Page 36 of 45 1 2 34 35 36 37 38 44 45
Re: Trick Flow heads [Re: DLewis] #2136952
08/19/16 11:54 PM
08/19/16 11:54 PM
6_pack_runner
6_pack_runner
Originally Posted By DLewis
We went to Dyno today. 511 flat tap solid cam, M1 intake, Holley 950 XP, Hughes 1.5 rockers, 2" exhaust.
Nice....Did you end up going with a Low Deck or did you keep the 75 440 block ? Care to share a full rundown of your engine/parts ?
Re: Trick Flow heads [Re: DLewis] #2137100
08/20/16 06:32 AM
08/20/16 06:32 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That looks pretty lean shock
Re: Trick Flow heads [Re: fast68plymouth] #2137367
08/20/16 06:13 PM
08/20/16 06:13 PM
AndyF Offline
AndyF  Offline
The Harland rockers lose a little bit of lift with the stiffer K-950 springs. I think they were .750 with the Trick Flow springs but now are down to 0.738 lift.
Re: Trick Flow heads [Re: AndyF] #2137715
08/21/16 09:57 AM
08/21/16 09:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is this a hyd. lifter cam ?
Re: Trick Flow heads [Re: JohnRR] #2137779
08/21/16 11:57 AM
08/21/16 11:57 AM
6_pack_runner
6_pack_runner
Are you serious...A .750 lift Hydraulic cam eek
Re: Trick Flow heads [Re: JohnRR] #2137856
08/21/16 01:30 PM
08/21/16 01:30 PM
AndyF Offline
AndyF  Offline
Solid roller cam
Re: Trick Flow heads [Re: fast68plymouth] #2137954
08/21/16 03:39 PM
08/21/16 03:39 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
What compression ratio, and what fuel did you run?
Re: Trick Flow heads [Re: Skeptic] #2138159
08/21/16 09:32 PM
08/21/16 09:32 PM
The BSFC looks good up I would look at the spark plugs and try richer first and then leaner second to find out what the motor really likes as far what that O2 systems reads work twocents
OP, Did you try higher RPM before stopping the dyno tests? If not I would have thumbs work
Re: Trick Flow heads [Re: fast68plymouth] #2138570
08/22/16 02:08 PM
08/22/16 02:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
I have another set of TF heads in the shop now.
This set has the 1.550 flat tappet springs and steel retainers.
The spring pressures don't really coincide with the spec sheet that comes with the heads.
The spec sheet shows these heads to come with TFS -16094 springs, and that they have 138lbs at 1.950/430lbs at 1.250, with a 420lb/in rate.
The TF dual spring spec chart on line shows different specs than that, and are closer to what I observed.
TF claims these are PAC springs, and the specs are the same as a PAC 1294, so that's likely what they are.
The specs for that spring are 175lbs at 1.900/442 at 1.275, 428lbs/in.
I have 2 calibration springs for my tester, and according to both I am within 2lbs of those springs.
The springs that come on these heads start to have some coil to coil contact at about 1.300, so at heights shorter than that the rate starts to climb pretty quickly.
The coil bind height is listed at 1.190, and while some would get that low, several wouldn't and were solid at about 1.220-1.230.
My observed pressures at various heights for all 16 pieces are;
145-150 @ 1.980
160-165 @ 1.950
185-190 @ 1.900
390-395 @ 1.400
420-425 @ 1.350
455-465 @ 1.300
465-480 @ 1.275
480-500 @ 1.250
My suggestion for someone using this version head/spring...... Especially if you're planning on running a flat tappet cam and using most of the available lift from the spring is to verify the installed heights and pressures.
This set of heads had the installed heights between 1.945 and 1.960.
Re: Trick Flow heads [Re: fast68plymouth] #2138677
08/22/16 04:13 PM
08/22/16 04:13 PM
AndyF Offline
AndyF  Offline
Those seem a little on the high side for a flat tappet. Good thing you checked them over.
Re: Trick Flow heads [Re: fast68plymouth] #2138685
08/22/16 04:27 PM
08/22/16 04:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
I checked the guide clearances as well.
6 of the exhaust valve stems were .3413-.3415, the other two were .3411.
The intake stems were all .3410-.3411.
The guides were basically all the same, and had about .0006-.0008 clearance on the intakes, but those larger diameter exhaust stems were pretty snug(for my liking anyway) at .0004-.0005.
The valve stems on these heads are polished to a very smooth finish, and the reamed finish of the guides are also very smooth, and my guess is with those ultra-smooth finishes you can get away with tighter clearances.
However, I went with what I've had success with for over 20 years and set the intakes up at .0011-.0012, and the exhaust at .0014-.0015.
I'll reassemble the heads with the springs at 1.980 for a nominal 150lbs on the seat, and with the cam that will be used with these heads will be around 390lbs open.
These are going on a 493 street cruiser, and that will be more than enough pressure.
I'll assemble the heads with the inners removed for cam break in.
Re: Trick Flow heads [Re: AndyF] #2138823
08/22/16 07:41 PM
08/22/16 07:41 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
if you are concerned with the pressure how do you feel about Hughes requiring 155/415 spring pressures ?
I am running 130 seat with my Iskys (8305?) at the moment . And am looking at 135-140 for my new motor.
Solid FT cams
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: tex013] #2138872
08/22/16 08:37 PM
08/22/16 08:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Dwayne@Andy,After getting my TF heads I realized I had ordered the wrong springs for a roller cam, came with flat tappet springs, so I needed to change the springs, so I elected to go with the PAC 1225 dual spring which is 250# on the seat @ 2.00 but will be installed at 1.950 which will increase the seat pressure to 282# and open pressure will be 726# with the .690 cam plugged into Pac's calculator,,do you see any issues going this route? also thanks for the guide info as I will have Doug check and/or correct the guide clearance since they seem a little tight to me also, any suggestions are welcomed.
Re: Trick Flow heads [Re: fast68plymouth] #2139016
08/22/16 11:51 PM
08/22/16 11:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
My advice is to check the actual pressures for the new springs and set the installed height accordingly.
Re: Trick Flow heads [Re: fast68plymouth] #2139490
08/23/16 07:44 PM
08/23/16 07:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Re: Trick Flow heads [Re: fast68plymouth] #2141018
08/25/16 11:51 PM
08/25/16 11:51 PM
AndyF Offline
AndyF  Offline
Buttoned back up and ready for the dyno
Re: Trick Flow heads [Re: AndyF] #2141245
08/26/16 12:37 PM
08/26/16 12:37 PM
JohnRR Offline
JohnRR  Offline
Solid roller cam
Are the rockers deflecting to cause the loss of lift with the stiffer spring?
Re: Trick Flow heads [Re: fast68plymouth] #2141289
08/26/16 02:21 PM
08/26/16 02:21 PM
AndyF Offline
AndyF  Offline
Probably. Either the rocker arm is deflecting or the pushrod or something else. My money is on the rocker arm as the most likely item to be deflecting. If they are deflecting 0.030 each cycle then that tells you why they eventually break.
Re: Trick Flow heads [Re: AndyF] #2141333
08/26/16 03:23 PM
08/26/16 03:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sure it's not the shafts............
Re: Trick Flow heads [Re: Thumperdart] #2141371
08/26/16 04:18 PM
08/26/16 04:18 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Aluminium rockers pretty much all deflect under high spring loads. It's the nature of the beast...
