to block off heat riser ports [Re: ZIPPY] #214726
02/05/09 06:20 PM
02/05/09 06:20 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
AAR= 6 BBL
Re: How to block off heat riser ports [Re: aarcuda] #214727
02/05/09 06:21 PM
02/05/09 06:21 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
whats the temperature at the opening tothe exhaust port? Lead melts at 600 degrees. It would suck if the lead melted
more than that at WOT
Re: How to block off heat riser ports [Re: JohnRR] #214728
02/05/09 06:34 PM
02/05/09 06:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a picture of one of the heads my brother melted the zinc into. Too bad photobucket is busted or I'd toss it on here.
The heat crossover openings in an Olds head are huge. No way would tin foil or fishing weights do the job.
Re: How to block off heat riser ports [Re: 6pkaar] #214729
02/05/09 06:55 PM
02/05/09 06:55 PM
Do you put the aluminum foil balls in the passage in the head OR the manifold?
In the head, that way the heat was kept off of the gasket & as far away from the carb as possible but actually now that you mention it I believe either would suffice.
Re: How to block off heat riser ports [Re: RapidRobert] #214730
02/05/09 11:18 PM
02/05/09 11:18 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
If I was gonna pound a buncha crap in there I'd back it up with wadded up $100,00 bills so when it finally melts/breaks loose and sucks it into a cylinder I'd at least have the cash on hand to fix it.
Re: How to block off heat riser ports [Re: aarcuda] #214731
02/05/09 11:30 PM
02/05/09 11:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
AAR= 6 BBL
You may find this page interesting, it reccomends not blocking the crossover on the 340-6;
http://www.hamtramck-historical.com/_1973Hi-PoParts-02.shtml?load_img=26
Re: How to block off heat riser ports [Re: Bill MeLater] #214732
02/05/09 11:36 PM
02/05/09 11:36 PM
New York
K
Ken25 Offline
Ken25  Offline
K
New York
on my 440 i welded the ports on the intake and plan on using the blocked valley pan.i use yamabond case sealer.i plan on running engine coolant in the port on the intake side for the winter and turn the valve of when it gets warmer
Re: How to block off heat riser ports [Re: Ken25] #214733
02/06/09 01:25 AM
02/06/09 01:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I always have my intake heat riser ports welded shut. Ron
Re: How to block off heat riser ports [Re: 383man] #214734
02/06/09 01:57 AM
02/06/09 01:57 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
When I did my 360 I couldn't find a gasket with it blocked off like you did, but for some reason the fel-pro gasket kit I had came with 2 extra 318 gaskets with the cross over blocked. So I cut that part out with some snips and used some rtv to them hold onto the head while I put the intake with the regular 360 gaskets on.
About a year later I had the intake off cause I broke a push rod and noticed that the tin had burned through in that time. When I put it back together I didn't bother trying to block it because I figured whatever I used would burn though again anyways, or be too thick and interfere with the intake sealing right.
The best way I would think would be to weld up the crossover itself in the intake as said above.
Re: How to block off heat riser ports [Re: 440newport] #214735
02/06/09 02:42 AM
02/06/09 02:42 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
A friend told me he'd pack the head side with furnace cement.
Keep old mopars alive.
Re: How to block off heat riser ports [Re: Alaskan_TA] #214736
02/06/09 09:50 AM
02/06/09 09:50 AM
AAR= 6 BBL
Haven't read that yet but you do bring up a good point , if he is using the stock choke stove then he'll need the heated passage or it's going to cause issues with the choke opening properly/fully ???
Re: How to block off heat riser ports [Re: JohnRR] #214737
02/06/09 01:03 PM
02/06/09 01:03 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
AAR= 6 BBL
choke? race cars dont have chokes...
this car hasn't had a choke for years. it wasnt there when i bought it in 86 either. The reason I want to block the crossover is because I can hear gas bubbling in the fuel bowls after I shut it off. I am also going to install the valley tray I just ordered (I used to have one and that kept the intake nice and cool).
Since I dont need the chock well, and the paint is starting to blacken near the heads at the crossover, I figured it wouldnt hurt to block em.
Re: How to block off heat riser ports [Re: Bill MeLater] #214738
02/06/09 01:14 PM
02/06/09 01:14 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
That's the funniest retort I've seen in a while, even more so considering the guy's name is Bill MeLater.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: How to block off heat riser ports [Re: aarcuda] #214739
02/06/09 01:57 PM
02/06/09 01:57 PM
sounds like a good reason to block it off then
Re: How to block off heat riser ports [Re: Fury Fan] #214740
02/06/09 10:03 PM
02/06/09 10:03 PM
Wisconsin USA
Wisconsin USA
Thank you...My girlfriend tells me all the time how I'm not funny
Re: How to block off heat riser ports [Re: Fury Fan] #214741
02/06/09 10:09 PM
02/06/09 10:09 PM
Wisconsin USA
Wisconsin USA
I can't really take credit for the name either, got it from all those pesky subscription inserts the magazines have. Take a look they all have it.
Re: How to block off heat riser ports [Re: Bill MeLater] #214742
02/06/09 10:24 PM
02/06/09 10:24 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Lessee. Crudely cast, non-precision blocks - yeah I tried the Felpro deal ; they burned thru.
I just stuffed aluminum foil balls "down thar" - these engines aren't finicky Lamborghinis after all.
Works swell.
Re: How to block off heat riser ports [Re: IronWolf] #214743
02/07/09 10:02 AM
02/07/09 10:02 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am just blerting this out so,couldn't you drill,tap for a pipe plug on the intake side?
Re: How to block off heat riser ports [Re: blownzoom440] #214744
02/07/09 01:21 PM
02/07/09 01:21 PM
There is a Mopar kit that has the intake gaskets with a metal block off plate for each side. Part#P4286569 I have used it with no problems so far.
Re: How to block off heat riser ports #214745
02/08/09 10:28 AM
02/08/09 10:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I filled the crossover on my Edelbrock intake with JB weld. Been working for over 6 years now.
Simply mix up enough to fill the hole, pour it in, tape off the face of the ontake and set the intake so that the tape in down, gravity does the rest. If you find you didn't quite mix up enough it's easy to add more later.
Don't be the exception.
