I think there was a bunch, maybe 12, of different part number Holley six pak carbs in 1970, stick and automatic, California ECS stick an dauto trans,CA non ECS,two r three different other part numbers for non CA domestic use as well exports maybe
The list number is stamped on the main body on the back of the passenger side throttle bore so you can't see it without the carbs in your hands or maybe with mirror. I'm not sure if Mopar had Holley reproduce some of the 1970 carbs or not
I bought a set of 1971 reproduction carbs that came with the original List number with a dash number after the main number, for instance 4404-1 or 4404-2(not a real Holley six pak part number probally but that is what came into my head for this example
) when the origianl number was 4404 with no dash number after it
I'm thinking my original non CA center carb. came with 63 jets
I had four or five sets to choose from back then
Mopar parts hoarder I am
