1969 340 auto A/C power steering pulleys?? #2144031
08/30/16 06:30 PM
08/30/16 06:30 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Anyone have pics/descriptions/dimensions of the correct crank & water pump pulleys?
Re: 1969 340 auto A/C power steering pulleys?? [Re: 6bblgt] #2144088
08/30/16 07:56 PM
08/30/16 07:56 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have the pulleys at home still on a 68 coronet 318, but I'm am still on vacation in Durango Colorado. Should be home on Thursday if you can wait that long.
Re: 1969 340 auto A/C power steering pulleys?? [Re: fastmark] #2144963
08/31/16 10:38 PM
08/31/16 10:38 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I took pics of the 69 340 A/C engine I have out of a Barracuda convertible, also took a pic of a 68 318 A/C balancer on a junk engine outside the shop, don't know what I did with the pulley's for it. shruggy First the 68, then the 69 340.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 340 auto A/C power steering pulleys?? [Re: Rhinodart] #2144967
08/31/16 10:39 PM
08/31/16 10:39 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Another couple pics of the 69...
A-Body's RULE!
Re: 1969 340 auto A/C power steering pulleys?? [Re: 6bblgt] #2145145
09/01/16 01:45 AM
09/01/16 01:45 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Everything you need is here, except the parts are ID'd by part number, not size:
http://www.faxonautoliterature.com/Search.aspx?k=engine+equipment+assembly&c=30737
These are factory "engine dress" drawings used at the car assembly plants (not the engine plants) to add the options such as PS, A/C, auto/manual trans. Same publication also exists for '69 Dart at Faxon.
I have a '69 340 with factory air, no PS. This is what I know:
Crankshaft pulley to A/C water pump pulley ratio is 1.3:1 size-wise, which yields 1:1.3 rpm-wise, so the fan is turning 1.3 times faster than the crank.
A/C uses 5-3/4" water pump pulley (hard to find) and a 3-1/2" diameter 6-vane water pump impeller to make the fan run faster and cool more. Non-A/C uses 6-1/2" pulley with an 8-vane, 4-3/8" diameter impeller. Both pulleys pump the same amount of coolant per crank revolution, but the 7-bladed fan is running faster on the A/C's smaller pulley. Many parts dealers selling water pumps don't know about the 6 or 8 vane impellers. I suspect many 340s out there have the wrong number of vanes and the owners don't know and it doesn't seem to make that much difference. But the 5-3/4" pulley is surely important for Nevada.
Given that the crankshaft pulley to water pump pulley ratio 1.3:1 and the water pump pulley is 5-3/4" then the crankshaft pulley is 7.48" (or maybe 7-1/2") diameter at the water pump belt. But never mind, because according to the manual above there is only one 3-groove crank pulley for 318/340 with either A/C or PS or both, and there is only one one-groove crank pulley for 318/340 with neither PS nor A/C. At least this is the case for 1969.
In the photos above, the fan spacer is non-factory for A/C in '69. Factory was a thermostatic fan clutch. That fan or water pump pulley looks to be the correct 5-3/4" for A/C. There is only one harmonic balancer for '69 340 regardless of PS, A/C or not according to the drawings above.
07-04 Cooling.fan clutch w green inspection mark1.jpg07-04 Cooling.fan clutch w green inspection mark2.jpg07-04 Cooling.fan clutch w part numbers3.jpg
