Re: Can compression hurt power?
[Re: AndyF]
#21470
01/17/06 07:37 PM
01/17/06 07:37 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
My answer would have been a lot different if I knew of the other variables. But the original question was general. Can Compression hurt power. That question by itself I stick with my original response.
But, if you are talking hemi which I know very little about other than you run a hollow dome to keep the piston light due to the huge dome to make compression. I would try and run someththing with the least dome I could and cram all the stroke I could in it making my compression that a way. This theory could be way off due to the hemi-culties but in theory this is the way I would lean.
[Re: moper]
#21471
01/17/06 07:46 PM
01/17/06 07:46 PM
Posts: 860 Fort Pierce, FL
Outlaw10_5
Fort Pierce, FL
With FAST rules, it would be very hard to get away with the MSD timing contorller ignitions..They neeed a #1 cylinder reference, and the probe will be visible, even if nothing else is.
Only if you want to use the ICT function.
[Re: Outlaw10_5]
#21472
01/17/06 08:14 PM
01/17/06 08:14 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Jeff, for sure I`m just letting you do your thing on this engine. I`m just trying to learn/understand all this. As most people know I`m the 1st guy to ask questions.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: DaveDudek]
#21473
01/17/06 10:07 PM
01/17/06 10:07 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Of course, the irony of a 4 stroke multi cylinder motor is that the compression cycle of the adjacent cylinder takes power generated from it's neighbor on it's power stroke. so increasing compression proportionally increases the internal load on the crank for it to overcome. Normally aspirated, as compression increases, power increases, likely to the motors very ability to maintain seal of the compressed mixture and the heads ability to flow gases in and out. but apples to apples compression alone doesn't tell the whole story, in simplest terms there is likely an optimum combustion chamber and cam timing for each ratio and for any given crank speed. And for example going from 10:1 to 13:1 in a hemi doesn't react like 10:1-13:1 in a wedge, too many variables in static vs dynamic especially with regard to timing events.
[Re: mbogina]
#21476
04/27/13 11:06 PM
04/27/13 11:06 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
You cannot make acceptable HP with a huge duration cam in a low compression motor
What would you consider huge duration for a 9-1 470 CI motor?
[Re: IcorkSOAK]
#21480
04/28/13 12:04 PM
04/28/13 12:04 PM
LSP
Charlotte, NC
ANYONE remember the 366 short-stroke Hemi ?
Those never ran well, a 10.7" deck and 3.218" stroke has ugly written all over it. The combo that did work was the 383 block/hemi head combo, compression was 11.25, cam had 15* shorter exhaust lobe, set the PS speed record before they went to 500" motors.
[Re: DaveDudek]
#21481
04/28/13 12:05 PM
04/28/13 12:05 PM
Posts: 4,219 New York
polyspheric
New York
"Dynamic compression" is this year's cliche, and greatly over-valued as an effect.
Boffin Emeritus
[Re: polyspheric]
#21482
04/28/13 12:13 PM
04/28/13 12:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why do you say that... to me when the intake closes is when you start the compression... so whats so over rated about it... to me its more important than just a math number for the cyl volume
[Re: Coldart]
#21485
04/28/13 04:37 PM
04/28/13 04:37 PM
Posts: 903 Saskatchewan, Canada
cudabin
Great post guys... Any comments on the effects of the exhaust restriction from factory manifolds and 2.5" pipe/mufflers on this combo? My understanding has been that this exhaust restriction is more of a problem at higher RPM's, so perhaps the added stroke will lower peak power range and have less exhaust pumping losses? More compression should not hurt this. At almost 500" would this motor not benefit from a wider LSA ?? Good luck with it Dave! IMO your in good hands with Jeff... Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: MR_P_BODY]
#21486
04/29/13 12:24 AM
04/29/13 12:24 AM
polyspheric
New York
It is - until engine speed goes above 1,000 RPM. After this point, and depending on manifold and port volume, inertia, gas speed etc. it approaches rhwn reaches full stroke - at some point before peak torque. If you still have capture based on IVC anywhere near your power peak your cam is wayyy, wayyy too big.
Boffin Emeritus
[Re: BIGSPEED]
#21488
04/29/13 09:03 AM
04/29/13 09:03 AM
Posts: 1,057 The Great White North
RAMM
It has already been mentioned by guys smarter than me-but I would say that compression will help until the dome gets in the way of flame travel. Also you will need a different camshaft--again pay close attention to this with a big change in compression. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#21489
04/29/13 03:34 PM
04/29/13 03:34 PM
polyspheric
New York
True - the negative effect of dome intrusion on VE can be somewhat reduced by running a narrower LSA.
I don't think the more successful work done with complex chamber shapes has been made public. Hint: there's squish happening during overlap too...
Boffin Emeritus
