Re: Can compression hurt power? [Re: AndyF] #21470
01/17/06 07:37 PM
01/17/06 07:37 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My answer would have been a lot different if I knew of the other variables. But the original question was general. Can Compression hurt power. That question by itself I stick with my original response.
But, if you are talking hemi which I know very little about other than you run a hollow dome to keep the piston light due to the huge dome to make compression. I would try and run someththing with the least dome I could and cram all the stroke I could in it making my compression that a way. This theory could be way off due to the hemi-culties but in theory this is the way I would lean.
Re: Can compression hurt power? [Re: moper] #21471
01/17/06 07:46 PM
01/17/06 07:46 PM
Fort Pierce, FL
O
Outlaw10_5 Offline
Outlaw10_5  Offline
O
Fort Pierce, FL
With FAST rules, it would be very hard to get away with the MSD timing contorller ignitions..They neeed a #1 cylinder reference, and the probe will be visible, even if nothing else is.
Only if you want to use the ICT function.
Re: Can compression hurt power? [Re: Outlaw10_5] #21472
01/17/06 08:14 PM
01/17/06 08:14 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
Jeff, for sure I`m just letting you do your thing on this engine. I`m just trying to learn/understand all this. As most people know I`m the 1st guy to ask questions.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Can compression hurt power? [Re: DaveDudek] #21473
01/17/06 10:07 PM
01/17/06 10:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Of course, the irony of a 4 stroke multi cylinder motor is that the compression cycle of the adjacent cylinder takes power generated from it's neighbor on it's power stroke. so increasing compression proportionally increases the internal load on the crank for it to overcome. Normally aspirated, as compression increases, power increases, likely to the motors very ability to maintain seal of the compressed mixture and the heads ability to flow gases in and out. but apples to apples compression alone doesn't tell the whole story, in simplest terms there is likely an optimum combustion chamber and cam timing for each ratio and for any given crank speed. And for example going from 10:1 to 13:1 in a hemi doesn't react like 10:1-13:1 in a wedge, too many variables in static vs dynamic especially with regard to timing events.
WIZE
In Car:
Re: Can compression hurt power? [Re: Streetwize] #21474
04/27/13 09:38 PM
04/27/13 09:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I can't see compression ever hurting power as long as these two variables are maximized. #1 No detonation. #2 Dome/dish/combustion chamber are optimised. A 426 style Hemi is a perfect example where using a large dome to increase compression may be worth less than the power created by an optimized chamber/piston.
Doug
Re: Can compression hurt power? [Re: dvw] #21475
04/27/13 11:04 PM
04/27/13 11:04 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I am convinced there is a point where piston dome shape ends up completely negating a given increase in compression but I think you will find that in this case (changing compression from 12.8:1 to 14:1 while at the same time increasing stroke to 4.25) the piston dome may be smaller. I would consider leaving your piston crown unchanged and changing just the compression height to match the crank and see what you come up with. If it is higher than 14:1 I would consider going with it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Can compression hurt power? [Re: mbogina] #21476
04/27/13 11:06 PM
04/27/13 11:06 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
You cannot make acceptable HP with a huge duration cam in a low compression motor
What would you consider huge duration for a 9-1 470 CI motor?
Re: Can compression hurt power? [Re: LSP] #21477
04/27/13 11:54 PM
04/27/13 11:54 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
i was going to fit the same piston i used in a few s/s engines in daves engine which is 104ish dome,,, would yeild 15.5/1 because the added stroke.
I should have carefully read all the replies, I see Jeff at modern already said same thing and you end up with 15.5:1.
Re: Can compression hurt power? [Re: Rapid340] #21478
04/28/13 09:17 AM
04/28/13 09:17 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ANYONE remember the 366 short-stroke Hemi ?
Re: Can compression hurt power? [Re: dOc !] #21479
04/28/13 09:44 AM
04/28/13 09:44 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
With the ability of a HEMI to overscavenge, I'd pay close attention to the camshaft. Especially in a class that doesn't allow crutching the effect with a properly designed header......or shrinking the ridiculously large exhaust valve diameter.
Has anyone seen a HEMI engine where the entire combination was "worked', actually pick up with cams in the 106/108/110 range vs 114/116/118???
Re: Can compression hurt power? [Re: dOc !] #21480
04/28/13 12:04 PM
04/28/13 12:04 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Those never ran well, a 10.7" deck and 3.218" stroke has ugly written all over it. The combo that did work was the 383 block/hemi head combo, compression was 11.25, cam had 15* shorter exhaust lobe, set the PS speed record before they went to 500" motors.
Re: Can compression hurt power? [Re: DaveDudek] #21481
04/28/13 12:05 PM
04/28/13 12:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"Dynamic compression" is this year's cliche, and greatly over-valued as an effect.
Boffin Emeritus
Re: Can compression hurt power? [Re: polyspheric] #21482
04/28/13 12:13 PM
04/28/13 12:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why do you say that... to me when the intake closes
is when you start the compression... so whats so over
rated about it... to me its more important than just
a math number for the cyl volume
Re: Can compression hurt power? [Re: MR_P_BODY] #21483
04/28/13 12:21 PM
04/28/13 12:21 PM
warren, mich.
dwayne welder Offline
warren, mich.
RIGHT ON MIKE!!!!!!
Re: Can compression hurt power? [Re: DaveDudek] #21484
04/28/13 12:48 PM
04/28/13 12:48 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
More compression helps but narrows the tuning window, meaning the slightest weather change is going to affect everything - most importantly damage happens real quick if you miss!
Listen to Jeff
Re: Can compression hurt power? [Re: Coldart] #21485
04/28/13 04:37 PM
04/28/13 04:37 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Great post guys...
Any comments on the effects of the exhaust restriction from factory manifolds and 2.5" pipe/mufflers on this combo?
My understanding has been that this exhaust restriction is more of a problem at higher RPM's, so perhaps the added stroke will lower peak power range and have less exhaust pumping losses?
More compression should not hurt this.
At almost 500" would this motor not benefit from a wider LSA ??
Good luck with it Dave! IMO your in good hands with Jeff...
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Can compression hurt power? [Re: MR_P_BODY] #21486
04/29/13 12:24 AM
04/29/13 12:24 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It is - until engine speed goes above 1,000 RPM. After this point, and depending on manifold and port volume, inertia, gas speed etc. it approaches rhwn reaches full stroke - at some point before peak torque.
If you still have capture based on IVC anywhere near your power peak your cam is wayyy, wayyy too big.
Boffin Emeritus
Re: Can compression hurt power? [Re: polyspheric] #21487
04/29/13 02:22 AM
04/29/13 02:22 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
When the effort to compress takes more power away than any gain by more compression it is a negative gain.Current NHRA ProStocks are around 15.5 CR,Comp Elim Single four engines around 16.2.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Can compression hurt power? [Re: BIGSPEED] #21488
04/29/13 09:03 AM
04/29/13 09:03 AM
The Great White North
RAMM Offline
RAMM  Offline
It has already been mentioned by guys smarter than me-but I would say that compression will help until the dome gets in the way of flame travel. Also you will need a different camshaft--again pay close attention to this with a big change in compression. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Can compression hurt power? [Re: RAMM] #21489
04/29/13 03:34 PM
04/29/13 03:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
True - the negative effect of dome intrusion on VE can be somewhat reduced by running a narrower LSA.
I don't think the more successful work done with complex chamber shapes has been made public. Hint: there's squish happening during overlap too...
Boffin Emeritus
