Re: Rallye dash wood grain?
[Re: 71TA]
#214640
02/10/09 10:43 AM
02/10/09 10:43 AM
Posts: 577 Spring, Texas
RedFish
super street
super street
Spring, Texas
Thanks James, I was wondering how to do the overlay over the lettering. I have a 73 Cuda and I don't remember there being any graphics on mine. Could be worn off by now. Howard
[Re: THESHAKERPROJECT]
#214641
02/10/09 01:49 PM
02/10/09 01:49 PM
Posts: 2,160 God's Country - Etowah, TN.
A34
I have the reproduction woodgrain bezels many sell (PG Classic/BEA /RTE...)and unless they changed them to make them more correct, I would give them a 7.5 out of 10. The ones I have are very shiney and lack some of the detail of the originals and the anadized part around the outside edge is a tad thicker and the color is off from my originals. Some ot these issues may have been improved by now (got mine from the first run)so I would call Mike at BEA parts as he is likely to have the best set avail. What I did was to use the overlay from Detroit Muscle Tech but to get these overlays to look perfect requires some prep work, patience and skill but when finished correctly, they look very good IMHO. I will try to post a pic when I get a chance today.
I bought the one from BEA because I was in a hurry. No one who restores the dashes could get mine turned around in less than 6-18 months at the time. It was alot of money, but I wanted to drive the car and not wait, so I pulled the trigger.
The Black Plastic bezel is very nice. The woodgrain overlay is too shiny and the end caps didn't fit well. I spoke to Mike about this and he didn't have a good answer for the shiny woodgrain. It's just the way he made it. I think it is fine for a driver car and most "show" cars, but not for an accurate restoration.
As far as who does ones for an accurate restoration, that's up for debate also. I was going to use a guy in Florida, but his name escapes me at the moment. He had an 18 month turnaround.
Kudos to Mike for making some much needed parts, I just wish he'd try to make them a little more accurate.
God Bless America, Our Troops and Their Families !
DEO VINDICE
[Re: A34]
#214642
02/10/09 05:42 PM
02/10/09 05:42 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Mike didn't make them. I have a NOS radio delete plate and frankly although the repop is a little shinier and the color is slightly off, I thought is was very close and the nicest option I've seen to date.
YMMV
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#214643
02/10/09 05:49 PM
02/10/09 05:49 PM
A34
YMMV
Good point. There is a difference in 69 and 70 colors and patterns. He told me he made them. Did he tell you something different?
DEO VINDICE
[Re: A34]
#214644
02/10/09 07:56 PM
02/10/09 07:56 PM
DPelletier
YMMV
Nope, but unless I'm missing something they are the same ones PG Classics in Canada sells. I think they are actually produced overseas. My understanding is that PG gets them reproduced in the far east and imports them and BE&A sells the same stuff in the US. Even though I'm up here in Canada, I've been buying stuff from Mike 'cause he's such a great guy and has stellar customer service.
Anyhow, I'm going to compare my NOS radio delete plate (don't tell Johnrr I called it that! ) with the repop. If I can get a decent pic or two, I'll post them side by side just for giggles.
Cheers, Dave
1974 'Cuda
[Re: DPelletier]
#214645
02/10/09 09:32 PM
02/10/09 09:32 PM
A34
Cheers, Dave
Cool !! Is your plate a 69 or 70? I have several of the 69 dashes used in various conditions. Sold off all my 70 stuff a couple years back. I remember the way the dash looked back in '82 and it wasn't as shiny as the BEA one. Granted it was 13 years old by then, but it was a low mileage always garaged car, so I doubt it had faded that much. I am anxious to see the difference. I think I heard either through Mike or someone else that he used a 70 as the pattern for the woodgrain. Not 100% sure on that though.
DEO VINDICE
[Re: A34]
#214646
02/11/09 12:59 PM
02/11/09 12:59 PM
DPelletier
OK, here goes; - first off, mine is a '70 - secondly, yes the repops are shinier. It is quite apparent in the pics although the flash makes it look a little worse than it is. I think they look good, pretty close, but certainly not close enough to "mix and match" between the originals and repop stuff.
1974 'Cuda
[Re: DPelletier]
#214647
02/11/09 01:01 PM
02/11/09 01:01 PM
DPelletier
Heres one showing the two metal pces: the silkscreened aluminum top pce and the metal base with the tabs.
1974 'Cuda
[Re: DPelletier]
#214649
02/11/09 01:07 PM
02/11/09 01:07 PM
DPelletier
The difference in gloss makes it harder to tell, but I'd say the grain, pattern and color are close.....but as I said; not close enough to mix and match. Still the best option out there short of finding NOS stuff (I didn't find any in 5 years of looking). Dave
1974 'Cuda
[Re: DPelletier]
#214654
12/14/09 08:44 AM
12/14/09 08:44 AM
Posts: 324 GA
roy2345
GA
[Re: roy2345]
#214655
12/14/09 09:10 AM
12/14/09 09:10 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
There's also a small difference between the '69's and '70's. The '69's have the "up" arrow next to the panel "dimmer" switch whereas the '70's don't.. Look close to the '69 and you'll see the arrow. The flasher is obviously different. EDIT:: I did visit Mike's BEA website and their woodgrain example pictures for the '69 versus the '70 are correct... Good going Mike... 1969 woodgrain: 1970 woodgrain:
[Re: RedFish]
#214658
12/14/09 12:02 PM
12/14/09 12:02 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Need to restore the wood on my Rallye dash. Which is better, easier to do, buy the wood grain with the metal backing or just the decal and cover the old one? Who sells the best looking repos.
Thanks,
I bought an overlay and it was pure junk. It was from year one or paddock, I forget. but it didnt even fit, forget the correctness of the grain or the letters... you could totally see the old wood around the bezels. it wasn't big enough. unless they changed them since then, i'd get yours refinished or just go with the BEA parts.
