Re: Tubing Notcher???
[Re: CJD AUTOMOTIVE]
#2138503
08/22/16 12:43 PM
08/22/16 12:43 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Can you send the video link again. Its the wrong link. I've used a Mittler bender and vertical mill notching fixture for over 20 years. With that being said, had a friend show me a video, https://youtu.be/mHBanmfn_CA is a while back, and I thought, hmmm. So I tried it on the next cage. I'll use the notcher on a 90 degree fish mouth, but anything else, the chop saw. The notches are just as good and take 1/3 the time. See if you can tell which ones were done which way.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 65 Hemi]
#2138504
08/22/16 12:45 PM
08/22/16 12:45 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Can you send the video link again. Its the wrong link. Sorry, fixed it.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: 65 Hemi]
#2138511
08/22/16 01:02 PM
08/22/16 01:02 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Once you try it, you'll never go back! It is so fast and accurate!
[Re: 65 Hemi]
#2138542
08/22/16 01:34 PM
08/22/16 01:34 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Notching tubing on a vertical mill is sweet........however, it IS hard on your mill and will loosen it up. IF you also intend to continue to use your mill to do precision work, buy a separate notcher. I use a mill, but its an old beat up one I bought JUST to notch tubing. My GOOD mill never gets used to notch tubing. I use hole saws, but even at the proper speed and technique, you WILL knock teeth off the saws at times. If you replace a hole saw every time you knock a tooth off, you will go through a bunch of them. After it knocks a couple teeth off, it shakes the mill pretty good and that's what loosens it up.
I have notched a many a piece of tubing with a chop saw, like in the linked video, although I didn't clean it up with a hand grinder like video. With a large rock on a bench grinder, you will eventually get the rock shaped like tubing and it makes cleanup a breeze. However I can't say that is faster than a hole saw type notcher. Not close to me, because if you make the cut right the first time on the hole saw notcher, all you need to do is debur and weld
[Re: Monte_Smith]
#2139195
08/23/16 10:02 AM
08/23/16 10:02 AM
Posts: 19,682 north of coder
moparx
and something to do with your junk hole saws. when the teeth are all gone, just about, or enough are missing you don't want to use them any more, grind off the remaining teeth, then use a disc sander while the hole say "blank" is spinning in your drill press, lathe, or mill at a fairly high speed, forming a sharp edge on the saw body. take a 5/8-18 bolt of approximately 3-4" long [or what ever thread size your holesaw has], cut the head off the bolt and attach. these re-purposed saws work great for punching holes in gasket material or leather, and i have also used one of these contraptions to punch a hole in .024 aluminium sheet for a gauge installation. resharpen as necessary. these also work to cut burr free plugs in 1/4" urethane and hard rubber sheet stock using approximately 1200-1800 rpm in your drill press. it's hard for me to through any broken tool away if i can use it for another purpose.
[Re: 65 Hemi]
#2140319
08/24/16 11:43 PM
08/24/16 11:43 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So, thanks to Quicktree, I now own a Pro-Tool tubing bender with dies, and a Pro-Tool tubing notcher. He even threw in the tubing software. Can't wait to get it all set up and start playing. Thanks again, Quicktree.
[image][/image]
[Re: sgcuda]
#2140609
08/25/16 02:37 PM
08/25/16 02:37 PM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
So, thanks to Quicktree, I now own a Pro-Tool tubing bender with dies, and a Pro-Tool tubing notcher. He even threw in the tubing software. Can't wait to get it all set up and start playing. Thanks again, Quicktree. The power of Moparts
