Max wedge 4 bolt valve covers - 440 heads #2139232
08/23/16 11:38 AM
08/23/16 11:38 AM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
I'm sure this has been done many times. Just looking for feedback on people that have run the MW 4 bolt valve covers on 440 6 bolt heads and how well they sealed? Best gasket? Any other issues?
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2139249
08/23/16 12:12 PM
08/23/16 12:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Used 6 bolts on the 4 bolt heads on my kids 62 300.No problem.Ive seen and run 4 bolts on later 6 heads.Only gaskets we use are Mr Gasket ultras dry.Rocky
Chrysler Firepower
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2139357
08/23/16 04:02 PM
08/23/16 04:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've seen many M.W. four bolt valve covers that had the extra lip on the corners to help seal the original V.C. gaskets better, my 1963 415 HP Belvedere had them stock up I've also seen some later 1966 to 1969 six bolt V.C. welded up to look like original M.W. four bolt covers work
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Cab_Burge] #2139763
08/24/16 08:26 AM
08/24/16 08:26 AM
6T4 Polara Offline
6T4 Polara  Offline
I believe somewhere mid 63 they went from 4 to 6 bolt.
You did not state what year you need info for.
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2139773
08/24/16 09:20 AM
08/24/16 09:20 AM
Tempest Offline OP
Tempest  Offline OP
The only ones I see reproduced are 4 bolt.
Re: Max wedge 4 bolt valve covers - 440 heads [Re: 6T4 Polara] #2139961
08/24/16 03:32 PM
08/24/16 03:32 PM
Not so, they went to the six bolt valve covers on all the heads in 1964, Max wedge or 361 two barrel motors shruggy
Mopar did make a limited amount of 425 HP Stage Two 426 in 1963 for drag racing only, bigger carbs, bigger cam, hand modified combustion chambers on the 286 heads for better flow and hand modifeid intake manifolds for the the bigger carbs. scope
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2139994
08/24/16 04:18 PM
08/24/16 04:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not all 4 bolt are max wedge also.They came on all early BBs.Rocky
Chrysler Firepower
Re: Max wedge 4 bolt valve covers - 440 heads [Re: therocks] #2140342
08/25/16 12:04 AM
08/25/16 12:04 AM
There was two versions of the early 4 bolt valve covers, those for non adjutable rocker arms with the stamp steel rocker arms and the other type was for the stock Mopar adjustable ductile iron rocker arms scope They are not interchangable shruggy You can run the adjustable covers on the non adjustable rocker arm heads but not the other way around shruggy
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Cab_Burge] #2140384
08/25/16 01:34 AM
08/25/16 01:34 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
What is the difference between the two covers?Is there more clearance on the max wedge cover?
Re: Max wedge 4 bolt valve covers - 440 heads [Re: keith airgrabber] #2140420
08/25/16 04:22 AM
08/25/16 04:22 AM
I never measure the hieght differences between the two covers but if you tried to run the stock ductile iron adjustable rocker arms under the stock covers off a hydraulic cam motor the adjusters would hit the oil baffles inside those covers just like they did and do on the later 6 bolt non adjustable covers shruggy
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2140459
08/25/16 09:47 AM
08/25/16 09:47 AM
Tempest Offline OP
Tempest  Offline OP
Was going to do this for the period look when I put a cross ram on the car. However, sounds like I may have some issues with rocker clearance. I'm running Crane roller rockers.
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2140463
08/25/16 09:54 AM
08/25/16 09:54 AM
Minnesota
peabodyracing Offline
Minnesota
Just looked at a set a few weeks ago. Guy was running roller rockers and had cut the oil shields out for clearance.
Lead, follow or get the hell out of the way
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Cab_Burge] #2140474
08/25/16 10:23 AM
08/25/16 10:23 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I'm planning on running my 915's with a set of Isky ductile rockers...The difference in the v/c's your talking about does it only apply to stock covers? work
I have a set of NOS Offenhauser finned 4 bolt v/c's I was planning on using... shruggy
...FAFO...
Re: Max wedge 4 bolt valve covers - 440 heads [Re: skicker] #2140498
08/25/16 11:08 AM
08/25/16 11:08 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
If I'm not mistaken the "taller" valve covers have an oil fill tube that is 1/2" taller then stock. However I do not know what the measurements are as I do not think I have any more of the 4 bolt valve covers to get the measurement.
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Cab_Burge] #2140540
08/25/16 12:50 PM
08/25/16 12:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yes you can,these were originally 4 bolt with the blank end tabs not drilled for the end bolts. grin
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2140743
08/25/16 06:58 PM
08/25/16 06:58 PM
Tempest Offline OP
Tempest  Offline OP
So back to original question. I plan on running a set of the repro 4 bolt valve covers on 440 heads. Sounds like they will seal just fine. However, I may have to modify a bit to run with Crane roller rockers?
These particular valve covers:
http://www.manciniracing.com/19mobigbl426.html
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2140818
08/25/16 09:07 PM
08/25/16 09:07 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I have a set of the 4 bolt covers somewhere & also offy. finned ones.
Re: Max wedge 4 bolt valve covers - 440 heads [Re: Tempest] #2140821
08/25/16 09:08 PM
08/25/16 09:08 PM
If they don't have the extended M.W. corners on them they will probally leak in the corners on the 440 heads shruggy
