Re: Front end allignment ?
[Re: CARMAN]
#2141028
08/26/16 12:03 AM
08/26/16 12:03 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Has the Lower Control arm bushing stud to K-member hole been repaired? Any cracking that could cause flexing? Any drivers side collisions? Are there factory spot welds on the inner fender? At joint to the radiator support? You could try running an adjustable strut rod on the left side and slightly pull the LCA forward. -You have to disconnect the lower ball joint, back off the T-bar all the way, and adjust the strut rod too short. -Then feel the natural up and down movement of the LCA and ride height. -Then push the LCA forward before it feels like it's binding or pinching the LCA rubber bushing. Then adjust the strut rod to that new length so the back strut bushing is against the K-member. Or measure your old strut rod and make the new one 1/2" shorter. Theatrically that will give you around 3 deg positive caster assuming UBJ to LBJ is roughly 9" If you could add 3 deg pos caster I think that would net you 2-3 deg caster with 1/4 deg negative camber. After that you can adjust the right side to match. And you appear to have plenty of adjustment to do that. That's sort of a band aid until you for sure identify what is going on in the left front. And figure if the issue is stable and not going to worsen. Or if want to attempt to fix it.
[Re: BDW]
#2141251
08/26/16 12:49 PM
08/26/16 12:49 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Take it back and tell them to put 2005 Mustang GT specs on it. What specs would that be? +7* caster left and right, -.75* camber left and right, +1* toe. Obviously they won't hit the caster number, which is fine as any positive you can get is better than stock, but it gives them a late model target that will be in any alignment computer, at any shop, nationwide, that any toe and go tech can likely perform.
[Re: NANKET]
#2141553
08/26/16 11:02 PM
08/26/16 11:02 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Carman you need to get that car in the garage and pull all those cams out and clean the rust off of the body where the cams fit. Next clean and lube all the cams and hardware or find some new ones. It's really hard to get a smooth movement out of the cams in that condition. If I was doing the alignment I would charge an extra $50 to deal with the rusted cams Don't ever bring a car to the alignment shop with all that paint and rust on the cams because the alignment won't stay in place because you cant torque the nuts down properly.You need to make sure you have clean rust free surfaces with some good wheel bearing grease on the bolts. By the way I probably align over 100 Toyota cars and trucks every year and just because I work on imports for a living doesn't mean I can't do Mopars Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: NANKET]
#2142080
08/27/16 07:29 PM
08/27/16 07:29 PM
TC@HP2
Pikes Peak Country
This is why you do not tell them to use these 2005 mustang specs, it will confuse them more than they are now. Never get half of that caster spec on a stock suspension. I disagree, but certainly your mileage may vary. When they fail to hit that spec, you look at the numbers, thank them for the effort, and walk out of the shop with maximum positive caster. Even if it is half of the mustang spec, its more than the stock specs, which will achieve a better driving vehicle, unless you insist on using F70 bias plys under your car. There is no reason why a tubular upper arm suspension, which the OP has, can't hit those numbers and there are some on this board who have achieved more than that.
[Re: TC@HP2]
#2142620
08/28/16 06:29 PM
08/28/16 06:29 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
This is why you do not tell them to use these 2005 mustang specs, it will confuse them more than they are now. Never get half of that caster spec on a stock suspension. I disagree, but certainly your mileage may vary. When they fail to hit that spec, you look at the numbers, thank them for the effort, and walk out of the shop with maximum positive caster. Even if it is half of the mustang spec, its more than the stock specs, which will achieve a better driving vehicle, unless you insist on using F70 bias plys under your car. There is no reason why a tubular upper arm suspension, which the OP has, can't hit those numbers and there are some on this board who have achieved more than that. Well OK, if you look at his adjuster bolts the left side rear one is all the way in so caster is maxed at that wheel and both sides is less than one degree. Where is the 7 degrees here?
[Re: CARMAN]
#2142714
08/28/16 09:26 PM
08/28/16 09:26 PM
Posts: 5,800 ohio
ruderunner
ohio
Are these adjustable control arms? If yes are the arms set right?
Fwiw years ago I did some work for a guy with a stealth. He bought adjustable rear arms.
I st the factory adjusters to center, then adjusted the arms . this allowed the arms to make the big changes and kept the factory adjusters for fine tuning.
And I agree the factory specs for vintage muscle cars are completely out dated.
Angry white pureblood male
[Re: NANKET]
#2142835
08/29/16 12:03 AM
08/29/16 12:03 AM
TC@HP2
Pikes Peak Country
It isn't there in its current configuration. The whole thing was not assembled correctly to begin with. Every aftermarket tubular upper control arm out there is designed with an additional 3-4* of positive caster in them. With this built in improvement, the fact that they couldn't achieve even that amount means it was not put together correctly. I'm willing to bet that achieving max positive caster was never a consideration during assembly because if it was, strut bushings, strut rod length, and lower control arm placement would have been forefront in consideration during assembly. Doing this and using offset bushing in stock control arms could easily get 3-4* positive. Swap to an aftermarket arm with an extra 3-4*, and 7* should be easily achievable. Dialing in possible alignment numbers begins with the basic assembly of the suspension. Just like building horsepower begins with degreeing a cam to optimize valve events, so too should suspension be assembled with precision and forethought at the numbers to improve its performance.
[Re: CARMAN]
#2143229
08/29/16 05:33 PM
08/29/16 05:33 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Just went through all this with my 73 "Cuda. One thing not mentioned was ride height. I set mine before the alignment shop visit. If that is off, the rest of the alignment will be off and alignment racks never mention it anymore. I could not get any positive caster out of mine so I went with tubular upper arms as well. Final alignment with the new arms was +3.5 left +3.4 right caster. Camber was -.6 left and -.7 right. The guy did not use any canned settings but went online to research it. One of the places he looked was here on Moparts. The results to me were astonishing, it has not handled like this in 35 years. I am very happy. Craig.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Fab64]
#2151212
09/09/16 06:44 PM
09/09/16 06:44 PM
Posts: 605 TN
1DGEMAN
TN
Instead of looking at the standard, big-name franchise shops, maybe you can find an independent guy? I use a guy who has his own shop, has been around for a long time and knows old cars. Good luck. So Fab64 where is this shop? I am in SoCal also and am looking for an alignment shop. Thanks, Rod
Real Men shift for themselves
[Re: ruderunner]
#2151427
09/10/16 01:16 AM
09/10/16 01:16 AM
TC@HP2
Pikes Peak Country
\\ Possibly. Unlikely, but certainly possible. Further up, OP said it was rebuilt with stock bushings. That typically means there is not a strut rod problem, but I'd certainly recommend looking into the whole strut rod and lower control arm relationship to the K-frame. If this combination of parts is not fully seated, the lower arm will be set too far back and cause the same inability to get caster.
