Page 35 of 45 1 2 33 34 35 36 37 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2132215
08/13/16 08:44 PM
08/13/16 08:44 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Will you do something to block the std head oiling so you don't over oil the top end?
Re: Trick Flow heads [Re: fast68plymouth] #2132286
08/13/16 10:35 PM
08/13/16 10:35 PM
AndyF Offline
AndyF  Offline
I'll watch it first to see what happens and then go from there.
Re: Trick Flow heads [Re: fast68plymouth] #2132928
08/14/16 08:59 PM
08/14/16 08:59 PM
AndyF Offline
AndyF  Offline
I snapped an ARP head stud today while putting the heads back on. I was only at 70 ft-lbs on the torque wrench when it snapped. Never seen that before. Got lucky, the stud came out without any problems so I just need to order some replacements and keep going. Very weird, maybe a defective stud? I've re-used studs in the past multiple times with zero issues. Not sure why this one broke.
Re: Trick Flow heads [Re: fast68plymouth] #2132991
08/14/16 10:05 PM
08/14/16 10:05 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I had that happen to me last year I just ran a tap clean up the threads some
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Trick Flow heads [Re: AndyF] #2134591
08/16/16 07:50 PM
08/16/16 07:50 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Wait! Do I see an OE type valley pan in there???
Re: Trick Flow heads [Re: AndyF] #2134676
08/16/16 09:20 PM
08/16/16 09:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That is odd cos I`m running the 1/2" main studs from my 360 from 14+ years ago.............. work
Re: Trick Flow heads [Re: cudadoug] #2134846
08/17/16 12:44 AM
08/17/16 12:44 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
That would be an older photo, Andy just showing the clear valve cover.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: fast68plymouth] #2135012
08/17/16 11:24 AM
08/17/16 11:24 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Ok so if I have all this right:
1) the exhaust port is in the same location.
2) the head is overall taller than say an Eddy RPM.
3) The rocker shaft is moved up.
4) A Hughes Rocker lines up with the valve tip.
5) They have more potential than a fully ported Eddy RPM.
6) Sounds like you can use a 1.6 or 1.7 ratio rocker
Will 3/8" pushrods fit with higher ratio rocker and not require clearance ?
Thanks!
Re: Trick Flow heads [Re: fast68plymouth] #2135567
08/18/16 12:51 AM
08/18/16 12:51 AM
AndyF Offline
AndyF  Offline
3/8 pushrods fit fine. Here is a picture of 7/16 pushrods on my head with the T&D rocker arms. Looks to me like 7/16 will also work but it gets tight.
Re: Trick Flow heads [Re: fast68plymouth] #2135920
08/18/16 03:33 PM
08/18/16 03:33 PM
AndyF Offline
AndyF  Offline
These T&D arms are basically a 1.65 ratio. The cam lobe in the picture above is 0.445 and I'm getting .727 gross lift (zero lash). The 7/16 pushrods rub slightly in a few spots. Not sure if I'll run them or not. I don't really want to shave a bunch of aluminum into the motor so probably safer to run the 3/8 pushrods.
Re: Trick Flow heads [Re: fast68plymouth] #2135935
08/18/16 03:54 PM
08/18/16 03:54 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
What is the advantage of the ball/ball pushrods?
2011 Drag Pak Challenger
Re: Trick Flow heads [Re: fast68plymouth] #2135987
08/18/16 05:06 PM
08/18/16 05:06 PM
AndyF Offline
AndyF  Offline
You would need to ask T&D but my guess is they would say that it provides more clearance. The cup on the end of the pushrod can really eat into the rocker arm on a high ratio arm.
Re: Trick Flow heads [Re: AndyF] #2136047
08/18/16 06:23 PM
08/18/16 06:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looks like 1.633 with full spring pressure(around 650-700lbs with that spring)..... Pretty good!!
Re: Trick Flow heads [Re: fast68plymouth] #2136096
08/18/16 07:21 PM
08/18/16 07:21 PM
AndyF Offline
AndyF  Offline
I think these springs are around 750 lbs over the nose. They were 290 on the seat and 636 lbs/inch so math works out to 752 lbs. A little stiffer than what it said on the box for whatever reason. I'm seeing about 0.030 deflection for some of the rocker arms but the T&D design appears to be pretty stiff.
Re: Trick Flow heads [Re: AndyF] #2136305
08/19/16 12:00 AM
08/19/16 12:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What spring are you using? PAC? model number? FWIW As far as what ratio the rocker is verses what the manufacturer says etc. I call it mathematically whatever it winds up being as determined by the checker springs in relation to the cam lobe lift and lash. The as assembled 'real' spring just identifies the deflection which I have typically seen .025-.030" on springs around/above 800lbs. it is what it is I guess
Re: Trick Flow heads [Re: fast68plymouth] #2136388
08/19/16 01:59 AM
08/19/16 01:59 AM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
We went to Dyno today. 511 flat tap solid cam, M1 intake, Holley 950 XP, Hughes 1.5 rockers, 2" exhaust.
Re: Trick Flow heads [Re: DLewis] #2136397
08/19/16 02:09 AM
08/19/16 02:09 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
How wild a cam, if you don't mind sharing
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Trick Flow heads [Re: OUTLAWD] #2136404
08/19/16 02:26 AM
08/19/16 02:26 AM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
Don't mind at all.
Re: Trick Flow heads [Re: fast68plymouth] #2136431
08/19/16 04:30 AM
08/19/16 04:30 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
wow ,
a lot of cam . what was idle speed ?
How long did it hold up after peak HP ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: fast68plymouth] #2136447
08/19/16 08:28 AM
08/19/16 08:28 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I ran that cam in my 500" and it didn't peek until 6800, shifted at 7000, now I've got the smaller 23-633-5 it peeks at 6400. Your cam is to big if your only going to 6200.
As a note mine has 915 heads 2.18/1.81 25.5 cr and made 645 hp and 620 tq on E-85. Is 40 hp worth the cost of the heads? My junk has been together since 91, if I was starting over I would go with them, but I have a lot of parts to use up.
Have a great day
Iowan
"obsolete is neat"
