Re: New Mopar W-5 Intake Gasket Sets
[Re: RAY1969CARS]
#2137406
08/20/16 07:17 PM
08/20/16 07:17 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just pulled my W-5 junk heads off today.. but I will be needing a few sets of W-2.. I hope Mancini's has them in stock What happen !? It smoked a little out the right side exhaust.. every time I have had those heads on it smokes a little.. I thought I had it fixed(a hole in the intake runner).. it was just super thin where I clearanced the push rod.. I tubed that but there must be something else And you pressure tested them ??? Pressure testing them is good for water issues, not oil issues. From what I've read the W5's are porous to start with then we add porting. It could be leaking from a valve spring pocket, bolt hole, pushrod pinch, or about any where else oil is close to.
[Re: pittsburghracer]
#2137414
08/20/16 07:29 PM
08/20/16 07:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The one thing that I know is its getting oil into the cyl.. so if I were to leak check the intake system It should show up.. have to have a plate on the head mounting surface another on the intake surface then pressurize it and maybe spray it with soapy water to look for air... but I think I would have to use clamps and not bolt for the head plate to watch the bolt holes.. dont really care right now.. I just want it on the street and running clean.. and strong
[Re: roadhazard]
#2137795
08/21/16 12:23 PM
08/21/16 12:23 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
OK..... where are all these W-5 users at?? I post about other new products and hear "when are you going to make gaskets for W-5's" I make the W-5 gaskets and all I hear is W-2 and GEN-III I am REALLY surprised that you hopped on this train. Most of the guys I know that ran W5's moved on.
#2137799
08/21/16 12:25 PM
08/21/16 12:25 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have one VIRGIN blue plug head sitting here the I bought for 250 dollars just in case I find another one 5-7 years ago. I kinda gave up looking.
#2137830
08/21/16 12:58 PM
08/21/16 12:58 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
OK..... where are all these W-5 users at?? I post about other new products and hear "when are you going to make gaskets for W-5's" I make the W-5 gaskets and all I hear is W-2 and GEN-III I am REALLY surprised that you hopped on this train. Most of the guys I know that ran W5's moved on. I was reluctant to jump on board, however...... Maybe I need to up the price 10 bucks a set
[Re: J_BODY]
#2138016
08/21/16 05:14 PM
08/21/16 05:14 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
considering I messaged you concerning W8 intake gaskets awhile back.... I find it hard to believe you went this route. I know the guy that bought one of my top ends is starting to assemble, so I'll let him know. W5 isn't even a good place to be from in my experience. If I ever find a virgin blue plug I will tread carefully in known water areas, sonic check often, and weld up other areas for needed volume space. I will also pour the water passages with (WaterGlass) to address porosity issues
[Re: J_BODY]
#2138059
08/21/16 06:21 PM
08/21/16 06:21 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
"weld"..... good luck with that. Weld before porting, not after. Lol
[Re: J_BODY]
#2138077
08/21/16 07:09 PM
08/21/16 07:09 PM
roadhazard
Akron, Ohio U.S.A.
considering I messaged you concerning W8 intake gaskets awhile back.... I find it hard to believe you went this route. I know the guy that bought one of my top ends is starting to assemble, so I'll let him know. W5 isn't even a good place to be from in my experience. I've had W-5 in my ear way more times than W-8. I'm a big block guy and don't know what the popular SB heads are or what gasket can fit multiple heads? I appreciate you dropping a line to the W-5 user Are the SB Victors their own animal also or will a 360-1 or some other have the same pattern? I do good just to get stuff cut, inspected, packaged, shipped out the door and keeping track of invoicing. Won't even mention the million other things that come into play running a business
[Re: roadhazard]
#2138082
08/21/16 07:17 PM
08/21/16 07:17 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
considering I messaged you concerning W8 intake gaskets awhile back.... I find it hard to believe you went this route. I know the guy that bought one of my top ends is starting to assemble, so I'll let him know. W5 isn't even a good place to be from in my experience. I've had W-5 in my ear way more times than W-8. I'm a big block guy and don't know what the popular SB heads are or what gasket can fit multiple heads? I appreciate you dropping a line to the W-5 user Are the SB Victors their own animal also or will a 360-1 or some other have the same pattern? I do good just to get stuff cut, inspected, packaged, shipped out the door and keeping track of invoicing. Won't even mention the million other things that come into play running a business Someone was looking for you in the question and answer section. I gave them your contact info.
