Re: How abouts a parts weight database? I will start
[Re: TheOtherDodge]
#21371
12/31/05 06:30 PM
12/31/05 06:30 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
side impact beams in challenger doors 22lb each stock bucket seats 45 each battery,tray and bracket 48lb
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: mcat4321]
#21373
01/01/06 09:10 AM
01/01/06 09:10 AM
66-67 BBody
Internal AC Box / Blower / Heater Core - 52 lbs. Power Steering box/pump/lines - 45 lbs. Front Bucket Seat - 51 lbs. Center console - 22 lbs. Stock Flat Hood with brackets - 69 lbs. Stock 8.75" housing/Moser 4.10 spool chunk/Moser Axles/drum Brakes - 212 lbs Fifty Lb balast bar - 50lbs.
#21374
01/01/06 11:21 AM
01/01/06 11:21 AM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
70 Challenger p/S box--35# 11Oz t Bars pair of .96, 17# 12 oz uc arms pair 10# 1 oz bare k frame 37# 15 oz pair of bare spindles 12# front 10" front drum brakes pair 64# 9 0z k frame as dropped out of car with steering box, all bolts ( no shocks or UC arms) 208 lbs weight of everything in above 236# 15 x8 bare ralley wheel 25# 11 oz outer front bumper bracket 9# pair inner 10# pair Hooker headers for Hemi 33# pair stock rear axle 19# 7 oz each rear spring 39 # 9oz each rear bumper, bolts and brackets 26# 1oz front bumper ,brackets and bolts 35# bucket seat 46# 8 oz steering column 24 # 2oz door beam 24# 7 oz empty 727 (no tc) 129# indy single 4 intake 20# rear 10" drum 12# 6 oz each PS pump with brackets 13 # 7 oz
[Re: VanishPt]
#21375
01/01/06 11:52 AM
01/01/06 11:52 AM
Is there anyway I can add this to Harpos weights for a 66-7 b-body? Anyway.. Back seat 45# Front bumper w/o brackets 25# This is a great idea!
[Re: TheOtherDodge]
#21377
01/03/06 10:44 AM
01/03/06 10:44 AM
fullmetaljacket
FULLMETALJACKET HERE.
Been away on a falling business for a while and now back. The following parts while the car was dismantled for painting were double checked on a second scale and then put back on the car unless other wise (Deleted) or (Replaced). This car hasn't an ounce of fiberglass/carbon fiber on its skin and is street driven to and from the races/car shows. WORD.
Defendant: 65' Dodge Coronet two door post. Front fenders: 58 1/2 lbs for the pair. Stock Hood: 68 lbs. Gutted carb hole opening with A990 Hemi hood scoop: 79 lbs. Hood hinges locking latch misc hardware: 13 1/4 lbs. 4-steel hood pins, replaced. Front wheelwell and headlight splash panels: 11 lbs. Power steering box, pump , belt, misc. hardware: 49 lbs. manual steering box, replaced. Master brake cylinder: 6 1/2 lbs. Front fold down bench seat, belts, mounting hardware: 100 lbs. A-100 bucket seats, replaced. Rear two piece seat: 56 lbs. (deleted) Stock radio: 6 1/2 lbs. (deleted) Heater unit, ducts, switches and misc: 27 lbs. (deleted)
[Re: TheOtherDodge]
#21379
01/03/06 03:05 PM
01/03/06 03:05 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
entire front suspension for a body including k member "237 lbs"
WAXER
[Re: TheOtherDodge]
#21382
01/04/06 03:16 PM
01/04/06 03:16 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
69 Plymouth Dash complete with all assy 48lbs
69 Plymouth Dash radio delete, heater delete, map light delete 42 1/2 lbs
69 Plymouth bucket seats 44 1/2 lbs each
15x7 steel rim 24lbs
15x6 steel rim 22 1/2
Complete 69 Plymouth steering column 24 1/2 lbs
Cast Iron HEMI 4-speed case 33lbs
Alum HEMI 4-speed case 15lbs
Complete alum HEMI 4-speed 88lbs
Complete cast iron HEMI 4-speed 121lbs
727 TQ 120lbs
STK HEMI balancer 13lbs
STK 440 balancer 6lbs
Stock 70 Challenger hood 78lbs
T/A fiberglass factory hood 46lbs
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: Ramcharger]
#21383
01/04/06 03:19 PM
01/04/06 03:19 PM
Posts: 1,819 Central New Jersey
Ira
super gas
super gas
Central New Jersey
This would be a very neat addition to the Tech Archives after some more info gets added.
this post has been saved, eventually it'll end up in the archives
[Re: TheOtherDodge]
#21388
01/20/06 09:37 AM
01/20/06 09:37 AM
Posts: 1,118 Central Missouri - USA
Ramcharger
super gas
super gas
Last night, I ran across the old Hot Rod issue where Steve Magnante took something like 500 pounds off of his Duster. I could post the numbers on all those items if anyone would be interested.
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop) '99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54 '89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift '14 Dodge Dart Limited 2.4/6-speed A/T
[Re: Ramcharger]
#21389
01/20/06 06:24 PM
01/20/06 06:24 PM
Posts: 1,262 Netherlands
72Challenger
Netherlands
If you have the time, yes please post these #'s as I'm just in the process of putting the Duster back together after the painting and tubbing.
Thanks a lot!
